Question about Funai Trutech 13" TV
Video button? My Funai Trutech model model #CR130TT8 does not have a video button but has a video/audio input for a DVD player. How can I play DVDs on this television?
  • cbyrnes08 Jun 17, 2009
    I would have never guessed that. Thank you so much pob-h!
  • 909 Answers
There is a button marked input select, press this until you see the dvd's picture.(analog t.v./digital t.v./video) plug the dvd into the front input socket.
Posted on Jun 16, 2009
DVD and VHS don't work
The outputs of your VCR/DVD player should be plugged into the audio and video inputs of your TV.
Mar 09, 2014 | Sony BRAVIA KDL-46W3000 Television
Burned dvd + r disc plays on a Sony progressive scan dvd player, but has problems on a Funai dvd player
If its because of the way you formatted it then try using something that says dvd format and change its resolution to its proper playing method to its dvd that can play it.
Nov 23, 2013 | Magnavox DV220MW9 DVD Player VCR
I dont have cable.i was using this tv just to play dvds and i accidentally hit channel search. now i get a blue screen that says" plerase connect cable system or an antenna to the terminal on the back...
Hi:
Using remote locate a button called tv/video or Input, turn on the DVD player and hit this button until you see your DVD player Logo. Most dvd players use either video 1 or 2, or componet or HDMI outputs. Seems you have changed the TV's input back to TV mode and you need to change it to a video mode input.
May 17, 2011 | Televison & Video
How do I play DVD on the BlueRay player?
According to the Vizio website, your VBR231 CAN play DVDs the same way a lot of Blu-Ray players can. The site blurb suggests the VBR231 is backwards compatible - which means your player should be able to play DVDs as well as Blu-Ray. Generally, most Blu-ray players can play DVDs if they are backwards compatible with them.
I do know Blu-Ray discs will NOT work in most standalone DVD decks.
MODEL NUMBER: VBR231
*Model Features:
* Full HD 1080p Video Playback
* Integrated Dual Band Wi-Fi - 802.11n
* 7.1 Digital Audio Output
* Backwards Compatible (see below)
*Compatibility:
* Plays Blu-ray and DVDs, Audio CDs, MP3s and Jpegs
* Multi-Channel 7.1 Audio Output via HDMI
* Playback and Enjoy Media via back USB Input (JPEGs and MP3s)
*Outputs:
* HDMI 1.3
* Component Video (YCrCB)
* Composite Video
* Stereo Audio
* Coaxial Audio
* Optical Digital Audio
I hope that helps somewhat.
Feb 02, 2011 | Vizio VBR231 Blu-Ray Player
Does TV have to be on certian channal for it to work . old TV audio and viedo are pluged into back sylvania tv?
There are two different methods for attaching the DVD to a TV.<br>If the TV has the red and white audio jacks and the yellow video jack, then you just plug them in and then set your TV to use the alternate video input.&nbsp; There should be a button to cycle through the video choices on the remote or menu.<br><br>If you do not have any alternate audio and video jacks on the TV, only then do you need to buy an RF modulator and plug that into the antenna in of the TV, and select channel 3 or 4.<br><br>Here is a better description, with diagrams:<br><br>http://trutech.supportsync.com/article.aspx?id=1005<br><br>
Aug 27, 2010 | TruTech DV288B3 DVD Player
Dvd won't send picture/audio to tv
for video, 3ways and any of this should work.
Step1, video out of dvd to video in on top at video1 section on tv. or
Step2, svideo out of dvd to svideo in at video1 section on tv. or
Step3. using component video DVD unit component video out to TV unit component video in at video2 Y to Y input of TV Pb to Pb input of TV Pr to Pr input of TV
for audio, connect left/right audio of dvd to left/right input of tv. Input section of TV is in the middle. on tv back panel from left to right is antenna input, IN section - this is it, use this for all your connections. let us know if you have any issues. thanks.
May 02, 2009 | Panasonic DVD-S27 DVD Player
Won't play dvd
we have two options in this case:
  1. the receiver is your main brain:
you hook up the dvd in the receiver and the tv works as a monitor (the receiver has to have video output to monitor)
2. anyone works at its own:
in this configuration the DVD (video) is hook up into the tv (any video tv input works fine) and audio goes to the receiver in any audio input.
Apr 14, 2009 | Televison & Video
No remote on TruTech CR130TT8 TV i need to know how to change from tv to video mode
try using the input button right next to the on/off and vol/channel buttons
Feb 28, 2009 | TruTech PVS31170S1W 17 in. LCD Television
Trying to hook PS2 up
u cant play them on it its a dvd player
Dec 12, 2008 | TruTech PVS12701 Portable DVD Player
Funai Trutech 13" TV Logo
206 people viewed this question
Top Funai Televison & Video Experts
Demonic-2011
Demonic-2011
Jaime Hernandez
Are you a Funai Televison and Video Expert? Answer questions, earn points and help others
