Question about Lexmark Office Equipment & Supplies
When I moved my Lexmark C912 printer from one computer to another, I couldn't find the driver disk, so I downloaded the one I thought would work for Windows XP Home Edition. LEXMARK_AAI_WINXP_PCL_SYS_EN.EXE It works, but the menus are different, and I can't find a way to print on 12x18" paper.
  • 1 more comment
  • justice49 Jun 16, 2009
    I downloaded the other driver and installed it, but I can't see any difference in the menu options.
    Paper size gives me letter, tabloid, and a dozen other options, but my old menu had a "custom" option where I could put 12x18". I have to admit that my webmaster set up the 12x18 for me, but he is long gone and I have no idea of how he did it. But the printer is designed for this size, so it can't be that strange.
  • justice49 Jun 17, 2009
    I downloaded the second driver, and have been going to printer properties to change the size, but 12x18" is not an option in the paper size setting, nor is "custom." This printer advertises as printing 12x18, and I have printed many sheets of 12x18 paper from my previous computer, but this print driver does not seem to support it.
    I downloaded
    LEXMARK_AAI_WINXP_PCL_SYS_EN.EXE first, then was advised to download
    LEXMARK_AAI_WINXP_PS_SYS_EN.EXE. Both are for XP. I am somewhat reluctant to uninstall them and try again unless I'm sure that it will make a difference. So far, even though I haven't figured out how to print 12x18, the color quality of my output seems to have improved. I would hate to sacrifice good color (which is important all the time) for larger format, which I only use occasionally.
    Worst case scenario, I'll keep my old computer attached to my network and use it only when I need some large-format prints.
    Justice
It could be that the driver installed previously on the old computer was simply older where it had the custom paper option - although it's print quality may not have been as good as the newer driver where this custom option is missing.
This is common sometimes, they remove something, but add something else. It's a choice you have to make unfortunately. It is silly why they can't just leave the older good options present.
There may be a way to extract the old driver for use on your new computer. But then you will sacrifice quality over custom size. If you're happy to do this, let me know and I'll let you know how to extract the old driver for use on the new machine.
Also let me know what operating system the old computer was running.
Thanks
nLinked
Posted on Jun 18, 2009
  • 10,515 Answers
First of all, let's make sure you have downloaded the correct drivers. Uninstall the previous one and download from the below link :-
http://www.nodevice.com/driver/C912/get32752.html
Once downloaded, Install and restart your Desktop/Notebook.
Check and let me know, If you see the same old menu or a new one.
Thanks.
Posted on Jun 17, 2009
  • 10,594 Answers
Download following file too with above said driver file..
Get it from Lexmark Support.
Thanks.
Posted on Jun 16, 2009
  • Shahid Electronics
    Shahid Electronics Jun 16, 2009
    Paper size settings would be in printer properties, click Control Panel > Printer and Faxes > right click Lexmark C912 and select Properties. There you can set required paper size.
    Thanks.
Lexmark C912 not reporting toner properly
print the status page make sure the revision level in the lower right corner is greater than 803.04 if its not go to lexmark to update the code if it is greater than. press the right arrow until reset toner Lvl appears in the display press select. use the right arrow to scroll through the colors to be reset. when you get tot the color you want to reset hit select it should give a brief message resseting toner then move to the next one. when finished you will need to power the machine down and back on again before the changes will take effect.
Nov 20, 2009 | Lexmark C912 Led Printer
Lost disk that came with printer lexmark 2500 series.
Hey,
The lexmark drivers and software required for installing the printer is available at www.lexmark.com
Select Drivers & downloads then driver finder.
Type in your model x2350 for example
Select your windows version
Download the setup program.
1.Download software
2.Run the downloaded setup
3.Plugin the printer when asked
4.Done
Thanks,
Ekse
Jun 07, 2009 | Lexmark X2500 All-In-One Printer
Lost intallation disk
click this link: http://downloads.lexmark.com/perl/downloads/downloads.cgi
Just choose your operating system: Windows XP or Vista and you can download the drivers (installation software).
Apr 19, 2009 | Lexmark X4270 All-In-One InkJet Printer
Replace toner
Please click here and the installation guide to install the toner cartridges ..
Good luck..
Nov 11, 2008 | Lexmark C912 Led Printer
Lexmark x 2589 printer will not install or download to computer
If your disk is not working you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
After downloading, find the file,double click on the file ,then if you get in troubles, follow the instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website, or use the disk and run the install file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Note:some printerdoes not work on Vista, if you do not find any driver download for Vista on your model page, that means your model is not Vista compatible.
Oct 27, 2008 | Lexmark X2500 All-In-One Printer
Lexmark C912 LED Printer
replace the rip baord if the firmware download failed ie flashing firmware eprom has fialed
Sep 29, 2008 | Lexmark C912 Led Printer
Lexmark c912
980 error code is internal printer error. This is beyond users capability.
turn off the printer and check all cable connections.
turn on the printer, you need to call lexmark service, if the error return.
Jun 24, 2008 | Lexmark C912 Led Printer
Lexmark C912
1> check or replace all of the data cables to the printer..... 2> shut off and unplug the printer from both the wall power and the computer for about 10 min, and reboot the computer as well 3> try reinstalling the printer driver software
Jul 27, 2006 | Lexmark C912fn Led Printer
44 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
