Question about HP Officejet Pro L7680 All-In-One Printer
Papers get stuck
My top feeder is not working. The papers get stuck.
  • 50 Answers
Clean the feeder rollers with WD-40
Posted on Jun 16, 2009
Paper feeder not working
something could have fallen into the printer and gotten stuck (affecting input paper sensor)
Sep 17, 2015 | Canon PIXMA MX452 Wireless Office All In...
How do I get a stuck piece of paper out of top feeder?
the top feeder is supposed to be able to open giving you complete access to the workings of the top feeder
and also when removing the paper work gently, and check to see if you removed the complete page and that a piece hasn`t torn off and is still stuck inside
Mar 04, 2014 | HP Officejet Pro 8600
Paper transport works not properly, 3 flashes orange LED
First make sure the printers well connected and the power supply properly plugged.
  • Remove any previously loaded paper.
  • Check out the printers Auto sheet feeder/front feeder for any paper jams and remove manually any visible stuck papers.
  • Turn the printer off and on.This also helps in automatically removing any stuck papers that may not be manually removed.
  • Make sure there is no foreign objects in the Auto sheet feeder.
  • Make sure you load a fair amount of plain papers in the feeder,that is,reduce by half the amount you feed into the feeder.
  • In case the printers rear cover had been removed,fit it properly by pressing it firmly until it fully fits into the rear of the printer.
Hope this helps.Thanks!
Please rate this answer.
Oct 26, 2011 | Canon PIXMA iP3300 InkJet Photo Printer
Paper feeder stuck
If the paper feeder stuck, do the following:
  1. Gently pull any jammed paper out from the output tray or sheet feeder.
  2. If paper is stuck inside, open the printer cover and remove the jammed paper, including any torn pieces. Then close the printer cover.
  3. If paper remains near the sheet feeder, press the paper feed roller lever inside the paper feeder to release the jammed paper, then carefully pull it out.
  4. Load the paper correctly.
  5. Press the cp_button_14.gif stop button to resume printing.
  • If the printer continues to jam or misfeed paper, and you are certain that there are no foreign objects lodged down inside the paper feed area, your printer may require service. Please call Epson technical support for further assistance.
  • Jan 29, 2011 | Epson Office Equipment & Supplies
    Canon MP730 Paper feed is not working correctly.....keeps jamming and feeds the paper incorrectly
    There are two feeders on this MP730. There is the sheet feeder on top and there is the paper feeder on the back. You can have problems with both.
    The sheet feeder on top.
    If the problem is things go through somewhat sideways, and if this is the problem, stuff some postit notes between the back grey thing and the feeder tray to eliminate this problem. Add or subtract to the wad to make it right.
    If the problem is it does not grip the sheet, what I used to do is to help it through by one sheet at a time, painful. I got frustrated with this so for scanning, I have a Snap Scan 1500, which is faster and better.
    The paper feeder.
    A small piece of paper left in the paper infeed path can cause a major problem. You cannot have anything in the paper path that will skew the paper, so you must get any little bit of restriction out of there.
    As the printer gets older, you will have to produce your own guides to prevent this skewing, as the guides on the printer do not do this well. I use clamps and wooden guides to keep things in line.
    May 25, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
    My printer says "close document feeder cover". I don't know where this is
    It is talking about the flap that is on the very top just above where one puts in an original to auto feed on to the glass, this access cover is required to be open and closed by the machine because it feels something is holding it open or its switch that tells it such is stuck. Maybe a jam from last original fed into it..
    The cover once open check around for paper fragment and inspect little levers that hang down, one is stuck or there is paper stuck in Document feeder
    I have found that often label bits, paper clips, punch bits and small corners of paper often get in the path, I use a piece of laminate cut so it has a v or a point and feed it in the document feeder, manually inserting it in the direction a piece of paper normal travels in it.
    Push it all the way threw not pulling back (bad for it) to do so poke the point threw, you will need the top cover open and lift off the glass, so you can grap the point and pull the laminate threw.
    Nov 04, 2009 | HP OfficeJet d145 InkJet Printer
    I have a HP laserjet 3055 all in one printer and its giving me the error message that says Doc. feeder Jam. There isnt anything in the printer. How do I fix it.
    The jam it's talking about is in the feeder on top. Check for stuck paper, or a sensor stuck down, in the feeder area on top
    Aug 06, 2009 | LaserJet 3052 All-In-One Printer
    The top feeder of my printer is not allowing papers to go through
    Pull the feeder up to open and look for obstructions. Clean the roller and pad with isopropyl alcohol.
    Jun 16, 2009 | HP Officejet Pro L7680 All-In-One Printer
    My HP printer paper get stuck in top feeder whenever I try to fax
    Lift the cover to the ADF (Automatic Document Feeder) and remove any paper debris from the rollers. Also, clean the rollers with a very damp cloth and a dab od dish washing detergent.
    Also, check to see that the spring loaded lever is in place.
    Clear the jam from the automatic document feeder (ADF)
    1. Make sure the product is turned off and the power cord is unplugged.
    2. Grasp the upper edge of the automatic document feeder (ADF) assembly and open it.
    3. Raise the roller assembly.
    4. Gently remove any jammed paper from the ADF.
    5. Lower the roller assembly.
    6. Close the ADF assembly.
    7. Plug the power cord back into the product.
    8. Press the Power button (c01346625.gif ) to turn the product on.
    9. Try the print job again.
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks, Joe
    I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
    Feb 01, 2009 | HP OfficeJet 6110 All-In-One InkJet...
    Auto-Feeder Does not feed paper evenly
    There must be a small jam in the feeder. You can try sliding a business card or heavier plastic card through the feeder all the way across. Chances are it will push whatever is stuck in there out.
    Jul 04, 2007 | HP OfficeJet 6110 All-In-One InkJet...
    HP Officejet Pro L7680 All-In-One Printer Logo
    80 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
