Question about HP LaserJet 5000 Printer
Is the HP laserjet 5000 a good screen printer? I have some one asking about the machine and they want to see out puts with the page being a solid color. They specifically ask about this model. The only problem when you hold the output at a angle you see some lighter spots/lines where it is not as dark as everything else. It looks kinda like the machine was never designed for this kind of printing and also the issue looks like it might be casued by the paper running through the fuser and unevenly melting the toner, but I also set it up a strait pass through print and I got the same thing. Basically us the HP laserjet 5000 a good screen printer? and if you understand what I am talking about with the print quality is that a fixable problem?
    Problem Solver:
  • 19 Answers
I understand the question. You may have already have a solution. Anyhow, this model does not move fast enough not to make the fuser immpression. i would go with an older 8100 laserjet using a good aftermarket graphic toner cartridge. The 8100 or 8150 have hard rolles not the soft teflon film like the 5000 has, plus the move faster.
I hope this helps.
Posted on Jun 19, 2009
Black horizontal lines
recharge(with new OPC, PCR and mag roller) or try another cartridge - if problem not solved - fuser film damaged
Jun 09, 2013 | HP LaserJet 1320 Printer
I have a HP laserjet 5000 that is printing light. I've replaced the toner/fuser. I tried cleaning the laser scanner but that didn't help. I was told that the printers laser was possibly failing and that it...
Let's try going to the control panel and go to PRINT QUALITY/ECONOMODE=ON.
TONER DENSITY=5.
Now run some pages through.
If pages are good change the density to 4 and try again. If that didn't help, then you could be looking at "transfer roller","engine control board", "laser scanner", "high voltage supply".
Mar 30, 2010 | HP LaserJet 5000n Printer
Laserjet 5000 printing problems
HP Laserjet 5000 Printer
01.Try to install the catridge properly once again after rebooting the Desktop / Laptop along with this Printer.
02. Check through CONTROL PANEL whether this particular HP laserjet 5000 printer is showing in the printer menu.
03. If is there, try to remove offline and make online.
04. If this HP Laserjet not available in the Printer menu, please insert the Printer driver cd and install this printer.
05. Try to ensure your desktop or laptop not affected with Virus. There might be a change, if the machine is virus affected, Printer offline problem will be shown.
Have a good day.
Jul 17, 2009 | HP LaserJet 5000n Printer
HP Laserjet IIP Plus only prints solid black pages.
Best bet is to just get rid of this machine...machine is outdated and parts are few and far between.
Jun 04, 2009 | HP LaserJet IIp plus Printer
HP laserJet 5000 Printer continually printing same page
laserjet 5000 printer A4 size printing right side line not printing .why?
Jan 14, 2009 | HP LaserJet 5000 Printer
Only first page prints out with HP LaserJet 4 plus
i would say reinstall the driver, wouldnt be a schoolboys trick even sometimes the schoolboys know more than the teachers when it comes to technology.
Try the machines with a seporate machine thats a freash install and see it does the same thing, this a driver issue, and sometimes the students can hack into the machine and asking the printer to just print just one page of the document, you can select pages in a print box in word / Internet explorer for example.
And you can ask the printer to print two pages onto one page.
Oct 22, 2008 | HP LaserJet 4 plus Printer
Printer
You need to replace the fuser, here is an example of replacement part
HP Fuser for LaserJet 5000
These are instructions for replacement:
HP laserjet 5000 fuser instructions
Apr 24, 2008 | HP LaserJet 5000 Printer
NO RESPONSE, PRINTER DISPLAY BLANK
sounds like you have a bad formatter....there is a way to circumvent the formatter and print whats called an engine test. this is used just to test the mechanics of the machine and leave the brain out of the equation...
Engine Test Button Location HP laserjet printer 5000 series
The engine test verifies that the print engine is functioning correctly.
The Formatter PCA is completely bypassed during an engine test.
This test is very useful for isolating printer problems. The engine test
prints a full page of lines across the entire printable area, and is also
useful for checking and adjusting registration.
laserjet-5000-engine-test.jpg Note Engine test will print from the last input tray used.
If the last input tray is empty or if the last input source was the duplexer,
then the Engine Test will print from Tray 2 (standard 250 CST).
If Tray 2 is empty (and the last input tray is empty or the last input source
was the duplexer), then the Engine Test will not function.
Printing an Engine Test HP laserjet printers 5000 series
To print an engine test, use a non-metallic object (such as a pencil) to
press the engine test button. A single test page with horizontal lines
will be printed. To print multiple test pages, hold down the engine test
button.
If the engine test prints ok then you have a formatter issue...if you have added memory or a network card try taking them out one at a time to see if the problem goes away. Otherwise the formatter will have to be replaced.
Inkworks
Sep 05, 2007 | HP LaserJet 5000 Printer
HP LaserJet 5000 Printer Logo
98 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
