Question about IBM Infoprint 1145 Laser Printer
Getting service code 914 on a IBM infoprint 1145
We have an IBM infoprint 1145 that occasionally gives a 'service code 914' message. What does this mean and what do we need to do if it shows up again?
Thanks!
Mark
  • 4 Answers
Service code 914 does not exist. If you meant 941, that is a tray 1 lift motor issue.
Posted on Jul 15, 2009
IBM infoprint 1145 replaced fuser for line down page ( bad upper roller )now the printer has 2nd image on 2 half of the page we tured density down helped a little PS this our 3rd fuser
I think is the cartridge,if you say you change the fuser,try to change the cartrdge.The problem that you say in the main part is on the fuser,make sure the fixing film is ok,not spent.
Mar 14, 2011 | IBM Infoprint 1145 Laser Printer
What does 914 Service DC Pick Motor mean?
Printer Error Codes 910,911,912,913 and 914 are indications that a Tray 1 paper feed problem has been detected. It's what i found hope it helps
Sep 28, 2010 | IBM Infoprint 1352 Laser Printer
Infoprint 1145 ''915 Service Fan Error''
915 Fan Error Fuser fan failure
+24VDC CHECK
Measure the voltage at P/J456-1 and FG on the I/O PWB.
Is there +24VDC between J456-1 and FG?
Yes: Replace the “Fuser Fan”
No: Use the Block Diagrams in the printer service manual to troubleshoot a loss of +24VDC
The following printer FRUs and areas are associated with this
specific problem. One or more of these FRUs or areas may
have failed partially or completely. If you cannot isolate this
problem using the steps in this Service Check, replace each
FRU or troubleshoot each area listed below, one at a time, until
you isolate and solve the problem.
• Wiring and connectors linking the FRUs
• I/O PWB
Mar 23, 2010 | IBM Infoprint 1145 Laser Printer
Error message 917.00 service transfer roller. I replacedn the service roller but still the error message comes up.This is from the IBM Infoprint 1552.
A 917 transfer roll error code on all models at service level may
display if an incorrect level HVPS is installed in a printer that has the erase lamp assembly installed.
Check to make sure the correct level HVPS is installed.
Feb 11, 2010 | Office Equipment & Supplies
IBM Infoprint 1532 giving error code 922.14 -service fuser error
There is a heater control problem in the fuser.
The fuser is the assembly of heated rollers in the rear of the device.
The most likely cause is either a blown heater element, or perhaps a faulty temperature sensor.
Usually we fit an exchange fuser assemblt to fix this.
Feb 04, 2010 | IBM Infoprint 1532 Laser Printer
Fuser error on my ibm infoprint color 1464
The error is Fuser cam position not found. Have you tried reseating the fuser? Does the fuser make any loud sounds? Based on the error message, it could either be the fuser, or the system board.
Apr 08, 2009 | IBM Infoprint 1116 Laser Printer
IBM infoprint 932 service printhead error
go on line and type in
ibm infoprint 1352 laser printer error 932
enter
or
ibm 1352 infoprine error message 932
rod
Feb 06, 2009 | IBM Infoprint 1352 Laser Printer
IBM 1352
DC Pick motor error: No Encoder feedback. Try to remove all paper from tray 1 and replace it.
It basically means there is a tray1 paper feed problem.
Oct 14, 2008 | IBM Infoprint 1352 Laser Printer
IBM Infoprint 1512 out of paper message
It could be a problem with the paper feed roller above the tray or a sensor problem.
It should be looked at by a service technician.
Jun 12, 2008 | IBM Infoprint 1512 Laser Printer
Infoprint 1120 929 service toner sensor error code
The problem is caused by one of the following (normally it's the cartridge that's faulty, very common on Lexmark's and IBM Infoprints)
The toner sensor is not operating properly, the developer
drive assembly is not operating properly or the print
cartridge is defective
Jun 09, 2008 | IBM Infoprint 1120 Laser Printer
Open Questions:
See all IBM Infoprint 1145 Laser Printer Questions
IBM Infoprint 1145 Laser Printer Logo
362 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
