Question about GE Refrigerators
GE refrigerator/freezer - defrost noise
I have a GE refrigerator, model GDS20SCSBSS, with a noise problem. I believe the noise comes from the frost free freezer. It has the freezer compartment on the bottom. No icemaker or water dispenser. The frost free feature comes on about every hour or so. When it was new it was very quiet at melting accumulated ice. It's a little over a year old now. A week or two ago it started making a loud noise similar to a electric alarm clock whenever it melts the ice build up.
Everything else about the refrigerator works fine. How can I shut this thing up, or at least quiet it down?
    New Friend:
  • 62 Answers
Blow it clean or check for loose bolts or broke springs.
Posted on Apr 18, 2017
fridgetech
  • 473 Answers
SOURCE: frost in freezer compartment
It is possible to get this build up in the return vents.  Check seals for any possiblilty of warm air getting into the fridge.  Warm air getting in will cause this.  For now use a hair dryer or some hot water to clear the vents.  Let me know what you find.  Would appreciate a solved rating for expert advice.
Posted on Oct 18, 2007
  • 409 Answers
SOURCE: HSS25IFMDWW- freezer frosting up but working
sounds like the defrost thermostat or you may have a crack in the water line causing the freezing.
Posted on Sep 13, 2008
SOURCE: Icemaker seems to partially melt ice while it is being stored
The number one cause of this is the door is not sealing correctly. Check that the door closes and seals as it should.
Posted on Nov 16, 2008
  • 85 Answers
SOURCE: 11 year old amana bottom freezer icemaker drips water when filling tray
as long as the temp in the frz is normal. the i/m could have a bad thermostat that, could be causing it cycling too soon or the tray is leaking water. either way i/m needs to be replaced, sorry
Posted on Dec 14, 2008
  • 15 Answers
SOURCE: Frost gathering in freezer, icemaker dispenser freezes over
well check to see if door seal is split if it is get new one!! need to see photo of the frozon over dispenser- found before that when ice not bein used alot the odd time you will have to take out the ice in the bucket crack it up and put back in try this???
Posted on Feb 03, 2009
Ge refrigerator model gss22kgmc
check defrost element, if good check defrost thermostat, if good change defrot timer/control board depending on your specific model you can look at this link provided its a diff model but none the less quite similar
am searching for Main PBA for fridge freezer model no SRL 629EV The number...
Sep 02, 2014 | GE GSS22KGMBB / GSS22KGMWW / GSS22KGMCC...
GE Profile Model PTC22MBMBRCC Counter Depth Refrigerator Noise
you have a defrost issue which need to be dealt with. the fans is hitting the ice that has formed after 5 to 10 days of not going through a proper defrost phase, you either have a bad defrost controller, def t-stat, or def heater. and can easily id the issue
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
Apr 16, 2012 | GE Refrigerators
We have a GE 22.2 Cu Ft refrigerator that gets frost in the freezer. How can we avoid this?
if there's frost on the back inside wall of the freezer and the fridge is getting warm you have a defrost problem,or if frost is on packages and racks the door could of been left open or the door where the ice comes out might not be closing properly.if it's a defrost problem you could have a bad defrost fan motor,you wouldn't hear the fan turn on when you open the freezer door,a bad timer or board,you didn't send the model number,bad heater or thermostat or loose wire.
Apr 09, 2011 | GE Refrigerators
Refrigerator temp hovers around 59F - why won't it stay at 34F when I want it to?
Will you look into the rear of the freezer and see if a layer of frost is building on the rear panel. If yes this will indicate a defrost problem most times noticed by rising fresh food temperatures. Try to locate the model number around the door frame and see if you can find the exact model number. I may be able to find a model number by searching GE 22.3CU.FT Bottom Freezer Model Numbers. I believe the most likely reason for this will be a defective defrost heater and possibly defrost thermostat, Sea Breeze I will return with part numbers.
Apr 21, 2010 | GE 22.3 Cu. Ft. Bottom-Mount Refrigerator...
GE Side by Side Heating Up and Frost on Panel in Freezer
sounds like your defrost heater termanator switch,or defrost timer is bad-mike
Jan 22, 2010 | Refrigerators
Ice melting and frost forming on freezer side, funny sound coming from freezer side. No condensation in back of fridge. Help for a new home owner.
check that your flapper on the ice shut through the freezer door is fully closed,
make sure there is no ice forming around your evaporator fan, thats the fan in the freezer, if that gets glogged with ice and is forced to stop, it could blow your entire machine control......
the frost in the freezer leads me to believe you may have a defrost issue
Oct 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Humming and frosting in freezer
Your defrost has stopped. Either the defrost heater, bi-metal or the control board has failed.
Sep 10, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE refrigerator model PSS27MGMBB Freezer is not working
Open the freezer door and look at the back wall. If there is frost on the back wall, you have a defrost problem, which means air cannot circulate over the cooling coils located behind the freezers back wall. You will have to remove the back wall and melt all the frost with a hair blower, then replace the defrost heater. (part number WR51X10055) . This is assuming that the fan by the compressor and the one inside the freezer are working.
Jul 01, 2009 | GE PSS27MGM Side by Side Refrigerator
GE PCG23NHMF side by side fridge freezer - stopped cooling
Although this machine is supposed to be frost-free (i.e. automatic defrost), there was a build up of frost. We manually defrosted the machine, then restarted it - the noise has stopped and the freezer and fridge are now working. However, this may be a temporary solution.
Jan 18, 2009 | GE GSS25LGM Side by Side Refrigerator
Red glow (from defrost heater?) at bottom of rear panel in freezer
This is from the GE Appliance "Knowledge Database" Web site:
Refrigerator - Explanation Of Red Glow
In a no frost refrigerator, the defrost timer activates defrost heaters in the evaporator section (rear of freezer) which heat up and melt the frost off the evaporator coils. This process lasts for approximately 25-45 minutes and usually happens up to twice a day.
During this time, there will be no running sounds, no fan noise, and you may hear water dripping or sizzling as it hits the heaters. On side by side models, you may even be able to see an orange glow at the bottom of the freezer.
This is normal.
Aug 06, 2008 | GE GSS20IEP Side by Side Refrigerator
Refrigerators Logo
165 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
