Question about Raymarine RL70CRC GPS Receiver
Where can I get a plug for a raymarine rd 218 radar quickly? I broke the eight wire plug on the cable that connects inside the radar.
  • 43 Answers
Raymarinedealer or Service you can buy only the plug
Posted on Oct 22, 2009
Testimonial: "You are 100% right. Many people are under the impression that you can't get just the plug. I found the plug by calling Raymarine parts directly."
    Scholar:
  • 76 Answers
That plug is not sold as a seperate part. You will need to purchase a new radar cable. Maybe you can lucky on ebay.
Posted on Sep 09, 2009
How to hookup RL70CRC to boat wired for C70
There are 5 wires running out of the antenna and the 5 wires that you need to connect.
Oct 30, 2008 | Raymarine Computers & Internet
Need to reconnect a c-80 system. I think the MFD, radar, GPS, and depthsounder are connected via Seatalk
I think your best bet here would be to post your query on the Raymarine forum.
There are actual technicians over there to look after you.
http://forum.raymarine.com/
Hope this helps you out.
Aug 01, 2017 | Raymarine C80 GPS Receiver
Hi, I have a new C80 that came in a pre-packaged system with a dome, cables etc. My service department at the marina installed the system. When we power up the radar...no image, power is good, dome is...
Sounds to me like the wiring is not quite right, as though a ground is not properly grounded. It should not be grounded to the battery. Check out the picture of the install below and verify your connections.
http://www.raymarine.com/raymarine/SubmittedFiles/rs125/rs125_legacy_connections.gif
May 15, 2011 | GPS
Connect Ratheon RL 70 to Raymarine E80
The two devices can share Nav data only. No radar, Sonar or Chart will be shared.
Hook the RL70 and the E80 together on SeaTalk and all data will be shared both ways. Alternatively, it could be done with NMEA 0183, which is directional, or you could also translate the RL70 data to NMEA 2000 and share it that way. As long as you have all Raymarine equipment, you are home free using a three wire Seatalk connection, with only two hooked up, Yellow and Bare, color to color.
Remember, this will share Nav Data only.
Nov 14, 2009 | Raymarine C80 GPS Receiver
Need to connect NMEA0183 to radio
Thank you for your quick respond.
I downloaded the owners manual and it had all the informaion I needed.
May 24, 2009 | Magellan GPS 320 GPS Receiver
Antenna not rotating
It sounds like voltage loss could be your issue. You need to find the "Y" cable under the dashboard and measure the voltage at the point where it connects to the main 12V supply. Keep the meter on and then spin up the radar. If there is a fuse (there should be) make sure you are measuring on the radar side of the fuse. If the voltage drops off as the radar slows, you have found your problem. If the voltage stays constant and the connections are sound at the terminations in the radar pedestal, I would recommend you send the pedestal in to Raymarine.
May 11, 2009 | Boating
Scanner self test result...is display comms/fail /raymarine c80 18" dome
Chances are that your scanner cable may be bad. Check inside the dome and make sure that the little wires going into the black connector from the radar cable are seated correctly and all the way in. This can cause tons of problems. Also check to make sure that your pins in the back of you unit are not corroded or broken off.
Jul 24, 2008 | Raymarine C80 GPS Receiver
Raymarine G series radar
Your problem is likely noise from the motor. Modern diesels use high speed networks, so it could be interference. Next likelihood would be a software issue. Is the diesel set up to display info on the G display?
Solution could be re routing cables, grounding or un grounding devices. First step is to send your processor to Raymarine, sorry, necessary step to eliminate hardware failure. This is a tough symptom, so do the easy stuff first.
Jun 16, 2008 | Raymarine C80 GPS Receiver
Raymarine RL70CRC GPS Receiver Logo
201 people viewed this question
Top Raymarine GPS Experts
Steve
Steve
Jon Piercy
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
