Question about GE 13GP243 TV
Flashing green light and black screen
I have a 15 year old Toshiba TV. The problem began with a horizontal line across the bottom of the picture. Then, on occasions, the picture would go completely blank with a black screen as if it had been turned off (although this only happened to the digital Sky picture; terrestrial was ok). Shortly after, the Sky picture would return. Then what I believe to be vertical sweep problems occurred: the picture would compress, be ok for a while, compress again and so on. I tried to turn the tv on today but all that happens is a flashing green light directly underneath the red standby light. Interestingly, with the tv turned off by the remote control and with the tv in standby, the green light flashes slowly. If I turn the tv on with the remote control, the green light flashes more quickly. I have no picture at all. Do I need to scrap it? It is a great tv and has fabulous sound.
    Top Expert:
  • GE Master
  • 75,774 Answers
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Type in this key phrase " my service table today " in the search box at the top right of the the home page, to get gathered some pages which has the details of practical experiences of the author of that site. The search result might display about 20 Nos of related posts. Press the "All posts" at the bottom of the list, then you can select them one by one.
Posted on Mar 13, 2017
techman
  • 3130 Answers
SOURCE: GE 46GW945
Your problem is a bad main filter, a regulator IC ,and or a combination of a convergence problem along with a vertical IC going bad. This set is not something you should mess with unless your a trained tech. Please seek a pro to assist you with this repair. good Luck
Posted on Jul 28, 2006
bkvinr
  • 76 Answers
SOURCE: Black horizontal lines across bottom 1/3 of screen
This is due to vertical section failure. Change the vertical supply rectifier diode and supply filters. Then check zener diode leakage in pumpup circuit section. Also check any electrolytic capacitors leakage in vertical section. If it is old model tv change vertical height, vertical lenearity presets also. I hope given details useful to you.
Posted on Aug 23, 2007
  • 556 Answers
SOURCE: Picture too wide for screen
your problem is called blooming as you might be aware of very high voltage in tv. you can check 1 high output voltage fron power supply. 2 if it is ok then the problem is in horizontal section.you can check cap.in hor. section at last flyback transformer. hope this will help.
Posted on Oct 01, 2007
SOURCE: 52'' GE Projection TV will not turn on
Called a service technician. Found bad board and wanted $437.00 I bought a new TV
Posted on Nov 13, 2008
  • 42 Answers
SOURCE: No Picture
i do know that this unit which i have also if you plug the tv up and turn it on several times it will reset the tape drive and take out all slack on the tape and it will then eject the tape then clean the tape path after you get tape out tv should return to normal but tape unit must be cleaned are the sensor mabe going bad like the end sensor and so forth etc..
Posted on Dec 17, 2008
My Sony Bravia KDL 40WL 135 TV has been flashing strange colors for awhile; today screen is black with a thin blue line across the bottom. No sound. Any help appreciated.
The vertical output section circuit has the fault. Contact any experienced service technician. This is not a user repairable fault.
Aug 10, 2012 | Sony Televison & Video
For several months we would get bands of lines across our screen. We thought we were experiencing some kind of outside interference as it would come and go. Two days ago the bands began to cover most of...
You're verical output IC is dead, this might because of a leaky capacitor on that section which causes the lines across the screen.
The processor shuts down the unit automatically to avoid further damage to your tube.
Send it to repair shop to isolate the problem. This is fixable.
Thanks for using fixya.
Jan 18, 2011 | Hitachi Televison & Video
I've had my Toshiba 46RV530U less than 2 years,
Diana, did you ever find a solution? My Toshiba (same model) is about 2 years old and it started getting these 4 horizontal lines spaced pretty far apart and a double image at bottom. When I lightly tap the top of the TV, they went away. But now that is not working. Please let me know. Thanks.
Jeff
May 15, 2010 | Toshiba REGZA 46RV530U LCD TV
Toshiba 36A50 sound, light line horizonally on black screen
It is my guess that you have some intermitent solder connections in the Vertical output circuit.
Hope this helps,
Skyassoc
Jun 23, 2009 | Toshiba 36A40 36" TV
Single green line spanning across the screen horizontally
I was just watching TV and all of a sudden the screen minimized down to a single green line spanning across the screen horizontally. The label in the back says it was made in 1996 so it is an old tv. Can anyone help?
Apr 08, 2009 | Mitsubishi CS-27205 TV
No picture only sound, Toshiba 36A 36" TV tube type
my friend if you open the tv carefully look to see if the tube itself has light, or if you have high voltage i coulbe many different things.wish luck!!
caypianan@yahoo.com
Aug 10, 2008 | Toshiba 36A50 36" TV
Toshiba 27D46 Black Screen - White Horizontal Line
I fixed the problem by taking it to a repair shop
Apr 24, 2008 | Toshiba 27D46 27" TV
Fault on TV
something fried .. sounds like the vertical has gone ,
call a tech.
Mar 07, 2008 | Televison & Video
Lines in picture
I had this problem around the time my TV was 3 years old. I ended up having to get it repaired at a TV repair place, it cost me $375.
Sep 24, 2007 | Toshiba 57H83 57" Rear Projection HDTV
GE 13GP243 TV Logo
167 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
