Question about HP DesignJet 5500PS InkJet Printer
I would like to have a manual for my plotter that we just bought second hand. No manual came with it i need to have one. Where do i find them?
  • 50 Answers
Go to
http://justmanuals.com/
Posted on Jun 16, 2009
Error code E161-403F
I have had two of my Canon plotters give this error.message, I had to manually move the carriage unit and replace the printhead. On one of the plotters the error message returned, on the second plotter I was able to go into service mode where it asked me to replace the printhead. I just went though the motions since the printhead was brand new and I was able to get the plotter to function correctly.
Mar 05, 2013 | Office Equipment & Supplies
Have bought a second hand DMA Tinto S534 mobility scooter for my father and would appreciate an instruction manual or at least some basic information.
Hi peters_17,
Just bought one of these myself second hand, managed to find this on that t'interweb thingy.
http://www.merits.com.tw/upfiles/news01191893408.pdf
You may not need this anymore, but, could come in useful for someone else.
Regards.
Kevin
Jul 28, 2011 | Health & Beauty
I bought a used HP Design Jet 450 C...But its showing the cartridge and data solid orange light and ready light is constantly green. I brought a new black cartridge, the printer takes in the paper and...
I think the problem is not the computer. You shoud check the plotter by running the test print without the computer. When plotter's power is on, press Setup and Cancel keys simultaneously. If it does not print, then the plotter need repair.
According to your descriptions, there is System Error Code shown on your control panel. when the lights on for Ready+Cartridges+Data (DKL), it may have 9 possible causes referred by Service Manual page 2-7. You can check all these 9 items to see which one causes the problem.
Dec 17, 2010 | HP DesignJet 450c InkJet Printer
Cannot find user manual for Bernina Industrial sewing machine-just bought it second hand.
Hi. Try http://www.berninausa.com/default-sUS.html. If you enter 'manuals' in the search field, it will give you a list of manuals that are no longer in print. Since you said you bought your machine second-hand, it is likely (but I'm not guaranteening it!) that the manual isn't in printl
Let me know if this works, ok?
Happy Sewing!
Robbie
Mar 17, 2010 | Bernina Sewing Machines
Need to change Y-axis belt on 650C Plotter. I
Try www.smpcshop.com they have many service manuals, from $9.95 to $19.95 to download.
Nov 27, 2009 | Office Equipment & Supplies
1. PEN NOT LIFTING. HOW DO I ADJUST PEN LIFT 2.PAPER SKEWS TO LEFT 3. NEED SERVICE MANUAL ON SUMMAGRAPHICS PLOTTER HI7200
Installing Pens
Most types of disposable pens must be activated before using the for the first time. If you are installing a new disposable pen:
  1. Press down on the pen cap to break the internal link seal.
  2. Holding the pen with its tip pointing down, shake the pen to start the ink flow.
  3. Remove the cap and test the pen for ink flow on a scrap of paper or media before installing it in the plotter.
    Some types of pens require adaptor sleeves to fit the pen holders in the pen changer and pen carriage. Insert each pen into its adaptor sleeve, if required, before installing it.
Using the Pen Changer
You may find it easier to temporarily raise the pen changer arm to install pens. Press the widest part of each pen into the jaws of each stall in the pen changer. After installing all the pens that you plan to use, lower the pen changer arm until it latches into place.
Notice that the pen changer stalls are numbered 1 through 8 from right to left (viewed from the front of the plotter).
Note: Make sure that the pen changer arm is in its lowered position and latched into place each time you power on or reset the plotter so that the plotter will correctly change pens.
Operating Without the Pen Changer
For operation without the pen changer, position the pen changer arm in the raised position and install a pen directly into the pen carriage by pressing the widest part of the pen body into the jaws of the pen holder on the pen carriage. You can still produce multi-pen plots, if desired, by enabling the PEN PAUSE parameter--------------Online KeyThe Online key toggles the plotter between on-line and off-line operation. The mode is displayed with each key press.
The plotter is initally in the on-line mode at power-on. In the on-line mode, plotting operations are enabled. When media is loaded in the plotter and the plotter has been selected (see below), an on-line plotter begins executing plotting commands from the input buffer as soon as they are received from the host computer.
In the off-line mode, the plotter can still receive data into its input buffer if it has been selected, but plotting operations do not begin until the plotter is switched on-line. The plotter can be operated manually in the off-line mode using the following control panel keys:
  • Pressing the left or right arrow key moves the pen left or right.
  • Pressing the up or down arrow key moves the media in or out of the plotter.
  • Pressing the PEN SELECT key accesses a menu to select a given pen from the pen changer.
  • Pressing the PEN UP/DN key raises or lowers the pen.
Pressing the Online key during plotting switches the plotter off-line and suspends plotting.
Pressing the Online key again will cause plotting to resume at the point of suspension. ------------------Pen Up/Dn Key
The Pen Up/Dn key raises and lowers the pen when the plotter is off-line. If there is no pen in the carriage, pressing the Pen Up/Dn key causes the plotter to retreive the currently selected pen from the pen changer (if the pen changer is installed and is in the lowered position).
Note: After approximately two seconds of no pen movement, the plotter will automatically raise a lowered pen to prevent ink from bleeding on the media, until the pen is moved again. If the pen is not moved for the period set for the AUTO-CAPPING parameter , the plotter will return the pen to its pen changer stall. To restore the currently selected pen to its previous position on the media, press the Pen Up/Dn key or an arrow key. Pen Select Key
When the plotter is off-line, pressing the Pen Select key allows you to select a pen from the pen changer. After pressingPen Select, press the <-- --> keys until the desired pen number is displayed on the lower line of the LCD, then press the Enter key. The plotter will retreive the selected pen from the pen changer.
The Pen Select key is also used in the Configuration Menu,
Oct 16, 2009 | Computers & Internet
My plotter seems not to output NMEA to my DSC radio and auto helm
Your plotter can talk to you Radio and your pilot. It sounds like one of two things.You must go into the system setup menu and turn on the nmea sentances. You will need to turn on RMB, RMC, GGl at least. You can turn on all the sentances if you like it does not matter. If this does not fix, check color of wiring is correct. Remember you have to go from NMEA + out (on plotter) to NMEA + IN on Radio.Then you need NMEA - out(on Plotter) to NMEA - IN on Radio.
You can look at the sentances wirth a multi meter coming out of your plotter. You put meter in DCV and connect across the NMEA out lines. You will see the meter move every second or so as it send a sentance.
Jun 09, 2009 | Raymarine Raychart 435 GPS Receiver
My fathers bought second hand ride on
Search it out online you should be able to access a manual
Apr 21, 2009 | Mtd Garden
Canon ipf 8000 Error Code E161-403F
Feb 21, 2009 | Canon imagePROGRAF iPF8000 Printer
RL70CRC crashes with new "Wide" C-map cartridge
get a new burn on the chip, I have seen this issue on a particular burn.
Mar 22, 2008 | Raymarine RL70CRC GPS Receiver
HP DesignJet 5500PS InkJet Printer Logo
85 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
