Question about Electrolux Freezers
Does not seem to be running and feels warm its making a noise but not cutting in to keep it cold
    Sergeant:
  • 340 Answers
Could be bad compressor. ta
Posted on Jun 17, 2009
My Fridgidaire upright Gallery freezer is freezing my food but the appliance seems to be constantly running and the temperature control on the outside is reading 29 Celsius when it obviously isn't
Hi Susan Abboud - Modern freezers have increased storage capacity and keep more even temperature that may require the compressors to run longer but use less energy. Was the unit disconnected previously for any reason? If so, freezer requires a minimum of 4 hours to cold down completely. Confirm that the temperature control is not set too cold and that the door is not being open frequently. A dirty, cracked, worn or poorly fitted door gasket can allow warm air to enter the unit causing it to have to run longer to remove the warm air. Leaks in the door seal will cause freezer to run longer in order to maintain desired temperature. Cleaned the gasket, if it is too damage then it will need to be replace. You can check and see if the door seal is bad by, placing a dollar between the gasket and cabinet. Check to see if the door is being blocked by anything stopping it from closing properly. If nothing is stopping the door then replace gasket. Keep in mind that there should also be at least 4-6 in of air space on all sides of the unit. If freezer is built in or has items stored on top that cover the unit, the can cause long run times, high temperature in the freezer and premature failure to the unit. Do not block the toe grille on the lower front of the unit. Sufficient air circulation is essential for the properly operation of your freezer, about 3 inches around the unit.
Nov 22, 2012 | Frigidaire 20.6 cu. ft. / 583 liter...
Mdle 21571 upright Kenmore Freezer seems to run all the time and seems warm to the touch. It is keeping cold but the running all the time doesn't seem right.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 02, 2011 | Kenmore Freezers
I have a manitowoc commercial ice machine.It has stoped making Ice and just seems to keep running water and not freezing
Check to see if the compressor is running... if it is running and not cooling then it may have a refrigerant leak...
If the plate is getting cold but the water is not freezing then check to make sure that the float is not stuck on and the the water just keeps running in... that will keep the water warm enough so that it does not freeze...
heatman101
Mar 10, 2011 | Freezers
I put in 35 quarts of applesauce last night and this morning everything in door and top shelves were defrosted. Is it not working?
If you put 35 quarts of warm applesauce in there you probably defrosted it iwth that....I as long as it seems to be running and you can feel cold air I would give it more time...
heatman101
Sep 03, 2010 | Freezers
Bosch KGV3120 fridge freezer , compresor not cutting in occasionally and food in fridge gets warm , food in freezer gets a little soft. all lights running.If i unplug /switch off & re-start the unit...
I am not sure but just for good measure>>>
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Jan 26, 2010 | Freezers
2 year old Kenmore freezer won't keep cold. It
Check underneath the unit and make sure the compressor is running and that the compressor fan is turning.
Oct 15, 2009 | Freezers
Freezer very cold, no air going into fridge it warm ANY SUGESTION
hi there,
check the blower fan inside evaporator,there is fuse on the back side of your refrigerator for cooling fan,check on this using multi tester if busted replace fuse.
Jul 06, 2009 | Maytag 15 cu. ft. / 425 liter Upright...
Freezer defrosting
If this is a frost free freezer you may be he\aring the fan motors run and not the compressor. I suggest you call a qualified and trustworthy repairman and have him look it over for sure.
Short if that you'll need to feel of the compressor to see if its hot or cold. Vibrates or not. See if the fan motor under it is running or not. See if the inside fan is running or not
If either fasn is out start there as to why and effect repairs. If the compressor is cold It hasnt been running for a while and you will need to check voltage at the compressor and if t\you have voltage there you need to try new start components to see if it will run. If no voltage there check the thermostat (and if self defrosting) the defrost timer.
After this you can see why I suggest you call a quiulified repairman. way too many things to consider and keep you from making a correct diagnosis
If this helps you polease rate me as high as you can and thank you for using fixya.
May 19, 2009 | Freezers
Amana 25. cu ft..freezer not working...making rattling noise now and then
Check the defrost timer, rotate it until a solid click is heard. If your unit starts to work replace that timer. Good Luck
Aug 05, 2008 | Amana 16.8 cu. ft. / 476 liter Upright...
Freezer making noise & left side of the freezer (on outside is very warm to touch)
Sounds like the freezer evapurator fan... they make noise on and off at times when bears are wore... Thats about the only thing that can make noise inthe area ur talking about.. if noise comes back listen where the freezer fan is.. is most liklly the problem
Nov 02, 2007 | Freezers
Freezers Logo
61 people viewed this question
Top Electrolux Freezers Experts
Dennis Boxerman
Wayne Tolonen
Are you an Electrolux Freezer Expert? Answer questions, earn points and help others
