Question about Microsoft Windows Vista Ultimate Edition
EXACTLY THE SAME
TRY TO UNINSTALL NERO 9 USING AD AND REMOVE OPTION AND WHEN I CLICK ON REMOVE DIAGNOSIS BOX APPEARS AFTER A TIME SAYING OK BUT IT IS STILL THERE
  • 56 Answers
If Nero is still showing in Add/Remove programs after your reboot your PC, you can try using the Microsoft Windows Installer CleanUp Utility.
You can find it here with directions from Microsoft on how to use it.
Posted on Jun 16, 2009
Every time I try to uninstall trial version of Nero 8, I get a box saying "Shellmanager database is corrupt or missing. How do I uninstall, please
Nero has its own "clean tool" which you can down load here: http://www.nero.com/eng/tools-utilities.html#tab4
Down load the utility and then run it to completely remove Nero 8
Mar 29, 2011 | Ahead Software Nero 6.0 (60045) for PC
Im trying to uninstall lg pc suit but everytime i try it says its still running, but i dont know how to stop it to remove it
The simplest way around this problem is to enter Safe Mode and uninstall it.
1. Restart PC
2. Press F8 until Windows Boot Menu appears.
3. Select Safe Mode
4. After Safe Mode finishes loading, press Win+R to open the Run command.
5. Type APPWIZ.CPL into the dialog box and press enter.
6. Allow Add and Remove Programs to fully load.
7. Scroll down to the LG PC Suite, select it, and then click Uninstall/Change.
8. Uninstall the program.
9. Restart computer.
If you don't want to go to the hassle of entering Safe Mode, then another option would be to open Task Manager and end any process affiliated with the LG PC Suite. Then you should be able to uninstall the program.
Good luck and thanks for using FixYa.
Mar 09, 2011 | Computers & Internet
My LG mobile keeps saying maximum number of applications reached each time i try and send a text HELP
That means there isn't much memory left. You will have to delete some applications:
The uninstall processes on LG Incite mobile phone are not complicated, three ways you can choose below according to situation/setup. LG Phone Problem and solution
1. Uninstall Apps Using ActiveSync LG-Incite info
For Windows XP and below users will want to use the ActiveSync program. You can download ActiveSync 4.5 here.
Once downloaded and installed on your desktop ActiveSync uninstalls are one of the easiest ways to remove unwanted programs, simply follow the directions below:
  1. Connect your LG Incite to ActiveSync
  2. Click on the "Tools" option
  3. Click Add/Remove Programs
  4. At this point you'll see a screen that lists all of your devices programs, each program will have a checkbox to the left of the programs name and all of your programs will have a checkmark located next to their names.
  5. Take out the checkmark in each program box you'd like to uninstall.
  6. Click "OK"
It's really that simple, your LG Incite will take a moment to uninstall the unwanted Windows Mobile Apps you chose and then you're done.
2. Uninstall Apps Using Windows Mobile Device Center
If you're a Windows Vista desktop user there's no reason to download ActiveSync, partly because it won't work, but more importantly because Windows Vista comes standard with the Windows Mobile Device Center, a device to desktop sync application that functions in much the same way as ActiveSync 4.5.
Uninstalling Apps with Windows Mobile Device Center is a simple process if you follow the quick steps below:
  1. Connect your LG Incite via USB to your desktop to launch the application.
  2. Click on the "Programs And Services" option
  3. Click the "More" option, You will now see a program box similar to the one found with ActiveSync 4.5.
  4. Each program will have a box with a checkmark, find the programs you'd like to uninstall and uncheck that box.
  5. Click "OK"
The unchecked programs will now uninstall from your device, its really that simple.
3. Uninstall Programs Directly From Your Windows Mobile Device.
You don't have to use a computer to delete programs from your LG Incite, if you're on the go uninstalling apps directly from your system once again involves only a few quick steps.
  1. Go to your "Start" button
  2. Go to "Settings"
  3. You'll see a "System" tab, click on that tab.
  4. Then go to "Remove Programs"
  5. Choose the Application you want to remove and highlight it.
  6. Click "Remove"
Your LG Incite will now remove the highlighted application.
Personally I usually use my computer for deleting apps just in case anything goes wrong during the uninstall process, however i've rarely heard of people running into Windows Mobile uninstall issues when doing so from their devices.
Conclusion
The 3 uninstall options listed above are the easiest ways to uninstall apps from your Windows Mobile based Pocket PC and Smartphone devices.
If these steps don't work your best bet may be to use the "Clear Storage" option on your Windows Mobile device and start your device with the standard fresh install, but hopefully it doesn't come to that."
Feb 28, 2011 | Cell Phones
I am starting to see we are sorry,but an internal error occured please reinstall the product to fix the problem. error-code:1/-3/10900 see doc#5305 And again the INCD helper service is not correctly...
That INCD service or component is a part of Nero. It gets installed with Nero. This was a common problem of Nero 7. What you can do is uninstall and re install the product. You have to use an uninstaller program available (such as your uninstaller) to remove the registry keys as well. Its clearly indicating that the programs is not successfully installed. Note: If you try to install Nero 9 in a Windows XP SP2 environment or in a Windows 7 environment you might receive the same error. Those are compatibility issues. You have to use SP3 in XP and you have to purchase Nero 10 for Windows 7. Incd is not necessary to function Nero. Try to install without Incd. You can do that while installing. Choose the Customized Installation. If you are using Nero 7, I recommend to use Nero 6 or 8 and upwards.
You can download Nero from their web site or using a torrent as well. Some funny things may happen when Nero gets installed partially. Go to Properties by Right Clicking the Taskbar and untick "Hide inactive icons" check box. Click on "Customize". Check the "Behavior property and for the programs which have the setting "Always Hide", select "Always Show" option. Then Apply and click on OK button.
Contact me further if you still have the problem. If the solution works for you please be kind enough to rate the answer as well :-)
Jun 09, 2010 | Computers & Internet
I have my nero installed but i did not enter the license key yet, how can i enter it?
You have to start Nero Control Center then select 2nd option License and there you have to put your product key and click on add.
iTechGuru
www.itechguru.in
Mar 29, 2010 | Ahead Software Nero Ultra Edition 6
I'm Trying To Delete The Program Nero 9 and it Saids This Program Requires The File Advrcntr4.dll,Which Was Not Found On This System
HI,
First download and install revo uninstaller from this website:
www.revouninstaller.com
next after you install it you will see Nero 9 in that and just click on it and then click on Uninstall at the top click next the applications uninstaller will begin then you need to uninstall it.If it says that it cannot be uninstalled or says that dll was not found cancel it and then on revo uninstall again click on next it will scan for registry files then you need to check all bolded registry items and then click on delete.Make sure you only tick bolded items dont remove then ones which are not bolded this will crash your pc.
After you are done with that then it will scan for left orver files and you need to click on slect all and then click on delete.Thats all you will be able to reinstall Nero;
Aug 02, 2009 | HP Pavilion a6400f Desktop PC -...
I can't uninstall my nero 7 essentials
try to reinstall it and then uninstall then reinstall it should fix your problem unless the computer is not up to date
Jun 28, 2009 | Ahead Software Nero 7 Essentials Suite...
Unable to uninstall Nero-
Vista is very picky - and you have to have at least version 7.5.9.0, or newer (but, with my vista 7.5.9.0 worked). Since you have nero-7 you can download the latest and use your key from your current nero-7 cd.
Mar 30, 2008 | Ahead Software Nero 6.0 (60045) for PC
Microsoft Windows Vista Ultimate Edition Logo
62 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
