Question about Electrical Supplies
Need a manual for Electra Gas Generator 5500 8200 -- B&G stanadard motor. Probably a renamed Elite.
  • gnugnoli524 Aug 02, 2009
    Tom --
    Yes, I need the manual. Mine works and I want to give it to someone but I would like to make sure they have written directions. I can give you a fax number or an e-mail if you can send it that way. Let me know. Thanks, G.
I can give you the "OWNERS MANUAL" for the 5500/8200 Model 16172 Electra generator, but I don't think that is what you're looking for, is it? I purchased the generator at the Navy Exchange and got the 3 year warranty on it. When it suddenly wouldn't start going into it's third year, I contacted the warranty center and they told me where to take the generator for repair. That shop worked on it and finally got it to start, but when they attempted a second start - the starter 'dogs' hung up and were destroyed. The shop attempted to locate parts, technical services, etc., for Electra, but couldn't find anything and the warranty center finally returned my purchase money and the shop sent the generator back to the warranty center. Does the manufacturer still even exist? Don't Know.... Tom.... Pensacola, Fl
Posted on Aug 02, 2009
  • JustTom Aug 02, 2009
    I'll be glad to send you the manual via USPS - just give me address and I'll put it in mail tomorrow morning. Contact me at: JustTom@cox.net
I have a 8200/5500 mdl. 16172 electra i bought it from a friend a year ago brand new never had oil or gas in it all sealed , had it in the box till first week of the 10 th of April i fill it with oil and gas , pull the start and first pull started up , had it ran from 6:00 pm to 12:30 no problem, the next night i checked the oil ,ok , fill with gas started first pull , but i noted a nose coming from the starter recoil housing area , so i promised myself the next day to look at it ,
but after an hour of ranning it cut off and the way it dit i kno that it was not normal so i flip on my propein generator for the knight
the next day cheked , oil ,gas good i pull the starter and gass what it thogh a rod . i am told that is all this generator was to last
7:00 hours. would you beleive that sal m
Posted on Apr 16, 2010
I have a 4500e duromax starts up and runs then shuts off clean carberator same problem looking for suggestions
On the WEB
manual-duromax-elite-mx4500e-manual ' Generator Nation
www.generatornation.com/tag/manual-duromax-elite-mx4500e-manual/
DuroMax Elite MX4500E 4,500 Watt 7 HP OHV 4-Cycle Gas Powered Portable Generator With Wheel Kit & Electric Start Reviews. By Generator Man Posted in ..
Jul 31, 2015 | Cars & Trucks
Generator alarm underspeed
When you get the under speed alarm is the generator under load? Try manually starting the generator with no load and let it run for a while, if no alarm, then put it under your home load and measure current draw (maybe have an electrician check it) if the amp draw and in rush caused by compressors, pumps motors etc are within the generator rating, check your fuel pressure, on average 8-11 WC Nat gas. Pressure may test well under no load but drop starving the engine of fuel unde rload. Underspeed is just that engine cannot make RPM/Frequency
Nov 28, 2013 | Generac Power Systems Generac 5522 14 Kw...
I am having a problem with my Electra generator. I have gas in my oil and gas runs out of the carb or air breather. I have tried to find someone who sells parts for this generator and I can't. Any...
The problem is probably that the float valve is not sealing closed tightly enough. The amount of gas being delivered to the carburetor is regulated by a float in a bowl of gas. When the motor is running, it may be OK that the float valve doesn't seal completely, because you are using the gas a bit faster than the minimum leakage rate through that valve. But when you turn it off, the gas keeps coming (slowly, but it doesn't stop) so if floods the engine, filling the cylinder and leaking into the crankcase. You need to remove the bowl on the carb and clean the float valve so that it can seal closed. Also, it helps when you turn off the generator to close the gas valve (hopefully it has one) instead of turning it off with the kill switch. When you do shut off the gas it will continue to run for a minute or two until it uses up all of the gas in the bowl. This tends to be a problem with generators more than with lawn mowers for two reasons, The generator is not used as frequently, so the gas in the bowl tends to gum up and causes the float vale to not seal. And the gas tank is located a little higher above the carb on a generator than it is on a lawn mower - so the pressure is a little higher, making it more likely to seep past the float valve. good luck, Al K
Sep 02, 2011 | Electrical Supplies
I have a kenmore elite refrigerator. Am trying to
plan on 11 amps which would be 1100 watts and 115 volts.
Oct 03, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Just won't start
check the spark plug after a failed attempt to start. If dry, then no fuel is entering engine.
Did you leave old fuel in carb? if so, your carb probably is dirty: old gasoline deposits varnish, gum, and you will need to dissassemble carb and clean it.
Nov 14, 2008 | McCulloch 13HP 338 Cc Portable Generator #...
Kitchen Aid Fridge Model KBR522K
Most fridges pull between 4 to 5 amps (600 watts) so a 1000 watt generator would cover all of them.
Oct 23, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
NEC Electra Elite DTU 16D-2
Are you trying to program speed dials into the phone?
May 29, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
Electrical Supplies Logo
1,408 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
