Question about Garden
I have a lazy boy tiller with chaine drive, its liked locked up. it will not engage, any help please ! it does have aplace to put oil on the side of the chine drive house. what kind of oil would it take? may be 90waite.thanks, cobraman
The gear box can be removed, reset and resealed using gasket magic. It is not a quick fix and during this process I also replaced the tine shaft seals as I had lubricant leaking from the gear-box to the tine shaft. When you are tilling you should avoid rocky areas. It iseems sudden tension due to bouncing is what knocks the chain loose.
DO NOT remove the belt pulley from the top of the gear box. It is unecessary. You must remove the entire assembly from the rear of the machine. It is set in place by 6 bolts and come off as a whole unit. Once it is removed then undo the three bolts and spacers that hold the case in place. Remove the case from the frame by sliding it out the open end. You will have to remove all of the bolts around the outside of the case; a cordless drill really comes in handy here. Lay the case on its side, as you remove the bolts you may experience lubricant dripping from the centers of the removed bolt holes, or at the center holes where the case connected to the frame. This is not a problem as you will need to replace the 90 weight lubricant after you have resealed the case anyway. Once you have removed all of the bolts, using a flathead screwdriver and a mallet or hammer. break the seal around the outside of the case. You may have to go around a few times, but eventually it will pull apart revealing the sprockets, bound chain and remaining lubricant. Since it is open this is an ideal time to check for wear on sprockets and remove any large debris from the case. reset the chain so that the tine shaft moves freely and the corresponding sprockets spin as you move the tine shaft. Using a gasket sealant (Gasket Magic**) put a thick bead of sealant in the center of flat outside edge where the two sides of the case come together. Add a little extra around bolt holes. Replace the two covers snugly together and begin finger-tightening the bolts back into the crank case. Once you have completed this task, go back over the bolts and tighten with a hand wrench. Once the case is back together allow 45m to an hour for the sealant to completly harden before introducing lubricant to the system. Then reattach the case to the rear assembly and then put your tiller back together.
This occurrence seams to be an issue with these machines, however the problem is avoidable as it is persistant use in rocky or hard ground areas which causes causes the system to jump and bind. If you happen upon a hard patch of earth or rocky area, go slow, do not force the tiller and remove any large debris when possible before tilling.
Posted on May 08, 2010
  • misty11656 Mar 14, 2011
    I am working on a tiller for my father-in-law. He says that one side of the tines won't turn. I have disassembled everything except the 2 inside tines. I can't seem to get them off to pull the case apart. I've used a wheel puller with no luck so far. Any suggestions?
I also have a lazy box 5HP front tine tiller mfg by Parma Tool co with the tines locked up. What I found out was the chain drive which is enclosed in the transmisson case had come off one of the sprockets an caused the tines to lock up. There is no way to access the chain or sprockets as they are enclosed in a sealed case. I am trying to find out if a replacement transmission case is still available. sorry I cant help with this.
John
Posted on Apr 10, 2010
How do I keep the tiller from bogging down when it goes in the dirt.
Adjust the depth bar on the back higher and push the handles down to rasie the tines somewhat.
Sep 12, 2014 | Garden
What size belt for lazy boy tiller
www.hyperparts.com/ope/LazyBoy-oem-list.htm
Jul 05, 2014 | Garden
I have a lazy boy front tine garden tiller. i want to have the proper amount of 90 wt gear oil in the transmission. I can see one hole with a plug that says gear oil. Do i fill the gear box up to that...
ITs not really a lazy boy brand is it? If we a re talking about garden tillers... then if the fill hole is on top the oil level should be about 1 ( one) inch below the hole. If the hole is on the side of the gear case then it is a peep hole and should be filled till fluid runs out.
Oct 24, 2012 | Garden
TILLER WILL START/RUN BUT BLADES DON'T MOVE..TILLER PART DON'T MOVE? MTD21AH413B129287-424
Hello, W/D here.
The motor drives a belt, and the belt drives a pulley that causes a chain to drive the tines (blades). For the belt to drive the tines, an idler pulley has to put tension on the belt. This is moved into position by a lever that pulls the pulley into tension on the belt, and tension is maintained with a spring when the lever is locked into place.
1. Make sure that the tines will rotate with the belt off. If there is difficulty, check for debris holding the tines (roots, etc.). If necessary, remove the cap covering the chain cover inspection port, and with the machine tilted back, observe for proper operation of the chain while moving the tines by hand. Lubricate the chain according to your manual. If your chain is not working properly, disassemble down to the chain case, and inspect the chain and sprockets. Chain is radily at places like Motion Industries, WW Grangier, or a bicycle shop. Often overlooked, check that the pulley set screws are tight, and causing the shaft attached to it to actually rotate. Check the pins and locking cotter pins in the tines, make sure that they are pinned to the shaft.
2. Check the belt. An old belt can stretch to the point where it will no longer work. The "V" belt can also wear down to where insufficient friction can be applied to the driving or the driven pulleys to cause it to rotate.
3. Check the condition of the idler pulley and spring. Make sure that the lever places tension on the belt. It should be somewhat difficult to engage the idler pulley when the belt is new. You may have an adjustor on the idler that will tighten the belt.
Best regards, --W/D-- Please provide feedback for our solutions so that we may continue to improve in helping others. Thanks.
Feb 24, 2011 | Mtd Products Yard Machines 158CC Tiller
I have A 5hp lazy boy garden tiller. The chain assembly is locked up and A hole has worn in theright side of the housing beyond repair. Can you tell me where I can get A transmission chain assembly to...
the chain will be standard pitch and width so any bearing supply shop will have a chain to do the job
take the old chain as a sample for the measurements
Dec 17, 2017 | Garden
Tiller goes For./Rev. but wont drive forward with tines engaged
check the sher bolt on the tine to drive shaft. ill need model and ser number off the unit before i can go further with helping you thy changed them around a lot
Oct 09, 2009 | Mtd Garden
Rototiller won't engage into gear
You will need to split the gear case if iam not mistaken it has chain drine the chain links break and you have to replace them
May 09, 2009 | Garden
Garden Logo
2,244 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
