Question about HP Compaq Presario V2000 Notebook
Laptop will not come on. The AC cord seems to be working. What can it be?
    Problem Solver:
  • 7 Answers
The power supply most likly shot
Posted on Jun 16, 2009
I have a lenovo thinkpad T420 and three days ago I lost my power cord now that I got a new one my laptop screen doesn't seem to turn on I tried a lot of solutions and nothing seems to work. When I turn...
Hi, try removing the battery pack then use the AC adapter or power cord alone. If still the same. Eject the battery and also remove from outlet hang on for 10 minutes. Then try to turn it on again with AC adapter alone
Oct 06, 2012 | Computers & Internet
Wont power up, power cord good. once plugged into laptop power cord stops working
As long as you are abslolutely sure the power cord is functional, without a more indepth analysis, it seems/sounds like the AC connection to the board is broken.
To rule out this conclusion as the failure point, see if you can borrow/buy or better yet, recharge your battery {assuming it has no charge left at this point}
Stick the charged battery into your rig and if it works, yes. The AC connection is broken - nothing a little bit of soldering won't fix.
If it works, will need to ask more 'protocol questions to narrow down the situation'.
...when you reflect on the usage of the laptop, is there a bit of manhandling when connecting the power cord? Do you run it mainly plugged into AC? Dell is infamous for dodgy AC connections strongly lending credence to a broken AC connection to the mobo.
Dec 07, 2009 | Dell Inspiron B130 Notebook
Dell D600 Power Up Issue
there is a short circuit onnthe laptop motherboard usually it's power ic's that are next to the power socket that block the power from going to other parts so you should change those ic's
Sep 08, 2009 | Dell Latitude D600 Notebook
AC Adaptor input issues (fries cord, won't charge computer)
dear,
are you using same wall socket everytime for this job...
if yes, then check the mains there too...might be its because of that..
if all are fine in the socket then u have to check the laptop power supply section ....
rate it if issue resolves.....
Apr 17, 2009 | Computers & Internet
HP Pavilion dv2020us laptop battery won't charge
How is your power supply? does it seem like you have to wiggle your cord that connects to computer to make it recieve power?...Many laptops power supply become loose over time form moving the cord around..when it does, the battery has a hard time getting electric power to recharge. Also, you my have other problems with your lithium internal battery that powers your cmos.
Check to see if your power supply is loose and go from there. the power supply is the little hole where you connect the cord to the laptop.
let me know what the status is
Apr 10, 2009 | HP Pavilion dv6000z Notebook
Battery will not charge nor is able to use AC power to stay on.
Hi everyone it seems to me that the DC connector is loose inside your laptops,try wiggling it about gently at the charger to laptop cord nearer to the dc socket to verify this.Only solution is resolder or new dc socket.
Dec 27, 2008 | Acer Aspire 3680 Laptop
Laptop won't turn on/stay on
Is the fan blocked?
If no air goes in, CPU could overheat.
Aug 26, 2008 | Toshiba Satellite 1135-S125 Notebook
AC Port shorting out
That definatly sounds like you need to replace the jack for sure....I have fixed two toshiba's with the same problem myself. To get it done in the store you are probably looking at $150-300. Least that is what it was here. So i decided to buy the part i needed off ebay, take the laptops apart and resolder the jack on.
Jul 09, 2008 | Toshiba Satellite R25-S3503 Tablet PC
Laptop is not working......adapter is plugged in and charging...???
I've seen this several times and a battery replacement fixed it every time.
Nov 08, 2007 | Toshiba Satellite L25-S119 Notebook
HP Compaq Presario V2000 Notebook Logo
57 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
