Question about HotBrick LB2-VPN SOHO 4-Port Dual WAN VPN Router (SOHOLB2VPN)
VPN established but can't see the server on the other per
I have two HB-2. I make de VPN established, but when I ping the IP from my machine to remote server it's not function.
Is any thing that block the traffic between two wan that I have to leave free ?
I didn't solve the problem using HB LB-2. I just change de router by linksys RV042 and the access
through VPN is ok.
Posted on Jun 17, 2009
Cannot link vpn. direct from internet provider works. when try connection via d-link dir625 does not connect. does allow internet access
Ok to Setup you VPN follow the instructions below. You can configure DI-804HV, DI-808HV, and DI-824VUP+ by web management interface. Type 192.168.0.1 (The LAN IP is 192.168.0.1 by default) in the browser, and then input user name: admin (there is no password by default) to pass authentication of web management interface. Then finish the configurations as showed below on Gateway A and Gateway B. Configurations of Gateway A 􀂾 Model: DI-804HV (DI-808HV, or DI-824VUP+) 􀂾 Firmware version: v1.40 (You can download the latest firmware on D-Link’s website.) 􀂾 WAN IP Address: 14.15.16.17 (Static IP) 􀂾 LAN IP Address: 10.5.6.1 (Subnet Mask: 255.255.255.0) 􀂾 VPN Configurations: 􀂄 Enable VPN function on Gateway A. 􀂄 Tunnel Name: toGatewayB 􀂄 VPN Method: IKE (Main mode) 􀂄 Local Subnet: 10.5.6.0 􀂄 Local Netmask: 255.255.255.0 􀂄 Remote Subnet: 172.23.9.0 􀂄 Remote Netmask: 255.255.255.0 􀂄 Remote Gateway: 22.23.24.25 􀂄 Pre-share Key: hr5xb8416aa9r6 􀂄 IKE Proposal (Please remember to add the correct proposal ID into the list of IKE Proposal Index when you finish inputting the following information.) 􀀹 Proposal Name: toGatewayB 􀀹 DH Group: Group 2 􀀹 Encryption Algorithm: 3DES 􀀹 Authentication Algorithm: SHA1 􀀹 Life Time: 28800 􀀹 Life Time Unit: Second 􀂄 IPSec Proposal (Please remember to add the correct proposal ID into the list of IKE Proposal Index when you finish inputting the following information.) 􀀹 Proposal Name: toGatewayB 􀀹 DH Group: Group 2 􀀹 Encapsulation Protocol: ESP 􀀹 Encryption Algorithm: 3DES 􀀹 Authentication Algorithm: SHA1 􀀹 Life Time: 3600 􀀹 Life Time Unit: Second 4. Verify the VPN connection Before you start to establish VPN connection between Gateway A and Gateway B, please make sure the Internet connection between Gateway A and Gateway B is workable. You can use “Ping Test” tool on Gateway A (or Gateway B), and input the IP address of Gateway B (or Gateway A) to see if there is any response from its peer device. Connect a PC (called PC_A) to the LAN port of Gateway A, and connect another PC (called PC_B) to the LAN port of Gateway B. Start to “Ping” PC_B on PC_A, then Gateway A will start to establish IPSec connection with Gateway B. If you can get “Ping” responses from PC_B on PC_A, then it means the tunnel has been established successfully. You can also check the “VPN Status” page with web management interface to verify the status of VPN connections. Figure 1: VPN status of Gateway A after IPSec connection has been established. Figure 2: VPN status of Gateway B after IPSec connection has been established.
Hope this helps
Here it is in PDF.http://www.vpnc.org/InteropProfiles/D-Link-DI.pdf
Feb 11, 2010 | D-Link DIR-625 (790069292637) Wireless...
VPN connection error
1) you are dialing the wrong number.
2) make sure you have good connection.
3) If using VPN, make sure the port 1723 and IP Protocol 47 (GRE) are opened.
Apr 04, 2008 | Televison & Video
Tip
How to setup VPN on a D-link Router.
Hope this helps
on Feb 11, 2010 | Computers & Internet
How to connect my MSSQL server through VPN by using PPTP
192.168.1.X is a local ip address ,, i trust that thhe vpn is in seperate places and is done with the wan ip over an internet connection?????
OK maybe the problem isnt on your side but the main office building,, when connecting , have someone looked for repeated attemps to connect by observing the fire wall,, if it appears to be blocked byu the firewall simply diasable any and try it out.. If it works then all you need to do is set the firewall correctly..
I was reading the ip address in your original post and those are local address,s are you certin the VPN is correct ???? did you use the correct STATIC IP ADDRESS ASSIGNED BY YOUR ISP??
Jan 20, 2008 | Cyberguard SG300 (00852503000366) Firewall
Can you help me. I have a remote stores with DSL and FIOS connections. The connect back to the corporate office via a VPN connection using a CISCO ASA. At one point I could get on the internet and...
the issue is that you probably do not have a host or administrator right ...and this is required ...also when you accessed it wasn't firewall ed ...now ...in order to access it by its IP from the browser you need to disable the firewall or to insert your computer into the allow exceptions in that firewall on the remote machine...
Nov 04, 2009 | FixYa Computers & Internet
I have two different domains that are connected via VPN connection through two routers. I can ping from domain to domain via IP address on clients and servers. However I can only do a net view command on...
This is an excerpt from a MS Technet page for error 53:
Resolutions: 1) if it is domain environment, check your WINS; 2) if it is peer-to-peer workgroup, enable NetBIOS over TCP/IP; 3) make sure the machine is running; 4) make sure file and Printer Share enabled on remote computer; 5) make sure client for ms networks is enabled on local computer; 6) make sure you type the correct name. 7) Make sure no firewall running or any security setting.
Pay close attention to #s 4 and 5 - I suspect XP pro might not be open enough.
Sep 28, 2009 | D-Link NetDefend DFL-700 Firewall
Remote Desktop via VPN problem
Make sure that the Active Directory setting for the User you are using to RDP with (LDAP FQN) has the remote access option turned on.
http://www.windowsecurity.com/articles/Securing_Remote_Access_Connections.html
Also make sure that the PC's you want to access have static IP addresses. Not sure if that was mentioned.
Feb 18, 2009 | Dell PowerEdge 2600 Server
Unable to get remote desk top computer to work on acer aspire one
I think you're trying to connect to your office computer from home/somewhere else.
If that's the case, make sure you have done the following :
  1. Your VPN Session is connected
  2. Your Office IT Administrator allowed RDC over VPN
  3. Your Office Computer RDC is enabled
  4. Your User (local or domain user) having administrative rights or allowed to connect to RDC session
  5. You got no firewall blocking RDC connection or remote registry
To check if you already connected to your office VPN, launch command prompt and try pinging your office computer name or IP Address. As an example if your office computer name is PC-100 and IP address is 192.168.1.100 then you will issue : ping PC-100 or ping 192.168.1.100. If you got ping reply than you're good to go.
To Enable RDC on your office computer there are 2 ways :
1. On your office computer, right click my computer > properties > Remote > Enable Remote Desktop
2. Via remote registry :
- Start > Run > Regedit > Enter/Return
- On registry editor, go to File > Connect Network Registry > Type in your office computer name > OK
- On your office computer registry, browse to : HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Terminal Server, find the key "fDenyTSConnections", double click it and change the value to 0
You should disable your windows firewall or 3rd party firewall for easier configuration. You can;however set up exception on your firewall but will need some knowledge to do that.
Hope it helps.
Nov 02, 2008 | Computers & Internet
Can't ping or see anything on remote LAN
They are defective i have gone through like 5 or 6 of them before sending them all back i would sacrifice the gigabit and go with the RV042
May 21, 2008 | Linksys RVS4000 Router
Vpn error. 800
Resolutions: 1) if you have firewall, open TCP Port 1723, IP Protocol 47 (GRE). 2) make sure you can reach the VPN server by using ping. Sometimes, poor connection can cause this issue too. 3) You may need to updated firmware on a router or firewall if other OS (win9x/nt/me/w2k) works except XP. 4) The VPN server may not be able to get IP from DHCP for the VPN client. So, you may want to re-configure VPN host networking settings. For XP pro VPN host, go to the Properties of the VPN>Network, check Specify TCP/IP address and Allow calling computer to specify its own IP address, and uncheck Assign TCP/IP addresses automatically using DHCP. 5) Make sure no other secure software blocks your access, for example, if you use Norton secure software, you may need to add the remote client's IP so that the client can access. 6) If your VPN running on a Windows RRAS with NAT enabled, you may want to check the NAT settings. 7) If you can establish the VPN from the desktop at home but not from the laptop. Make sure no security software like Microsoft OneCare software that blocks the GRE.
Oct 01, 2007 | Acer Aspire 5100 Notebook
HotBrick LB2-VPN SOHO 4-Port Dual WAN VPN Router (SOHOLB2VPN) Logo
104 people viewed this question
Top HotBrick Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a HotBrick Computer and Internet Expert? Answer questions, earn points and help others
