Question about IBM Infoprint 1532n Laser Printer
Receiving an error 920.06 Service fuser error
  • 4 Answers
920 .06 Fuser is not increasing in temperature even though the lamp has been on for an extended time. Fuser page count between 0 and 99,999. • Fuser is not receiving AC power. • Poor supply line voltage.
Posted on Jul 15, 2009
  • IBM Master
  • 1,684 Answers
This error code indicates the fuser is not heating up. Your fuser will need to be replaced. We ave the fuser assemblies available for $125 plus shipping with exchange. And we offer free installation support if you need it. Contact me at buddy@ccl-la.com for more info.
Posted on Jun 17, 2009
  • 62 Answers
SOURCE: 920 service fuser error
nothing you can do but replace the fuser
Posted on Jan 08, 2010
SOURCE: receiving an error 920.06 Service fuser error
It's either the (fuser) heater lamp, thermistor, or fuse..call for service.
Posted on Apr 29, 2009
  • 53 Answers
SOURCE: Receiving Fuser Failure error message
please check if the fuser is inserted properly:)
Posted on Nov 20, 2009
mariolands
  • 2296 Answers
SOURCE: Error 120.10 service fuser error
Service Fuser Error appears on your Lexmark printer when the fuser does not warm to the required temperature. For this error on this Lexmark model, the manual states you should power off the printer and power it back on, and if it is not plugged into a wall power point, change it to a power point mounted directly on the wall. Personally, I never got a Lexmark printer to work doing this, but this is in the manual. If this won't help, and the printer is under warranty, you should log it in with the servicing company.
If the printer is out of warranty, your next option is to change the fuser which costs around $350, so I think you would be better off getting a new printer unless you find a second hand one on Ebay.
Posted on Feb 26, 2011
mariolands
  • 2296 Answers
SOURCE: E 352dn Mono Laser Printer: error 922 service fuser error...
Service Fuser Error appears when the fuser does not warm to the required temperature. For this error on this Lexmark model T632, the manual states you should power off the printer and power it back on, and if it is not plugged into a wall power point, change it to a power point mounted directly on the wall. Personally, I never got a Lexmark printer to work doing this, but this is in the manual. If this won't help, and the printer is under warranty, you should log it in with the servicing company.
If the printer is out of warranty, your next option is to change the fuser which costs around $90 on Ebay.
Posted on Mar 02, 2011
MON IMPRIMANTE LEXMARK T640N AFFICHE UN CODE D
Service Fuser Error appears when the fuser does not warm to the required temperature. For this error on this Lexmark model T640n, the manual states you should power off the printer and power it back on, and if it is not plugged into a wall power point, change it to a power point mounted directly on the wall. Personally, I never got a Lexmark printer to work doing this, but this is in the manual. If this won't help, and the printer is under warranty, you should log it in with the servicing company.
May 26, 2010 | Lexmark T640n Laser Printer
920.06 SERVICE FUSER ERROR
A 920 fuser error indicates that the fuser unit in the printer is below the proper temperature for printing. Turn off the printer for 30 seconds. Bypass any surge device or power strips, plug the printer straight to the power outlet in the wall. Make sure the printer is an operating environment where the temperature is above 16°C (60°F). If none of the steps above correct the issue, the fuser unit or possibly the power supply unit on the printer will need to be replaced. This will require a service action on the printer. I hope I can assist you more on this.
May 26, 2010 | Lexmark T640N Networkable Mono Laser...
Muratec f320 states: fax ready please call service it continues to send faxes but is not receiving
F-320 "Please call Service".....Press PROGRAM,*,6.....Press PROGRAM to select "Service Call"....error message will now be displayed.
Most common is #02 (Heater Error) which means you have a defective fuser.
Press PROGRAM to show any other error messages.
Press "STOP" TO EXIT.
May 14, 2010 | Muratec F320 Plain Paper LED Fax
There is a problem 120.10 Service Fuser Error
This error normally requires a service call. The fuser is not receiving the right amount of power. But try this. Power the printer off, wait ten seconds, and then power the printer back on. If possible, connect the printer's power cord directly into a wall outlet. In rare instances, a surge protector or uninterruptible power supply (UPS) can generate false error messages. If problem is not resolved, printer needs to be serviced.
May 03, 2010 | Lexmark C524 Laser Printer
Press ..Program, *, 6 ....Press Program to select "Service Call" then press ENTER...the error message will be displayed.
Most common prob was "Heater error" which means a defective fuser unit.
Mar 26, 2010 | Muratec F320 Plain Paper LED Fax
Dell printer will not print. Receiving message: fuser error
Fuser error usually means that the heater element has blown, or is not functioning properly.
The device will usually lock itself out to prevent any risk of overheating and causing a fire
You will need a technician to fix this
Feb 02, 2010 | Dell 1110 Laser Printer
Xerox phaser 6265 displays engine service 8300
From the service manual:
Code 83: Engine NVRAM is corrupted or receiving wrong data from a CRUM.
1 Cycle power to the printer. Does the error still appear? If so, go to step 2.
2 Remove and reinstall the Imaging Unit and Fuser Assembly. Does the error recur
after the power has been turned off and then on? If so, go to step 3.
3 Replace the imaging unit. Does the error still occur? If so, go to step 4.
4 Replace the fuser assembly. Does the error still occur? If so, to to step 5
5 Replace the EEPROM board. Does the error still occur? If so, replace the Engine Control Board.
Jun 23, 2009 | Xerox Phaser 6250 Laser Printer
Apr 28, 2009 | IBM Infoprint 1532n Laser Printer
IBM Infoprint 1532n Laser Printer Logo
3,539 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
