Archos 504  Digital Media Player
Problem for Archos 504 (80 GB) Digital Media Player (500870)
Recovery code 4 on archos 504
By leonor on Nov 01, 2007
i need help with this recovery file
Same Problem
Jan 09, 2008
-   I HAVE SAME PROBLEM WAT CAN I DO PLS HELP ME-   Guest
Dec 26, 2007
-   I have the same problem and the computer doesn't recognize the Archos. It just repeats the error screen. If it would load up for me load the firmware onto it I would, but that's not the case.-   UndeadGirl
Best Solution
posted on May 28, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Hemansd
Thanks for your advice my Archos decided to die on me , not as bad as a ipod :) thanks for your tips did the job nicely
Solution #2
posted on Dec 19, 2007
Helpful)
Hemansd
Rank: Apprentice
Rating: 94%, 13 votes
I had the same problem and manage to solve it. You need to do the following
a. go to Archos website and download latest firmware and save on your pc
b. turn on 504 and select repair - unit not connected to pc
c. connect 504 to pc and wait until pc recognise it
d. copy firmware from pc and past to 504 root directory.
e. press done on 504. that should work. I've spent the best part of 10 hours looking for a solution to the dreaded recovery code 4. The problem is a corrupt os. I hope you're as lucky as me.
I still have a problem with mine though...a screen that blink constantly.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #3
posted on Sep 21, 2008
Helpful)
myspcestubbs
Rank: Apprentice
Rating: 88%, 2 votes
Connect your archos by USB then...
Download and save the most up-to-date Archos operating system (firmware) to your desktop - it's of the file type *.aos file (in this case for the 404, "a404.aos")
Switch on the Archos so you get the warning message and the 3 messages, "no", "repair" & "format".
Select repair or format (format removes all data however, works best) - this recognises your Archos on your PC - do not select "Done".
Open my computer or home & you will see your archos drive in hard drive mode.
You can now drag & drop the a404.aos file from your desktop into your Archos (root).
Once you can see the aos file on your Archos (do not select done on on your Archos) reboot your pc keeping the USB cable plugged in and your archos will automaticelly update then reboot.
Switch the archos off (if frozen use a pin to reset it) then on & it should function again!!!
If this worked for you, please support the band "Stubbs" myspace/peter j skye.
http://profile.myspace.com/index.cfm?fuseaction=user.viewprofile&friendid=411928241
Was this helpful?
Yes
No
Solution #4
posted on Apr 25, 2008
Helpful)
jiggssey
Rank: Apprentice
Rating: 85%, 2 votes
how did you get your pc to recognise it?
mine will not because it is not switched on?
Was this helpful?
Yes
No
Solution #5
posted on Nov 02, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
it does not even have anything on the screen!..
Solution #6
posted on Oct 15, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
thanks for the help i have done it
Solution #7
posted on Sep 20, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
you need to hold down both the power button and the one next to it to power up is maintainance mode. In this state it should communicate with a host PC via USB. Just give the PC long enough to react to the new device.
The arcos screen should show the three choices : recover system , don't recover , format disk.
The latter will blast everything so dont do that unless you're sure you don't want anything at all you have on the archos.
recover system will ask for an update file. This is what you need to supply by adding it to the archos from the PC.
This can be done from Linux if you wish.
Popular Solutions for Archos 504 Digital Media
Questions and Unsolved Problems for Archos 504 Digital Media
Do you recommend Archos 504 (80 GB) Digital Media Player (500870)?
Answer
Answer
i have an archos 504 mp4 player the unit powers up after charging, then will play one album, then... (More)
Answer
When we connect our archos 504 to our new HD Digital TV via the scart plug (TV Output) -... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Archos 504 Digital Media...:
Top MP3 and Digital Med... Experts
Rank: Guru Guru
Solutions: 780
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more MP3 and Digital Med... Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
