Question about NetGear WGR614 Wireless Router
Connecting the routerwgr614
How do i connect the router to computer no directions here to help me
  • Chuck Brink May 11, 2010
    are you trying wired or wireless? Goto www.netgear.com for the manual.
    Sergeant:
    Champion:
  • 310 Answers
Try this link http://kb.netgear.com/app/answers/detail/a_id/119/c/3/p/15,21,164,215,242,/r_id/166
Its pretty simple.
Hope this helps
Thanks
Ranjit ranjit@supportminds.com
Posted on Jun 16, 2009
How to config Wrt160N Router
192.168.1.1 usually. or 192.168.0.1 hope this helps
Jul 26, 2014 | Cisco Computers & Internet
Verizon dsl and cisco valet
Connect your computer directly to the Internet modem and make sure that you have Internet access directly from the modem.
If that is working properly then connect the modem to the Internet port on the router. Connect the computer to port 1 on the router.
Reset the router and configure it manually.
Here is link which will help you troubleshoot Cisco Valet M10 or M20 router
Mar 01, 2014 | Linksys by Cisco Cisco Valet Plus Wireless...
My computer is not connecting to my Dynex wireless router. I've called my locate cable subscriber and they told me that it's a router problem. I've disconnected the router several times and it shows that...
First off, verify that you can connect to your cable modem directly. After that, hook up your Dynex wireless router and reboot your cable modem. After this, directly connect your computer to the Dynex router (using a cable). If you cannot get an Internet connection, then there is some issue with your Dynex router configuration. It's possible that there might be an IP address conflict with the cable modem. It would be best to contact support for configuring the Dynex.
If you can connect to the Internet with your computer connected directly to the Dynex router, then there must be some router configuration problem affecting your ability to connect wirelessly. You'll have to check the configuration--might be a good idea to completely reset the router and start over. If that doesn't help, you should contact Dynex customer support, as each router has its own configuration specifics. Good luck.
Nov 07, 2010 | Computers & Internet
I can connect to the router but the router cant connect to the internet. If i directly connect the internet connection to my pc, it has internet connections, so the router is not connecting to the...
Firstly please check the connections. The modem should be connected to the "Internet" port on the back of the router. And the computer can be connected to any of the 4 ports of the router. Checked the lights. They should be steady. If you have a cable connection (cable modem) than you can connect directly to the internet. Else if you are using a DSL connection than you need to configure the router according.
**If this works please rate else let me know in case of further help.**
Jul 01, 2010 | Linksys WRH54G Wireless Router
Cannot connect to my wireless router
If you connect the computer directly to the modem, it works .
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Dec 19, 2009 | Computers & Internet
Lost internet service on laptop
First, are you wired or wirelessly connected to the router? Is there any computer that is connected to the router aside from the problem one?
If you are wired connected to the router, try connecting the Ethernet cable into different LAN port of the router.
If you are wirelessly connected to the router, try disabling and re-enabling the WiFi of your laptop and try connecting again.
If there's another computer that's connected to the router and it can get online, then the problem is in your computer. Checked the Network properties of the problem computer and make sure that you are getting a valid IP address.
If you have two computers and both of them are not getting online, try connecting first one of the computers directly to the modem. If same problem occur, then contact your ISP.
If you can get online while directly connected to the modem, then turn the Netgear router OFF for about a minute and turn it back on and try again.
Hope this helps and have a good day!
Nov 29, 2009 | Computers & Internet
Cannot get to the internet using this router ...does it need to be connected directly to a computer? we have it connected to the modem
For the initial set up of the router , the computer should be connected to the router.
Once you set up the router then you can use it wireless.
Are you able to go online when connected to the modem.
Click Here to know more about network and router
Oct 25, 2009 | Linksys Wireless-G WRT54GS Router...
My internet connection requires username and password then how can i store it on my router also it has mac address filtering
To configure the router to store your ISP username and password, please perform the below steps:
1. Connect a computer to the router using any one of the 4 available ports.
2. Open the browser (Internet Explorer, Mozilla Firefox or Safari).
3. Access the router usually by typing 'http://192.168.1.1' or 'http://www.routerlogin.com' in the address bar.
4. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
5. Click on Basic Settings in the left hand side menu and for the first question :Does your internet connection requires a login. Make it yes and enter the required information. Click Apply
Check the below image for more clarification:
http://www.ziddu.com/download/6912448/RouterWGR614.JPG.html
Let me know if you need any further assistance.
Regards
Anand
Oct 13, 2009 | NetGear WGR614 Wireless Router
Belkin Wireless G Plus MIMO router - connectivity problem
  • this problem can be ISP releted they may have some issues on the ADSL line connection
Aug 10, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
No wireless connection
Go to Parental Control after logging into 192.168.10.1. Then make sure you have allowed the MAC addresses of the wireless clients ( machines). Reboot the router one after making any changes.
Good Luck
Dec 14, 2008 | Arris Wireless G Broadband Router (wr850g)
NetGear WGR614 Wireless Router Logo
52 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
