Question about Brother IntelliFAX 775 Plain Paper Thermal transfer Fax
My friends fax machine, a brother intelifax 775 keeps having the message ''TAD''. She can not locate the manual and this is keeping her from operating her office like she would like to. Can you help with this?
    President:
  • 3,085 Answers
TAD means Telephone Answering Device like an answering machine.
Posted on Jun 16, 2009
I have changed from a desinated fax line to sharing a phone and fax line. the fax machine rings along with the phone however the fax does not answer. i was told to purchase a ring decipher but cannot...
Your fax can share the line with your phone, but it needs to be set to answer or not, depending on your equipment and choices.You can download the manual from Brother here. The receive modes are explained on page 5-1.
If you're often out when faxes or phone messages might come in, you probably need to plug an answering machine into the back of the fax (the EXT. jack) and put the fax in FAX / TAD mode. (TAD stands for Telephone Answering Device. Be sure the TAD is set to answer before the fax does. The fax will pass the phone call through to the TAD, and if it hears the beeping of another fax sending, it will cut off the TAD and take the call.
See the manual for more info and other options.
Feb 15, 2011 | Brother IntelliFAX 2600 Fax
I am unable to send a fax brother intelifax 775 fax manual
go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set.
make sure the phone wire which you insert in fax machine getting proper dial tone and getting out going calling facility.
Hope this helps. Please rate my response.
Thanks.
Have a good day
Dec 24, 2010 | Brother IntelliFAX 775 Plain Paper Thermal...
My intellifax 775 has a code TAD...what does this mean? Will not receive faxes
This means your receive mode is set to TAD or telephone answering device. If you have a dedicated phone line it should be in Auto or automatic receive. There is a button on the panel to change the mode to auto.
Oct 20, 2009 | Brother IntelliFAX 775 Plain Paper Thermal...
Can't receive fax when on "TAD" but answering machine works and when on "F/T" can get fax but answering machine won't work
this fax works on one mode at a time either TAD (Telephone Answering device) or F/T (Fax/Tel). so you can't use both at a time. Thanks
Aug 08, 2009 | Brother IntelliFAX 775 Plain Paper Thermal...
Brother Inteifax 775 will not send fax
change the mode from TAD to F/T by pressing mode button on panel
Thanks
May 19, 2009 | Brother IntelliFAX 775 Plain Paper Thermal...
Cannot send a fax
Change the mode from TAD to F/T by pressing mode button on front panel . Thanks
Setting personalized ring
Its called distintive Ring. This is the instructions from the manual -
VERY IMPORTANT
If you have Voice Mail or a TAD (Telephone Answering Device) and want to keep
one of your phone numbers dedicated only to fax calls, you must leave the fax machine
in MANUAL mode at all times while using the distinctive ring feature. Here’s why:
Manual mode will never pick up a call by itself, since it is «Neutral ». When the fax
machine is in this « neutral » mode, the Distinctive Ring Feature can be activated. The
distinctive ring feature is actually an answering mode. So, do not activate FAX ONLY
mode or FAX /TEL mode while using distinctive ring; otherwise, the fax machine will
answer calls for all the numbers.
Registering the Distinctive Ring Pattern
Set the fax machine to MANUAL mode.
2 Press Menu/Set, 0, 1.
3 Press to select DISTINCTIVE:SET?, and then press Menu/Set.
4 Press to select the prestored ring pattern you want to assign, and then press
Menu/Set. (You will hear each pattern as you scroll through the four patterns.)
Be sure to choose the pattern assigned by the Telephone Company.
5 Press Stop/Exit.
and a link to the manual if you need it -
http://static.tigerdirect.com/pdf/brother-IntelliFax-775-Manual.pdf
Feb 21, 2008 | Brother IntelliFAX 775 Plain Paper Thermal...
To recieve fax on brother
Press the 'RECEIVE MODE' button on the right side of the control panel, its next to the large 'FAX START' button. Here are your options :
Select Receive Mode
MANUAL
—You must answer all calls yourself. If you hear fax tones, press
Fax Start
to begin receiving the fax, then hang up. You can use this mode with
Distinctive Ringing. (See
Distinctive Ring
, page 8-1.)
FAX ONLY
—The fax machine automatically answers every call as a fax call. You
cannot receive a voice call, but you can dial out and make a voice call.
FAX/TEL
—The fax machine automatically answers every call. If the call is a fax, it
prints the fax. If the call is not a fax, it signals you with a double-ring (ring-ring),
different from the phone company ringing, to alert you to pick up the call. If you select
this setting, you’ll need to set the Ring Delay and F/T Ring Time features (on the
following pages). If you have extension phones on the same line as the fax machine,
set Ring Delay to 4. (See
For FAX/TEL Mode Only
, page 5-5.)
TAD:ANSWER MACH.
—This is the only setting in which you can use an external
answering machine. Your telephone answering device is connected to your fax
machine, and answers every call. Once the TAD answers, the fax machine listens for
fax tones. If it detects fax tones, it prints the fax.
The TAD setting works
only
with an external telephone answering device (TAD); it
does not work with telephone company Voice Mail. Ring Delay and F/T Ring Time
do
not
work in this setting.
Nov 27, 2007 | Brother IntelliFAX 775 Plain Paper Thermal...
Brother IntelliFAX 775 Plain Paper Thermal transfer Fax Logo
132 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
