Hoover 1100 my hoover 1100 won't empty away the water that it has took in
  • 365 Answers
Sounds like the pump is faulty
Posted on Jun 17, 2009
HNL 6146 door won't open
Has it emptied all water out ??
Jun 18, 2013 | Hoover Washing Machines
Using my hoover steam vac tonight and too much water coming out. once it's turned on, water and shampoo continuously come out underneath until tanks are empty. looks to be leaking from left side bottom as...
make sure that you have filled everthing properly and the hoover steam is in a good condition. or check else is there any loose coonections in the bottom of the hoover, which makes the tank empty.
if the problem persists take it to service.
Feb 25, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
Will not **** up
LOL.. not sure what it will not do.. but assuming it will not **** up the water ? make sure the dial is set to the correct setting. container for soap is full and correctly popped into place...
if the clean water resevoir is empty - it won;t **** up and if the dirty water resevoir is full it wont' **** up the water from the carpet... other than that... I don't know.
Mar 29, 2010 | Hoover F7431-900 SteamVac Vacuum
Hoover performa 1100 ac110 not emptying
After syphoning water out of drum, remove and clean filter located at bottom front left of washer, if there is a screw in the filter cover, unscrew this first.
Remove filter by unscrewing anti-clockwise.
Feb 06, 2010 | Hoover Washing Machines
Hoover condenser dryer VHC180. Water empty
hoover dryer water leaks when machine is running.
Dec 05, 2009 | Hoover Dryers
My hoover performa 1100 is leaking slightly. Is there a filter I should empty?
yes there is a filter .n the bottom left. you just take off the panel on the bottom, then with a philips screw driver take the cover off the housing then remove the filter. top tip would be place a towel on the floor because it will leak water.
Sep 06, 2009 | Hoover Washing Machines
Washing machine will not complete the wash cycle
The timer could be sticking OR: Is the machine empty of water when it stops? This information may help solve your problem?
Jun 16, 2009 | Hoover Washing Machines
How to work the hoover performa 1100 washer dryer
My Hoover Performa 1100 does not drain the water therefore it does not open. Can anyone help please?
May 15, 2009 | Washing Machines
Water not draing away and machine is not spinning
Empty your machine manually by lowering the drain hose into a bowl or bucket. Then remove the kick plate and check the filter for blockages.Before replacing try the machine on drain to see if the pump is running, if problem persists there may be a blockage in the pipe from the drum to the pump.
Nov 15, 2008 | Hoover Nextra HNWL 3136 Front Load Washer...
Hoover ab130 water won't empty from drum
unselect the option button "crease guard or easy iron" it will will spin normally! (ex hoover engineer)
Jan 08, 2008 | Hoover UltraCare HC6 130M Front Load...
Washing Machines Logo
150 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
