Question about GPS
Unit won't take a charge in my car.Ichecked the fuse in my vehicle and its ok.The power cord to the nuvi760 has a sticker that says ''replacement fuse F3A 250V'' but I can't seem to find it
    President:
  • 1,111 Answers
Its in the tip of the plug on the charging adapter that plugs in the car..the tip screws off and fuse is inside under tip
Posted on Jun 17, 2009
No power ac or dc IFR 1200 super s
Try another Cord/charger, with the EXACT same power specs, without the battery installed. If it works on the AC/DC cord/charger, replace the battery with a genuine battery with the exact same power specs.
Mar 15, 2013 | Computers & Internet
T will indicate charging but it won't charge actor
If the laptop works only off the Power Cord and the batteryis not charging, then the battery is dead.
To check to make sure the Power Cord is working remove the battery and let thelatop run for 10 minutes or so.
To check to see if the battery has any charge left in it put the battery in andremove the power cord. If it won't boot or shuts down then the battery is deadand needs to be replaced if the power cord is ok.
Apr 23, 2012 | HP Compaq nc6400 Notebook
My Garmin nuvi 265 was working fine until 2 weeks ago. We got a screen message saying that the XM traffic was not supported, and then noticed that the unit no longer could be charged using the car...
The traffic receiver is in the car charger cable. The charger should have a red light on if it is getting power. If the light is on and the unit is not charging and you have no traffic, the charger cable is bad. If the light is off, then either the fuse did not fix the problem, blew again, or is somehow not sitting properly in the charger. Another thing you can check is by using the unit in another vehicle. If it works fine there, then the charger is not making good contact with your vehicle outlet for some reason. You will probably have to buy a new traffic receiver charging cable.
May 04, 2017 | Garmin nuvi 265 Car GPS Receiver
Doesn't want to stay on
If your GPS unit powers down before it can fully boot up, use the steps below to charge the GPS unit and test the vehicle power cable:
  1. Connect device to a computer that is powered on
    • The unit should power On when you plug it in showing a computer plugged into the GPS unit on the screen (Mass Storage Mode)
  2. Press Reset button on the bottom of device if it does not power On*
  3. Allow the unit to set and charge for 3-4 hours
Once the device is charged please take it to the vehicle and test it on the vehicle power cable.
  1. Connect the device to the vehicle power cable
  2. Connect the vehicle power cable to outlet on vehicle
  3. Power the vehicle On
  4. Device should automatically power on
    • If a battery icon appears directly to the left of the time then it is not receiving a charge from the vehicle
    • Please check the fuse in the vehicle power cable
      • The end of the cable unscrews to reveal this fuse
      • Check to make sure the wire element inside the fuse is in contact and that there is no discoloration.
      • If you see either of these the fuse needs to be replaced with the replacement fuse specifications listed on the sticker attached to the cable.
      • If the fuse looks good and there is still no light, the vehicle power outlet may need to be checked to see if it has power.
*Note - The reset button may be found on either the left or right side. In some cases if the device does not have a reset button slide the power key to the left or On position for about 10 - 15 seconds.
Oct 23, 2010 | Garmin nuvi 200W GPS Receiver
Unit shuts down while navigating with power cord plugged inalso seems to have dead pixels in screen
Dead pixels you can't do anything about without replacing the COLOR LCD TOUCH SCREEN. Which will probably cost as much as replacing the whole unit anyway.
As for shutting down while plugged in, that may be one of two things. Either the charging cord has gone bad (and they do go bad), or your not plugged into the lighter/charging port in your vehicle completely. Lastly, the charging cord for a Garmin GPS has a fuse in it, at the head that plugs into the charging port. Check it to see that it's not blown. Chances are it may be.
Jul 10, 2010 | Garmin nuvi 1300 Car GPS Receiver
Garmin street pilot 330 charging problem
Linda,
You need to check the fuse for both the car's cigar lighter AND the one in the GPS power plug (that goes into the cigar lighter outlet). Both must be good for the GPS to charge and power up.
I don't know if your friends cord worked in you car - or hers - so you're going to have to find out if it is the cord fuse or the car fuse. Since her cord worked on your GPS, start by using HER CORD connected to YOUR GPS in both cars. If it works in her car, but not in yours, check & replace your car's cigar lighter fuse. If or when it works in both cars, disconnect her cable and connect your cable to your GPS again. Connect into your cigar lighter. If it works, you're done. If it doesn't work, disassemble the plug at the end of the GPS cord (cigar lighter end) and check and replace the fuse if blown. You should be good to go at this point.
Please rate this reply if found to be helpful - good luck!
Jul 07, 2010 | Garmin StreetPilot C330 GPS Receiver
Cant get my nuvi 260 to work
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If the device does not power on it could be a result of a extremely low battery. Please ensure that the device is receiving a charge while it is connected to the vehicle power cable. If the battery is receiving power from the vehicle power cable then the battery icon (located next to the time) would disappear from the Main Menu. clip_image001.jpg clip_image002.jpg
If the unit does not power on while attached to the vehicle power cable please follow steps from below to perform a soft reset:
  1. Connect the device to an external power source1
  2. Slide and hold the power key to the on position for 15 seconds
The device should power on. Notes:
  1. Preferably the vehicle power cable or a USB cable from a computer
  2. Some of the older Nuvi 200 series will have a reset button on the bottom of the device. It can be found on the bottom of the device on the same sticker that the serial number is printed on.
If your GPS unit powers down before it can fully boot up, the battery will need to be charged. Please charge the unit with the vehicle power cable or on a computer for at least three hours. After charging the unit, it should power on and function normally. If the unit will not charge in the vehicle, check the fuse in the power cable for the unit and the power outlet in the vehicle.
Nov 12, 2009 | Garmin nuvi 260W GPS Receiver
My nuvi 205 garmin stops working s soon as I
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} First Make sure your plug and power cord are working. USE a Garmin charger!!!!
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If your unit will not charge in your vehicle, you may need to replace the fuse located in the tip of the vehicle power adapter.
  1. Unscrew and remove the silver or black, round end piece.
  1. Remove the fuse (glass and sliver cylinder) and replace with a new fuse.
  2. Ensure that the silver tip is placed in the end piece. Screw on the end piece.
Nov 01, 2009 | Garmin nuvi 205 GPS Receiver
GARMIN STREET PILOT-330 GPS
Hello KTFORE1,
The Street Pilot 330 comes with both a vehicle power cord and a USB cord for connecting the unit to the computer. If I understand you correctly the GPS isn't getting power from the vehicle power cord. Does the GPS charge if connected to a computer using the USB cable? If so the problem is likely the power cord or cigarette lighter socket you are using. If the GPS doesn't charge from USB port on your computer then the problem is likely the GPS itself.
If you determine that the cable is the source of the problem, check and replace the cable's fuse. You will probably also want to check and replace your vehicle fuses as the circuit that powers the cigarette lighter might have a blown fuse. If replacing the fuses doesn't solve the issue then you might need to replace the power cord.
Best Regards.
Ken
"Go Ahead. Use Us."
Jun 30, 2008 | Garmin StreetPilot C330 GPS Receiver
Nuvi 650
Hello Grumpa1350,
There are several possible reasons why a GPS unit might not turn on. For example, there could be something wrong with the charger such as a blown fuse, bad power adapter, or defective cable connection. The internal battery inside of the GPS also might be defective or worn-out. Or, worse yet, the unit may have a more serious hardware fault.
You don't say how you are charging the unit. I'd recommend trying a different charge method. The GPS can be charged one of three ways: connection to you car via the automobile power cord, connection to your computer via a USB cable, or charging from a wall outlet using an optional AC adapter. If you are charging the unit in your car, try connecting it to your computer (or vice versa). If the GPS turns on after being charged using one method but not the other, then that pretty much tells you that the problem is with the cable or adapter being used for charging.
The Garmin NUVI 650 does not contain an internal fuse, but there is a common 3 amp fast-blow fuse located in the vehicle power cord. If you find that the problem happens when trying to charge the unit in your vehicle, then you should change this fuse and see if that corrects the issue. The fuse can be replaced by unscrewing the black round piece at the end of the cigarette lighter plug.
If the unit does not turn on regardless of what charge method you use, then the fault is likely with the GPS itself. Either the internal battery would need to be replaced or the unit would need to be serviced to correct whatever hardware fault is causing the problem.
I would recommend you contact the manufacturer before you attempt to open up the unit. Opening the case of the GPS may void your manufacturer's warranty (if the unit is still under warranty).
Best regards,
Ken
Go Ahead. Use Us.
May 14, 2008 | GPS
GPS Logo
142 people viewed this question
Top GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
