Question about Hoover HFA270K Bottom Freezer Refrigerator
My fridge in my fridge freezer keeps freezing everything in it.
My fridge is all frozen up at the back.and everything is frozen. tried turning thermostat down but makes no difference.doesnt seem to defrost itself.door seal is ok.drain pipe is clear.everything at back of unit seems ok.freezer seem to work ok.
  • Hoover Master
  • 3,361 Answers
If the fridge side is frozen you have a door seal issue.
If the freezer side is frozen you have a defrost component issue.
Your post was not clear as to which side is frozen.
Posted on Jun 16, 2009
Freezer will not freeze ice ceam
Before you go any further it is important that you check for freezer temps. Yes, you have frozen items but remember that water freezes at 32 degrees and many items will get hard at that temp. And also remember that the lower the temp the longer frozen items will keep.
But ice cream needs proper freezer temps close to zero degrees. Use a digital thermostat and check for your freezer temp - bet it it is no where near zero. I had the same problem and attributed it to the fact that I was not using a name brand ice cream!!!! I was wrong ! LOL.
Aug 31, 2015 | Refrigerators
I have a model MTB1956GE Maytag Fridge, Frezzer
Can you feel air moving or hear the fan running in the freezer section? You said the freezer section is freezing well, but is it freezing really hard?
Regards,Richard
Dec 12, 2011 | Maytag MTB2156GES Top Freezer Refrigerator
Water does not work. Possibly frozen line. i keep
I have a GE PSS25SGNA no ice no water freezer side is reading -2 refrigerator side 25 everything is freezing help
Jan 03, 2011 | GE PSS25SGNBS Side by Side Refrigerator
Fridge freezing up
Check the fridge sensor. On my Hoover HNMF2805AL80 f/f, first I replaced control module - still freezing.
Have just replaced cheap fridge temperature sensor. Part No. 97061619. Trouble is you have to cut into insulation at back of fridge to replace. I just plugged in sensor & placed inside fridge at back at the bottom - so far so good, only lettuce freezing now, everything else v. cold but not frozen. :)
Jun 02, 2010 | Hotpoint RLA50 Refrigerator
My daughter's mini fridge has a freezer compartment. Her issue is, if she turns it up high enough so the freezer freezes, the fridge compartment also freezes everything; if she turns it down so that the...
This is a drawback of most mini-fridges. Start by defrosting everything. Then fill ice cube trays with water and keep lowering the setting until the water freezes. Just go a little lower, no more. Fridge should not freeze food. If the fridge stays closed all the time food will freeze. Also if the freezer element gets ice buildup it must be defrosted. Not automatic like home fridge. Most kids today weren't born when the last fridges that had to be defrosted were in service.
Sep 01, 2009 | Refrigerators
Amana BR18 Doesn't get cold
Mine is doing the same thing
Jul 05, 2009 | Amana Freezers
Fridge side began freezing everything then the fan
Generally speaking, sounds like you may have the frozen condensor problem that is so common
because of the design flaw in the Samsung products.
Turn it off, empty the freezer.
Study the back and look for formed ice around the seams.
So it got too cold, and now it is still too cold, or not cold enough ?
May 08, 2009 | Samsung RS2556 Side by Side Refrigerator
Samsung refrigerator freezer not freezing
-2 although below freezing temperature, is not really enough to keep food really frozen. I am presuming we are talking in Celcuis. You need to set the freezer to a lower setpoint.
Mar 09, 2009 | Samsung RB215LASH
GE Frigerator has intermittant Freezing
It sounds like the defrost heater is burned out. Remove the inside back cover in the freezer to see if the coils are frozen up. If so, more than likely your defrost heater has bit the dust. It is located at the bottom of the inside coil of the freezer.
Also, you could be have a clogged condensor coil. It is located on the out side back of the Fridge. You need to remove the panel from the lower part of the fridge and do a thorugh cleaning.
Nov 01, 2007 | Refrigerators
Hoover HFA270K Bottom Freezer Refrigerator Logo
589 people viewed this question
Top Hoover Refrigerators Experts
Charles T Nevin
Charles T Nevin
tom wright
tom wright
JONFRIDGEDOC
Level 1 Expert
Are you a Hoover Refrigerator Expert? Answer questions, earn points and help others
