Question about E-Machines eMachines Desktop PC
I have similar problem on an eMachines W1500
When I power my pc on, the green light around the power button lights up, I can hear the computer running, but my screen is black. I checked my screen with another computer and it's working fine, I did notice that the yellow light that has a battery symbol above it on my pc is not lighting up, could this be my problem and how do I fix this? also, when I opened my pc up I noticed there's a red, black & white wire that has a 4 pin connector on the end of it is unplugged from somewheres and I don't know where it should be plugged in at. Any advise????
  • bolessd Jun 17, 2009
    I tried your solution, but it didn't work. However, my mom's HP did the same exact thing today. I'm thinking it does have something to do with the power, the fans are kicking on but the pc is not loading. but I'm wondering if it has anything to do with my mom's power outlet because my computer was hooked up at her house when it crashed, and like I said, today, her pc crashed the same way and has the same exact symptoms. Any other advise?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 72 Answers
Thats your powersupply cable. look for a 4pin sloth on your mobo that looks kind of like that switch and plug it in
Posted on Jun 16, 2009
Emachine T2200 power light yellow (not green) fan working computer does not. Any ideas?
yellow normally indicates sleep or hibernate, have you tried to press keys on the keyboard to see if it wakes up? have you tried just pressing the power button once?
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
May 03, 2012 | E-Machines eMachines Desktop PC
I have a 3507 emanchines computer.When I push start button all it does is show green light clicking . Then it will stop and the white light will below will blink 7-8 times. The green light will click about...
sounds like an issue with your motherboard or something like that...try resetting the motherboard by unplugging the power, taking out the battery of the motherboard inside the computer and pressing the power button several times to drain the power. then put the battery back in, plug in the power cord and try to start it up. if it doesnt work then ur gonna have to contact emachines because ur mobo is either defective or broken...
Nov 12, 2009 | eMachines W3507 PC Desktop
Emachine D2880 no power clarification
your getting power to your PSU, via the green light on your mobo.
verify the PSU has a green light(most emachines do)
it sort of sounds stupid but, check the connection of the cable coming from the front of the case(the wires that connect to the mobo to the power button on the outside of the case.
if all else fails, take the pc out of the case.. put all components on a static free bag and start to rebuild your PC(without a case)
...this will rule out a short on the PC case, and faulty wiring from the case...
pretty much sounds like you've been through almost every step except replacing the PSU(you just said you tested/but your getting power to the PSU)
hope some of this helped
Sep 04, 2009 | E-Machines eMachines Desktop PC
No boot, New PS, Green light on MB lights, No Fans running
Bottom line: Either your power supply or (hopefully not) the mother board has gone bad.
Replace power supply (remove old one), take to local independent computer shop, ask them for new unit. Should be around $50.00. - no more. After reinstall, if still no fans, boot, etc. Replace motherboard or buy a new machine. MB's installed probably will run you around $250.00-ish.
Good luck.
gurutim
Mar 21, 2009 | E-Machines eMachines Desktop PC
Problem with emachine m5124 startup
Take the battery out and unplug the power cord. Press down the power button continuously for a solid 30 seconds without stopping. This drains all the power out of the circuits and resets whatever invalid state your computer is in.
Now, leave the battery out but plug in the AC and turn on the laptop. If it works, turn it off again and insert the battery. All should be well.
Jan 25, 2009 | E-Machines eMachines Desktop PC
E-machine 5220 power up
Emachines have notoriously cheap power supplies. Often, while the power supply itself doesn't fail, it causes the failure of motherboard components, essentially trashing the computer.
Try the following:
First check and make absolutely certain that the power switch connector is properly connected to the motherboard. (Take standard grounding/safety precautions: wear a properly-grounded grounding strap, for example, when working with any internal components.)
Obtain a known-good power supply of equal or greater capacity to your eMachines PS and switch 'em out.
If either of these fixes your problem, well and good. If not, the problem may be, as is all too common with eMachines power issues, a motherboard issue caused by the power supply.
Jul 16, 2008 | E-Machines eMachines Desktop PC
I have a emachine model t3958
try to reseat the power cable of the computer and power it on again
Jun 24, 2008 | E-Machines eMachines Desktop PC
Emachine T2984 won't power up
First, Check your ram. If not seated, it will not power up. Also, do you hear a series of beeps or not? Need a better & more exact description of problem and what occurs
Apr 14, 2008 | E-Machines eMachines Refurbished EMA...
Tower
Hello:
Please to check and fix the following:
the ; memory, VGA connecting to the monitor, fix all cable connecting to all hardware inside the system.
the problem most likely is in the memory. please do.
if does'nt work i will give you the step by step troubleshooting of your PC.
eager to hear you soon , best regards, melnavz
Feb 20, 2008 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
115 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
