Question about RIM BlackBerry Pearl 8100
Rollerball will barely roll down
Rollerball sticks when trying to scroll down
    Problem Solver:
  • 4 Answers
Yes
Posted on Jun 16, 2009
Rollerball will move, but won't click to activate applications. Nor will the buttons work to answer or turn phone on/off? The side buttons won't work either. All other aspects of the phone are...
my friend it is easy just open ur phone and clean ur rollerball u find calceur white.this because ur mobile infected by water .and tel m later
Jan 04, 2010 | RIM Blackberry Curve 8300
Tip
How to fix a faulty Blackberry rollerball/trackball
There are a few relatively simple solutions to fixing a faulty Blackberry rollerball/trackball.
Compressed Air
Spraying some compressed air on the ball and round the sides of the ball can sometimes loosen the compacted dirt & dust on the rolling mechanism.
You can pick up compressed air from your local hardware store.
WD40
Spray a tiny amount of WD40 on a cotton bud and rub it onto the rollerball. This can free up the mechanism and lubricate it.
Removing and Cleaning the Rollerball/Trackball
  1. Using a small flathead screw driver gently prise the silver ring around the rollerball from the top (be extremely careful as the catches are made of plastic and can break easily)
  2. The rollerball module should come out with easy
  3. Using a clean paint brush, gently brush the inside of the Blackberry where the module came from
  4. Using a toothbrush clean the rollerball module gently around the rollers on the underside and also clean the actual rollerball
  5. When replacing the rollerball module it will only fit one way so don't worry about putting it in upside down
  6. There are three plastic catches on the silver ring, there should be one at the bottom & two at the top. Line them up on the phone and press it back in place gently.
Replacing the rollerball/trackball
Sometimes the mechanism or the rollerball can be come damaged and cleaning will not solve the problem. In this case you can replace the rollerball by following the instructions above about cleaning and purchase a replacement rollerball from eBay or one of the other countless online stores that see Blackberry parts.
I would always recommend that you buy genuine Blackberry replacement parts as these are usually of a higher quality than copies.
on Dec 18, 2009 | Cell Phones
Rollerball on Wireless mouse keeps getting gummed up. Cleaning done frequently but need to open mouse to get inside cleaned ?
The Apple wireless mice aren't made to be disassembled, not even by techs. If you disassemble it to clean it, you must glue it back together.
The best way to clean the rollerball is to remove the batteries and roll the ball upside down on a cloth soaked in alcohol. Be sure to roll the ball alternately depressed and not depressed for the best cleaning, and roll it in all directions.
When this no longer works, you can either attempt to clean the ball yourself at your own risk, or purchase a new mouse.
Nov 25, 2009 | Apple Computers & Internet
I can't scroll down with the rollerball
The balls on the blackberry's get clogged up with finger oil, skin, and all sorts of grime I think. But I fixed mine by shutting the phone down and then rubbing hard against the roll ball in each direction and pushing each time until the clicker under the roll ball clicked. You could also try alcohol.
Oct 06, 2009 | AT&T Blackberry Curve 8300 Smartphone
My Rollerball won't scroll down - tried everything.
Cause: The sensitivity of the trackball/trackwheel might be less Faulty Hardware Resolution: Increase the sensitivity by following procedure Option -> Screen and Keyboard -> Horizontal Sensitivity and Vertical Sensitivity to 100 If not working check with the service center
Aug 11, 2009 | RIM BlackBerry Pearl 8100
My rollerball won't click.
I'm having the same problem with this. One of my friends and a Att worker have suggested that replacing the Rollerball with a new one which can be bought off Ebay for 5 or 6 bucks can fix the problem. If that does't work then check to see if water damage has taken place, if any moisture has gotten to the phone it may be that. Other then replacing the rollerball i have no other solution.
Apr 17, 2009 | RIM BlackBerry Pearl 8100
Blackberry pearl turns off when i touch the rollerball
Try a different ball in the device they are fairly easy to remove. Borrow a friends entire track ball use nail file to remove the ring then look to make sure what way the mechanism and ring go back in and try your firends if his/hers works in your phone replace the defective part. 2b4daea.jpg fb71594.jpgeb3c8be.jpg
Dec 29, 2008 | RIM BlackBerry Pearl 8100
Tmobile Sidekick Slide Rollerball won't roll down
Try taking a whipe and moving the trackball from side to side and it will become unstuck it happens with every phone that has a trackball
Dec 29, 2008 | T-Mobile Sidekick ID Cellular Phone
Blackberry Curve rollerball scrolls but will not select when push
Try removing the silver cover around the scroll ball, and remove the ball. There should be a little white square underneath it. If there is no white square, but a red square, then it could be water damage. I had the same issue with mine.
Dec 15, 2008 | RIM BlackBerry Pearl 8100
Hi guys I have the solution. I think all your trackballs are stuck. If you cant move it, take the silver ring off with a knife, take off the trackball and put rubbing alcohol on it wth a Q - tip until it works. Can some1 help me? My problem is titled My blackberry pearl wont load up.
May 16, 2008 | RIM BlackBerry Pearl 8100
RIM BlackBerry  Pearl  8100 Logo
221 people viewed this question
Top RIM Computers & Internet Experts
ismael castillo
David
Jerry Greenberg
Jerry Greenberg
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
