Question about Bebecar Racer ST Jogger
Wheel problem My front wheel is wablely and I can't walk too fast or the whole stroller shakes.
    Scholar:
  • 91 Answers
You need to adjust the screws on the top of the mudguard. This is mentioned in the instructions. To obtain instructions email service@bebecar.co.uk
Posted on Jul 23, 2009
Shaking wheel on graco trekko
I am assuming you have lubed the wheel with a silicone based spray lube.
Is it wobbling with the wheel in the locked position? Th only reason a wheel can wobble is if the axle and the actual wheel have too much play. A thin shim washer may tighten the axle to wheel spacing. Most hardwar stores will have thin washers. Give it a try. Your manual made no reference to wheel maintanance so if you purchased it new I would call Graco and complain. If used, try to eliminate the problem. If you need it here is your manual.
Graco Trekko Manual
Apr 26, 2012 | Graco Trekko 3-Wheel Stroller
Our stroller shakes when pushing forward (very badly - would shake the baby out of the stroller if we had her in it), but if you pull the stroller back it appears to cease shaking. Is there something...
You don't mention what make / model you have. Try turning stroller upside down ( without baby in it *-) ) and spin each wheel to see if it runs freely. Try to rock the wheels from side to side to see if there is any play in the axel. On a flat smooth surface do all wheels touch the ground? If the front wheels swivel do they rotate freely without any side to side play? Some strollers have nuts you can adjust others just have Silver domes. Try tightening nuts till wheels get tight then back off just enough so they spin freely try taping domes on tighter using a large socket from a socket set and a hammer so the pressure is around the edge of the dome and not in the centre where it would dent. Silicon spray is the best lubricant for strollers.
May 09, 2011 | Bertini Baby Gear
The front wheel shaking if i go faster than a very slow walking speed. Apparently it needs to be locked in order for it not to shake. And i found a small ball from the bearing i think.
The lock for the front wheel is a little plastic clip that should be just above the wheel itself if you push that down it should stop it from shaking
Hope this helps
Mar 02, 2011 | Baby Jogger City Elite Stroller
My front swivel wheel shakes about 30 seconds into our walk. What is causing this? Can it be repaired?
Hey there,
Its hard to say what exactly the problem is but here are seem things to try.
If you turn the stroller upside down you should see 4 screws (2 on each side) right by the front wheel on the underside of the stroller. Make sure those are in tight because if they are loose they can cause shaking in the stroller. Also make sure that the wheel is screwed in tightly to the wheel base as well.
If these steps dont work then you might need to order a replacement for the front wheel. This can be done by calling customer service of Kolcraft at 800.453.7673 or you can email them at customerservice@kolcraft.com.
This is their website : http://www.kolcraft.com/customer-service/replacement-parts/
Hope this helps!!
Mar 01, 2011 | Jeep Liberty Urban Terrain Jogger
Babyjogger city elite front wheel shakes
You need to put more weight on the front of the stroller. The wheel is shaking because it's able to swivel....
Apr 12, 2010 | Baby Jogger City Series Single Stroller
Front wheel trembling
Yes have it checked out the front wheel my be loose and my come of speak to www.buggypitstop.co.uk they are experts on fixing buggies
Dec 04, 2009 | Baby Trend Expedition LE Jogger
The front wheel of my Koelstra double stroller shaking
oh you just lost one of the bearings from your wheel you can get it servicet at your local bike shop
Oct 25, 2009 | Baby Trend Expedition Double Jogger
Front wheel
http://www.babytrend.com/contactUs.php
Contact us by mail:
BABY TREND INC.,
1607 S. Campus Ave. Ontario, CA 91761 U.S.A Contact us by phone:
Customer Service: 1-800-328-7363
Apr 24, 2008 | Baby Trend Expedition LE Jogger
My jogging stroller shakes
Well, i'm not positive in this, seeing how I never had kids, but while jogging are you pushing down harder on the stroller? or you could look for smaller wheels to put it on, but then again you might have'ft to bend over to do it, and if the handle which you push is tall that has to do with force viberating the stroller
Nov 29, 2007 | Baby Gear
Shakes when going fast
Problem suggests that the stroller has sustained structural damage in the accident.If you use it with any additional weight than what is the recommended as per cataloge the stroller may give away causing injury.The damage is beyond repairs and hence it is not safe to use the equipment any more.
Aug 25, 2007 | SafeTech Double Jogging Stroller
Bebecar Racer ST Jogger Logo
339 people viewed this question
Top Bebecar Baby Gear Experts
john milligan
ray gallant
Tom Chichester
Are you a Bebecar Baby Gear Expert? Answer questions, earn points and help others
