Question about Kenmore Refrigerators
I have a Kenmore 363.50627000 serial 01326082 and there is an awful smell coming from it and its dripping etc. I don't know where the drain pan is I have taken the back cardboard piece off and vacumed out the dust man was that fun. I guess I need to do that more frequently. Where is the drain pain and how do I get it out and clean it this was a gift to me 3 yrs ago so I have not done any manit. except the vacuming of that back piece of cardboard
  • 8 Answers
SOURCE: kenmore side by side model 596.55662500
have you tried pouring bleach water through the drains in the fridge?
Posted on Nov 08, 2007
CRTN
  • 716 Answers
SOURCE: terrible smell coming from bottom of unit
There Should Be A Grill On The Front Bottom Below The Door. Remove That And It Should Come Out Of The Right Side.
Posted on Jan 05, 2009
  • 72 Answers
SOURCE: Kenmore top freezer fishy smell
if it has an icemaker attached, this may cause your problem. to get rid of the fishy smell, get a box of baking soda, open it a little, and stick it somewhere in your freezer. this will help to filter the air and make it fresher. Also some vegetables can cause this noxious smell, especially if cooked then frozen or if a box or bag of bad frozen vegetables has been stored in the freezer. Our freezer recently had a problem with the icemaker making it smell musty, like after a rain, wet dirt, and I have yet to find a real solution to this problem other than baking soda.
Posted on Jun 15, 2009
  • 2976 Answers
SOURCE: I have a smell coming from the fan in my
The coils under the fridge gather dust. When it gets wet it stinks. A brush & vacuum cleaner usually works.
Posted on Jul 31, 2009
  • 83 Answers
SOURCE: The Vacum condenser light comes on. I vacumed the
Hi there
There are a few of possibilities
Switch off and unplug before trying these.
1. You may not have got all the dust out of the condenser, sometimes you need to shine a torch through from the back and see if all the fins are clean, if not then a soft brush can be used with the vacuum cleaner to remove the rest of the dust.
2. There is a small temperature sensor either just behind the condenser or sometimes pushed in between the fins, this may have dust on it or it may be faulty. If it's faulty and you are competent with electrics it is fairly easy to change.
3. Is there a fan at the back of the condenser, and if so does it work. Again if it is not working its easy to change if you are competent.
However if you are not happy with electrics then you will need your local reputable service guy
Regards
Gordon
Posted on Apr 17, 2011
Testimonial: "Good advice"
My water filter was not clicked in all the way so water leaked and filled up the drip pan under the refrigerator and started leaking out onto my floor before I noticed anything was wrong. I put the water...
Hello Terri,
The pan there is for the defrost water that drains into it durning the defrost cycle,that water eveperates automatically so this water too will evaperate as well may take a bit longer since its more but it will evaperate. Also as you know there is no way to remove that pan,but tomorrow it will be empty anyway
Gene
Aug 08, 2011 | Kenmore Side by Side Refrigerator
Terrible foul ordor coming from air conditioner
Two things may be causing this. A dirty air intake filter and/or the drip pan is not draining as it should.
Remove the front air intake filter and clean it, if necessary.
While the front is Off and the filter is removed, look at the drip pan under the mechanicals. If you see water standing, the unit is not draining as it should. This can be the result of the drain hole near the rear of the drain pan being clogged and/of not enough downward tilt on the rear of the unit. The general rule of thumb is 1/4" to 1/2" of downward tilt. Finding the drain hole can be a challenge, as the clog can blend in with the drain hole. Be patient and persistent in locating it. A pipe cleaner works well to clear the hole.
If none of the above applies, look for dark stains in the drip pan. These stains could be mold. In which case, add a couple of drops of bleach to the water in the drain pan. It may smell like bleach for a while, until the water dilutes it and drains it and the mold away.
Hope this helped you and thanks for choosing FixYa.
Aug 07, 2011 | Kenmore 75121 Thru-Wall/Window Air...
Foul smell coming from behind the refrigerator. I smell it coming through the fan on the back of the refrigerator. I believe it could be the drip pan, but I don't know where it is located. Also, my...
the drip pan is usually on top of the compressor or has a draw underneath with a coil to create heat for evaporation of water from the drip pan. Some time a rodent can drown in this location.
Jul 17, 2017 | Whirlpool GB2SHDXP Bottom Freezer...
How to get a smell out of a hotpoint fridge.we try bread soda.what else can we use
You may have had something drip and somehow get under the fridge. I know blood dripping from meat will smell. It could have dripped down through the defrost drain tube to the pan underneath. You can access the pan from the rear by removing the cardboard cover. If the smell seems to be coming from the pan, it's difficult to remove so I would just pour some bleach in it to kill any smell and you may can wipe it out from there. The drain tube may also have the smell in it so you can pour some bleach into it from the inside of the freezer at the bottom of the rear panel. You can move the fridge to see if anything is pooled on the floor that might smell.
Feb 02, 2011 | Refrigerators
A horrible smell from underneath 60721. The drain doesn't seem to be clogged. We think turkey drippings spilled and attempting to cleaning the drain and drain pan, but it's difficult. Is there a secret...
The drain pan may be accessible from the back. An equal portion of bleach and water should kill the smell. Make you wear gloves and use a fan to ventilate the area before and after using the bleach solution.
Dec 12, 2010 | Kenmore 60721 Refrigerator
My refrigerator is one year old. There is a bad
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} You may have had something drip and somehow get under the fridge. I know blood dripping from meat will smell. It could have dripped down through the defrost drain tube to the pan underneath. You can access the pan from the rear by removing the cardboard cover. If the smell seems to be coming from the pan, it's difficult to remove so I would just pour some bleach in it to kill any smell and you may can wipe it out from there. The drain tube may also have the smell in it so you can pour some bleach into it from the inside of the freezer at the bottom of the rear panel. You can move the fridge to see if anything is pooled on the floor that might smell.
Jan 06, 2010 | Whirlpool Refrigerators
Foul odor from back area of fridge/Kenmore bottom freezer
I had the same problem, but just fixed it. I have a maytag bottom freezer and when the fan blower comes on, there was a foul/stale smell that permeated the kitchen. There is no drip pan that I could remove to clean.
I just removed four screws from the back cover of the fan blower area, reached in with a small cup of organic odor remover and poured it into the drip pan just under the fan blower.
Any odor remover would work. probably vinegar or enzyme odor remover would work, too.
I now have fresh smell when the fan blower comes on.
Jul 03, 2009 | Kenmore 50522 / 50524 Side by Side...
Bad odor coming from drip pan when compressor kicks own[when dry]
I just had the same problem with my kenmore side by side. I have been noticing a nasty smell for the last couple weeks when the fan comes on. My husband just took the whole back of the refrigerator apart and put a flashlight in there. We could see the drip-pan and it was filled with stinky black mold!! It was very hard to remove, but he managed to get it out by taking the lower front (where the filter goes) apart and then he was able to slide out the drip pan and clean it out! Problem solved.....but Kenmore should really make the drip pan more accessable!
Apr 12, 2009 | Frigidaire FRS26ZSG
Foul odor
Yes ,there is a condensate drain pan in the compressor compartment under your unit.
You should be able to get to it from the rear of the unit, by remove several screws.
Use caution and unplug unit before attempting any repair.
The pan can be cleaned out with warm soapy water.
Nov 01, 2008 | LG LSC26905TT Side by Side Refrigerator
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
