Question about Refrigerators
Frig just cool freezer cold
Freezer about 10 -15 deg frig is around 50 i unpluged it for 2 days pluged back in same thing . I took off back cover to the evaporator there was some ice but the fan wasn't running shouldn't it be ?Is this my problem?
  • 159 Answers
That can be your problem
Posted on Jun 17, 2009
Freezer only gets down to around 18 degrees but fridge is fine. No frost on the freezer evaporator fan is running
Modern consumer refrigerators only have coils in the freezer. In the lower back of the freezer there is a small fan and possible a damper (flap that opens/closes) to push cold air from the freezer to the refrigerator. Given that the freezer is 18 deg, it's probably cold enough to keep the fridge area at typically 34 deg.
So the cooling system (compressor, coils, thermostat) are not working properly to keep the freezer at, typically 0 deg. Possible causes: partial loss of refrigerant gas, icing around evaporator coils (in freezer), compressor failing, dust clogging condenser coils (under fridge), condenser fan clogged or broken (under fridge), thermostat failure.
I'd start with condenser. Remove the slotted trim at the bottom front and look in with a flashlight. Are the coils clean? Pull out the fridge and remove the lower back cover (usually cardboard). You can now see the coils and fan. Clean and blow them out.
If it's icing, it probably means freezer door not closing tight. If auto-defrost not working properly it would probably get worse over the period of a few days so not likely.
Apr 21, 2016 | Frost Refrigerators
My kenmore refrig (freezer on top) has started dripping from tube near temp control inside of frig. I think it might be related that one month ago - electric was off since not at apt for one month. Doors...
Your defroster inside the fridge may not be doing a good enough job to keep the drain from freezing up. Check to see if the drain pan is frozen over in the freezer section. I took the cover off the inside of the freezer and wrapped a piece of uninsulated 14 gauge solid copper wire around the heating element and pushed one end down the inside of the drain tube and wrapped the other end around the heating element. No problems since.
Aug 16, 2013 | Kenmore Sewing Machines
My GE refrigerator GE GSL25JFPABS stopped cooling on both the frig and freezer sides. I pulled it out, took off the panel and cleaned around the fan. I plugged it in and it worked perfectly for just less...
you may have a defrost problem, check for frost in freezer, back wall, or pull off rear panel and check evaporator, it should have some frost on coils, if frozen all around evaporator, check glass element at bottom of evaporator, should have blue and pink wire going to element
Aug 22, 2010 | Refrigerators
My refrigerator stopped cooling and my freezer stopped freezing but the freezer is still cooling
Same thing with our GE Eterna Series - off and on for the last two weeks. Took back panel off, looked around, vacuumed dust build up off of the fan blades, etc.; everything worked fine for five good days. Then frig went out stopped cooling. Off and on for the last week. Unplugging it works for a day then back to not freezing and or colling.
Jul 17, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Frig won't cool RM2652
You'll need to get in touch with the store you bought it from but Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Jun 26, 2010 | Dometic RM2652 Refrigerator
I have a 690 subzero refrig that runs almost continually and temps jump around from 38-46..any ideas
I had the vacuum condenser message on my sub zero for about five years. I vacuumed it every six months (as per the owners manual) and the message would go out for about a day and then come back. I figured it was just a bad code.
Recently, my frigerator temp went from the normal 38 to 40 deg F to about 53 to 55 deg F. My freezer temperature was normal (0 deg to -2 deg F). My unit is under warranty (parts only) -- Model 560 -- so I called an authorized service company. They found that my evaporator coil was bad and replaced. I had to pay for labor and freon so my bill was about $300.
Since then -- my warning message is gone and my frig temp is at 38 deg F. Constant. No waivering.
So - for those of you with a Sub Zero with a wandering frig temp and with the "vacuum condenser" message on all the time -- I am suggesting that you get service out to look at it immedately. More than likely -- you have a freon leak and the frig cooling is insufficient leading to the error message ("vacuum condenser"). I am guessing that my frig was running all the time leading to a higher electric bill (potentially -- an extra $10 - $15/month * 12 months * 5 years of owning the house = $600 - $900 of money thrown out the window.
Hope this helps!
Ron
Mar 31, 2010 | Refrigerators
GFI Trips when pluged in.
Hi, Are you unplugging the big black hard wire that goes under the evaporator coil in the freezer. If so, that is the defrost heater and it has gone bad. Please let me know if I can explain anything further.
Thanks
Vic
May 20, 2009 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Fridge is not cooling on my Maytag MSD2756GES
Check thermostat and fan switch. If not same thing need changeagain
Sep 04, 2017 | Master Bilt Indoor Step In Cooler 70""W x...
Refrigerator odor
hi there,
the bad odour could be from the compressor, evaporator or heat exchanger. can you supply the complete model # please?
thanks.
Sep 25, 2008 | Whirlpool Refrigerators
Kenmore 596-76512 fridge not cooling freezer seems to be working still
If the fan above the evaporator coils in back of the cover isn't running then no cold air will be blown up to the fridge area. That's a common failure item and very easy to replace yourself. And by the way... $200 bucks and 2 weeks out is about normal these days believe it or not. It's what we would charge ya! :) At least you did the troubleshooting and saved yourself a couple hundred bucks.
Jan 14, 2007 | Kenmore 71812 / 71814 / 71819 Bottom...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
