I would start by entering the bios using the method below. Try running a hardware scan. It sounds like you could just have a hard drive that is going bad.
F2 key method
Turn the computer on. If you see an invitation to press the F2 key to enter Setup, do so. The Setup screen will appear.
Toshiba Hardware utility method
Run the Toshiba Hardware utility from the Toshiba Console. It may also accessible (as 'HWSetup') from the Windows Control Panel. Changes to some of the settings will require re-starting the computer. This method is the only way to access the BIOS settings on some notebook PCs (Satellite 5000 series, for example). (For these machines, pressing and holding the F12 key immediately after powering-on the notebook will allow you to alter the notebook's boot priority.)
If the Toshiba Hardware utility is not present, try the F2 key method and the Esc key method (see below). The Toshiba Hardware utility may be downloaded from the Toshiba support website at
http://support.toshiba.com
If the computer is fully off, and/or to avoid having to re-start it (and Windows), use one or the other of the following two methods. The PC will have to be truly off (not suspended, or in standby mode, or in hibernation mode). If an external keyboard is attached to the notebook (either directly or via a docking station or a port-replicator), disconnect it until you have completed this procedure.
Esc key method
Turn the computer on. If you do not see a prompt to press the F2 key, then immediately press and hold the Esc key for three seconds, and then release it. When prompted to, press the F1 key. The Setup screen will appear.
For Toshiba notebook PCs manufactured before the introduction of Windows XP
One or more of the following methods are appropriate:
HWSetup method
Run the HWSetup utility from the Windows Control Panel. This utility provides a relatively user-friendly way to change the BIOS settings. Changes to some of the settings will require re-starting the PC (and Windows). HWSetup was pre-installed on all but early Toshiba notebook models. If it doesn't appear as a Control Panel applet on your computer, you may be able to download it from the Toshiba Support website as part of the Toshiba Utilities package for your model.
Esc key method
If an external keyboard is attached to the notebook, either directly or via a docking station or a port-replicator, disconnect it. Turn the computer on. Immediately press and hold the Esc key for three seconds, and then release it. When prompted to, press the F1 key. The Setup screen will appear. The PC will have to be truly off (not suspended, or in standby mode, or in hibernation mode) for this method to work.
http://support.toshiba.com/sscontent?docId=98081013
