Question about Dymo LabelWriter 400 Turbo Thermal Printer
This is the error message when openning the Dymo Software on Server 2008. We have openned this same softare successfully on other 2008 Severs. Exception EPrinter in module Labels.DLL at 0000643E6
  • 130 Answers
http://global.dymo.com/enGB/Troubleshooting/LabelWriter_320.html
From this site.
    • The error message: "Exception Eprinter in module LABELS.DLL at ...." is displayed.
      or
      The error message: "Access violation at address ... in module DYMOLBL.EXE" is displayedA. This problem can occur when DLS 7.x was installed over DLS 6.x, without first uninstalling DLS 6.x.
      Solution:
      Delete the file Dymolbl.ENG.
      DLS will still work, however, all default settings will be incorrect.
      The settings will need to be set correctly.
      On the DLS menubar, click Preferences and set the preferences as desired.
      The default values are:
      Default label file folder should be set to "C:\Documents and Settings\All Users\Shared Documents\DYMO Label\Label Files"
      Default address book folder should be set to "C:\Documents and Settings\All Users\Shared Documents\DYMO Label\Address Books"
      Default clipart folder should be set to "C:\Documents and Settings\All Users\Shared Documents\DYMO Label\Clipart"
      B. An incorrect printer has been selected in the DYMO software.
      Solution:
      1. Start the DYMO Software.
      2. Click on File and point to Change printer.
      3. Click the LabelWriter model connected to the PC (e.g. Dymo Turbo)
      C. Occasionally, double-clicking the print command button in the list manager is not handled properly by the software.
      Solution:
      Single-click the print command button.
      D. An incorrect driver has been installed.
      Solution:
      Run the DYMO Driver Uninstaller
      Restart the PC and install the correct driver.
      To remove and reinstall the printer driver:
      1. On the Windows taskbar, click Start, point to Settings and click Printers (& Faxes).
      The printers window is displayed.
      2. Double-click the LabelWriter icon and delete any documents waiting to be printed.
      3. Close all programs.
      4. On the Windows taskbar, right-click on Start and click Explore.
      Windows Explorer is started.
      5. Double-click the file C:/Program Files/DYMO Label/Support Files/LW Remove.exe
      6. Unplug the LabelWriter's USB connection from the back of pc and click OK.
      7. Choose Select all and then remove.
      Once the driver has disappeared from the printers dialog box, click Close.
      Restart the PC.
      8. When Windows has restarted, on the Windows taskbar, click Start, point to Programs, point to DYMO Label and click Uninstall DYMO Label.
      9. Reconnect the LabelWriter to the computer and reinstall both driver and software.
Posted on Jun 16, 2009
How to Change SQL Server 2005/2008 User Password
There is one SQL password recovery tool, SQL Password Genius, which would help you to successfully change SQL Server 2005/2008/2012 user password instantly, especially when you couldn't think of other ways for it.
1. Open SQL Server Configuration Management and stop SQL Server Services.
2. Install SQL Password Genius full version and run it on computer.
3. Click "Open File" button to import master.mdf database file into this recovery tool.
4. Select user in list and click "Reset" button.
Instantly, new user password would be available for SQL Server logon after you type new password for user.
Now, SQL Server user password has been changed and you can login into SAL server now. But please remember to restart SQL Server Services before you access to SQL Server with user password.
Jul 04, 2014 | Microsoft SQL Server 2008 Enterprise Full...
My server is not configuring the settings and its not opening.its opening. it is displaying the error message '2147217900 in (module mode)mode - server.:sub Get server setting (line#:40) while running...
ok I solved your problem
1st you DB
2nd open the Backup
3rd open the Startup File
and Copy 1st file and past to C:\Program Files\CyberCafePro Server\DB
and Rename (oneroofccp)
I hope ur problem will Solve... Thanks..
Nov 26, 2013 | OneRoof CyberCafePro Main Control Station
Paper "30252 address" is not supported
Here is the fix for Win7 provided by Dymo tech support:
1. goto Devices and Printers
2. select Dymo Label Writer
3. On the top where you see Print Server Properties, open it and find "30252 address"
4. delete "30252"
5. delete Dymo Label Writer printer
6. disconnect USB cable and then power to Dymo printer
7. connect power and then USB cable back to Dymo printer
8. reboot PC
9. try printing label again.
Jan 31, 2013 | Dymo LabelWriter Thermal Printer
My server not configuring its settings
My server is not configuring the settings and its not opening.its opening. it is displaying the error message '2147217900 in (module mode)mode - server.:sub Get server setting (line#:40) while running ccpsrv.exe v 5.00(Build 250)
Aug 31, 2012 | OneRoof CyberCafePro Main Control Station
I have some problems with SSH, here the info that i could get from the appliance: SA-Firewall# Device ssh opened successfully. SSH0: SSH client: IP = '172.17.200.32' interface # = 2 SSH: host key...
What version of software are you running? I have noticed issue with ssh on version 8.2(3) and below.
You can try to remove all ssh access and then add it back. Also you can try zeroizing and regenerating the crypto key.
Dec 13, 2010 | Cisco ASA 5520 Firewall
When I try to open 'My Comupter' from the desktop or anywhere else for the matter I get the message Windows Explorer has stopped working, and two options 1. Check online for a solution and restart the...
Easiest way to fix that problem is to save all your important files onto an external hard drive and reformat the hard drive, otherwise you will be trying to correct this with Antivirus programs and other junk that will only cover up the error message. Alot of times it is easier to format and reinstall the operating system than try to figure out tose error codes, and windows never gets their stuff right.
Good luck.
Jun 12, 2010 | Microsoft Windows Server 2008 Enterprise...
OUR DYMO LABELWRITER TWIN TURBO JUST STOPPED PRINTING--
OK! The first time you tried to print ON THE LEFT SIDE, without anymore labels there, there was a "pending" error message in the print queue. This typically cuts off all furtther printing, as all subsequent requests are "behind" it in order or priority.
To fix this, open the Dymo Labelwriter "Printer" dialog box (double-click it on the tray or go to "start / control panel / printer and faxes" - then double-click on "DYMO LabelWriter Twin Turbo". Once open, you'll see a list of "failed" print requests. Somewhere in there you'll find the one with the "laserwriter output" out of paper message. Select that and cancel or delete it.
If this was the problem, all your attempts will now print (make sure you have enough postage paper in, and you'll have extras you can use, I'm sure!
Hope this helps.
Jun 17, 2009 | Dymo LabelWriter Thermal Printer
Tally 7.2 problem
We surrendered license for changing SERVER . But could not get the license number to the new server. But message box of the tally wrote as license activate successfully. But now we want to operate to old server. But the message box written “ surrender license and try again”. We will be very thankful if you solve our problem.
Apr 23, 2009 | Computers & Internet
I typing orkut.com & it is not opening
just restart the machine and then try
Nov 19, 2008 | Computers & Internet
Dymo LabelWriter 400 Turbo Thermal Printer Logo
1,804 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Marvin
Marvin
Jose Pino
Jax Planet
Jax Planet
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
