Question about HP Officejet Pro L7680 All-In-One Printer
The top feeder of my printer is not allowing papers to go through
The papers get stuck so I can't print. What do I do? Thanks.
    President:
  • 3,085 Answers
Pull the feeder up to open and look for obstructions. Clean the roller and pad with isopropyl alcohol.
Posted on Jun 16, 2009
SAYS IT IS OUT OF PAPER WHEN IT ISNT AND WONT PRINT
I have the same problem with a Kodak printer I have. I sometimes have to put more paper in or take some paper out to get it to print. It looked to me like the feeder roller was messed up.
I am going to get a new printer as soon as the ink in this one is used up.
Mar 06, 2015 | Office Equipment & Supplies
My printer will not accept photo quality paper
The printer should accpet every paper only requires adjusting the feeder area fo every new brand paper that is inserted on device. Inspect the devices feeder compartment for appropiate size requested of the paper. Also, the printing paper has size adjustment details required to fit into the printer. Once observed, the feeder compartment would require manually adjusting to fit new paper size to achieve printerbility. Also, power on the computer to test print the new adjustments. The printer commnads too allows to sleect the appropiate shapes requested considerign the type of pape inserted in feeder comparments. Circumspectively, perform printer feeder compartment adjustments and test print a page to ascertain the most possible condition ot the new settings.
Feb 04, 2011 | HP PSC 1410 All-In-One InkJet Printer
Paper feeder stuck
If the paper feeder stuck, do the following:
  1. Gently pull any jammed paper out from the output tray or sheet feeder.
  2. If paper is stuck inside, open the printer cover and remove the jammed paper, including any torn pieces. Then close the printer cover.
  3. If paper remains near the sheet feeder, press the paper feed roller lever inside the paper feeder to release the jammed paper, then carefully pull it out.
  4. Load the paper correctly.
  5. Press the cp_button_14.gif stop button to resume printing.
  • If the printer continues to jam or misfeed paper, and you are certain that there are no foreign objects lodged down inside the paper feed area, your printer may require service. Please call Epson technical support for further assistance.
  • Jan 29, 2011 | Epson Office Equipment & Supplies
    Put new roll in printer and paper feeds through then goes back out again
    The printer should accept print paper ready for feed commands when computer sends jobs with clicks. A paper feeder tray may be clogged, attempt to open compartments to ascertain for misaligned or adjusted entrapment areas. Paper feeder adjustments that are tightened least allows feeder processing while loosened paper feeder clips allows several print papers at a time. Select the appropriate adjustment for the papers. Second, printers that run out of ink display sensitive malfunctions either as inability to feed paper when available. Ascertain that printer ink is available.
    Jan 28, 2011 | HP PhotoSmart 130 InkJet Printer
    Paper stuck in printer,can't get it out.
    (1) Slowly pull the paper out, either from the paper source or from the Paper Output Slot, whichever is easier.
    (A) When printing from the Auto Sheet Feeder
    (B) When printing from the Front Feeder
    bullet_s.gif If the paper tears and a piece remains inside the machine, open the Scanning Unit (Printer Cover) and remove it.
    After removing all paper, close the Scanning Unit (Printer Cover), turn the machine off, and turn it back on.
    * Be careful not to touch the components inside the machine.
    bullet_s.gif If you cannot pull the paper out, turn the machine off and turn it back on. The paper will be ejected automatically.
    (2) Reload the paper in the machine, and press the OK button on the machine.
    If you turned off the machine in step 1, all print jobs in queue are canceled. Reprint if necessary.
    May 17, 2010 | Canon PIXMA MX320 Color USB InkJet Printer
    I am printing several pages and there is a jam. I
    It will re-print it after you clear the jam. Just pull it out pulling slowly and evenly and it will come out.Also you can see directions on HP.com. Steven 818-888-0006
    Mar 06, 2010 | HP LaserJet 3055 All-In-One Printer
    Paper jamming problems with HP DeskJet F380 All-In-One Printer . The paper feeds into the paper feeder but then it seems to get off line and the paper get stuck and actually tears in the feeder. The...
    Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
    Keep printer unplugged for about 2 minutes and replug and try a test print.
    Also make sure that you have waited long enough for the printer to heat up before giving a print job.
    Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
    Hope that helps!
    Thanks
    Newton
    Aug 29, 2009 | HP DeskJet F380 All-In-One Printer
    Paper is jam on the top feeder of Dell 1110
    There is a section in the user guide that shows how to remove and avoid paper jams on this unit:
    Click on the user guide link .
    http://www.generalmanual.com/Printers/Dell-1110-Laser-Printer.htm
    Printer paper jams can be caused from:
    Paper that is sticking to-gether - fan your paper from both ends and both surfaces before placing it into the printer
    Paper tends to absorb moisture in high humidity - this can also cause it to stick and jam.
    Always store your paper flat - many printers jam readily when supplied with bent or slightly damaged paper.
    There could be a piece of paper stuck in the printer from a previous jam - especially if you have printed labels - it only takes one tiny corner of a label to cause paper jams in any printer - cheap consumer models to commercial models costing thousands of dollars.
    Click on this link or copy and paste the complete link into your browser.
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks, Joe
    I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
    Apr 23, 2009 | Office Equipment & Supplies
    My HP printer paper get stuck in top feeder whenever I try to fax
    Lift the cover to the ADF (Automatic Document Feeder) and remove any paper debris from the rollers. Also, clean the rollers with a very damp cloth and a dab od dish washing detergent.
    Also, check to see that the spring loaded lever is in place.
    Clear the jam from the automatic document feeder (ADF)
    1. Make sure the product is turned off and the power cord is unplugged.
    2. Grasp the upper edge of the automatic document feeder (ADF) assembly and open it.
    3. Raise the roller assembly.
    4. Gently remove any jammed paper from the ADF.
    5. Lower the roller assembly.
    6. Close the ADF assembly.
    7. Plug the power cord back into the product.
    8. Press the Power button (c01346625.gif ) to turn the product on.
    9. Try the print job again.
    Thanks, Joe
    Feb 01, 2009 | HP OfficeJet 6110 All-In-One InkJet...
    Lexmark x7550 Printer, Scanner, Fax - Clicking Noise Question
    top feeder for the scanner (on my x6570) had a loose piece of rubber stuck between the feed wheels. The rubber is part of the guiding mechanism that guides the paper to the feed wheels. Remove rubber strip and reattach it where it belongs.
    Feb 19, 2008 | Office Equipment & Supplies
    HP Officejet Pro L7680 All-In-One Printer Logo
    mukhtar21 shaikh
    mukhtar21 shaikh
