Question about Kenmore 20.6 cu. ft. Top Freezer Refrigerator
Kenmore compressor no power dont start
Compressor short out replaced new one wont start make an extnsion cord plug direct compressor start ok and running normal my problem is im not having power to compressor please help god bless
  • fnlbatino Jun 16, 2009
    the problem is i replace the compressor wont start no power going to the comp. temp. control is ok thanks god bless
  • Anonymous Mar 31, 2014
    I have a new power cord but having looking the last red and white cord going to the compressor
  • Kenmore Master
  • 3,361 Answers
Did you replace the start relay also? If not do so.
Posted on Jun 16, 2009
Haier window unit reset plug not resetting
check the house power board circuit breaker if the light indicator is not working
Jul 25, 2016 | Haier Heating & Cooling
How do i fix my dewalt 55155 air compressor
It is a 15 amps motor and will need 6 times (90) that amount of amps to start up. Plugging it into a 15 amps circuit may work but a 20 amps circuit is more apropiate. Kitchen circuits are 20 amp circuits.
You can try plugging the compressor directly into the wall and see if it refills with air without trippiing the circuit breaker. Using an extension cord should be done with a #12 or #10 wire gage type, smaller type will cause a power loss in the cord and will cause the compressor motor to trip the circuit breaker.
Power formula is I square R, or the amps multiplied by itself and by the resistance of the wire. E.G. 90x90x4 = 3200 watts. This is at start up. To find the voltage drop divide the watts by current, 3200/90 = .... get the point? Keep voltage drops to a minimum, use heavy wire gage extension cords.
Mar 11, 2015 | Dewalt Air Tools & Compressors
Kenmore French door refrigerator will not start up, control panel will not light up, wont come on
Have you tested the outlet? The power cord itself could have a broken or burned wire. Even if boards are bad, there should be lights.
Oct 03, 2014 | Kenmore 2537031321 Stainless Steel 26.7 Cu...
Kenmore Coldspot 25ssa. After power outage the refrigerator trips breakers and GFCI
Either the compressor or the start device on the compressor is shorted out. More than likely the compressor, hate being the bearer of bad news
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 07, 2012 | Kenmore Refrigerators
Kenmore refrig: when I plug power cord t wall socket, it triggers the ckt breaker
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Hi, There is a shorted wire or the compressor is shorted out...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 08, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Fridge and freezer not cooling any more. fan still running
it should never be plugged into any type of extension cord and also on its own dedicated circuit(nothing else on that circuit),you probably ruined the ptc overload relay mounted on the compressor(if your lucky) and not the compressor itself,this component is very inexpensive compared to a new compressor and labor to install it
Apr 19, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My microwave is plugged into a power strip and it keeps shutting off the strip. sometimes it does not trip the strip but most of the time it does.
It's drawing too much power through the strip and tripping the safety on it. Use a short extnsion cord on it(not the houhold style with the 3-way on it) the next size up gauge wire. Ask your local electrical supplier. they can help. Probably the longer you have the microwave on it when this happens?
Apr 13, 2009 | Microwave Ovens
Kenmore 700 trips breaker
Sounds like something is shorted in the unit.
Start at the power cord where it plugs into the wall, following down to where it enters the back of the refrigerator and look for any crimped or smashed places that may indicate the hot has come into contact with the ground (center wire.).
From there, you'll need to have basic trouble shooting skills to determine where the short circuit is. It could be the condenser fan, the evap fan, the compressor, or any number of other things.
Jan 24, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore freezer quit working after power outage
simple stuff, you have a compressor a stat and power. check the receptacle to be sure you have 120 volts . then check the compressor with stat at max cold setting to see if you have 120 volts at compressor. if you do then compresssor is bad =new compressor or new unit. if no power to compressor then stat is bad= new stat. i always recomend new unit cause new stat or compressor wont fix a freon leak.... i have replaced a few compressors that died soon after due to a freon leak. good luck...
Nov 23, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore Refidgerator is not cooling
let fridge cool down it sounds like the relay overload is bad try replacing it with a 3 n 1 start kit directions on the kit real easy to hook up... if the compressor starts then you are ok... hopefully the compressor is not burned out good luck
May 09, 2007 | Kenmore 50522 / 50524 Side by Side...
Kenmore 20.6 cu. ft. Top Freezer Refrigerator Logo
93 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
