Question about Whirlpool Calypso GVW9959K Top Load Washer
Machine states 8 more minutes but will not clear when start or stop is pushed. When unplugged the 8 minutes returns on the screen.
It fixed itself. The next day it was reset and working.
Posted on Jun 18, 2009
How do I turn off protocol monitor on sharp fax model fo-235
Had exact same problem on UX 177. You need to clear the memory. On the UX 177 unplug machine, press and hold down the COPY button then press and hold down the STOP button. Keeping these two buttons pressed plug machine in. It should display message "clear memory ?" let go of the COPY and STOP buttons and press the START button. Will then display message "memory cleared". This will also wipe out all other programming but it is the only way to stop protocol report. Then reprogram all your settings.
That stopped protocol report printing after each fax. On some machines it may be the stop and start button the need to be held down on startup. It also seems to make a difference which button you push first even though machine is unplugged.
This problem returns after a power failure so if you have a lot of numbers programmed in you might want to get an inexpensive uninterruptible power supply or plug fax into UPS for computer if you have one.
Mar 03, 2011 | Sharp Office Equipment & Supplies
Canon Multipass 730 Alarm light blinking and "PLEASE WAIT" on the screen. It is making a sound like it is about to print or copy something, it is an intermittent running. I tried shutting down...
Hello Mary, You can reset the Machine;
1) Enter SERVICE MODE.---
By pressing Menu-Copy-#
2) Select TEST MODE.
3) Select [8] PRINTER TEST in TEST MODE.
4) Select 3. [EEPROM CLEAR].
5) Select 0. [INK COUNT].
6) Press the [OK] key.
7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
Service Centers near your area; Click Here, and Enter your Zip Code on the target page.
Nov 18, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
Brother MFC 240C clear Machine Error 46, IT HAS REPLACEMENT OF PAD INK, BUT STILL HAS THIS ERROR, HOW CAN I DELETED FROM SCREEN??
In order to resolve the issue we try to resetting purge counter:
1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
This will resolve the issue.
Feb 25, 2010 | Brother Multi-Function Center MFC-240C...
Brother printer machine error 46 indicates in the LCD
All you need to do is to reset the purge counter. These steps worked in MFC620CN/420CN/410CN/210C/240C and FAX2440C models, and may work in others.
To reset purge counter
1) Enter machine maintenance mode:
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the “up arrow” key four times to enter the maintenance mode).
**Be sure not to change anything accidentally, as critical operations can be changed in this mode**
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine’s log information list (function code 80).
Other things you can try is to power off the machine and unplug it for 10 minutes. Make sure nothing is jammed.
Hope this helps!
Rate my solution!
reizac926
Jan 05, 2010 | Bosch Office Equipment & Supplies
How to fix a message: Waste Ink Near Full on Canon MP730 Multipass printer
Instructions for resetting the MP730 ink tank full counter
1) Enter SERVICE MODE.By
pressing MenuCopy#
2) Select TEST MODE. using the + key then the set
3) Select [8] PRINTER TEST in TEST MODE. by hitting the number 8
4) Select 3. [EEPROM CLEAR]. by hitting the number 3
5) Select 0. [INK COUNT]. by hitting the number 0
6) Let it default to the new value by waiting
7) Press the [Stop/Reset] key (returning to the state of 3)), this is the red stop key
8) Then press the [ON/OFF] key and the machine will reset and push through a page of paper
Sometimes is need to clean the purge unit
Canon MP730 Printer Purge Unit Disassembly and Assembly :
http://newsquaremusic.com/CanonMP730PrinterPurgeUnitDisassemblyandAssembly.pdf
http://newsquaremusic.com/CanonMP730PrinterWasteInkTankFullResolution.pdf
I hope this is useful
Oct 03, 2009 | Canon Office Equipment & Supplies
My he2 kenmore washer is not starting when i push the button-it stops and starts flashing the error code f-01-what can I do to fix the problem?
F01 - There may be an internal problem with the control, attempt a Hard Reset.
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
The F01 generally indicates a failed electronic machine control board.
This error code can sometimes be caused by a glitch or power surge through the electrical lines.
You may be able to clear this code by unplugging the washer for 5 minutes.
If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
The procedure for accessing and replacing this control board is shown in this image...
http://media.fotki.com/1_p,wkwdftgtbkdgfrwxgtqsskgwtqkq,vi/ksrttqdqrxkssrqtgsd/1/1303472/5961857/image12917img-or.jpg
Be sure to unplug the washer before accessing internal components.
When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time.
Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer.
Reassemble and test the washer.
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU.
The "F01" can also be displayed if the onboard "Pump Driver" fails to activate.
Generally in order to correct this failure will require replacing the CCU.
There is no way to test and verify if the control board has failed.
The technical data sheet basically states to replace the CCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 26, 2009 | Kenmore HE2 Plus Front Load Washer
Washing machine flashes F1
Sep 04, 2009 | Kenmore Elite 45986 Front Load Washer
The fax wont work and the copy wont work
I would first check to see if there is anything that is stuck in the top feeder (ADF) area. If that is all clear I would unplug the machine and leave off for about 10 minutes and then plug back in. If that does not work. there could be a problem with one of the electrical components in the machine.
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_7148ad2a373711a3
Sep 01, 2009 | Brother IntelliFAX 4100 Laser Fax
Error: F 01 and it wont start! I unplugged it for 2 minutes but it still reads 01. I drained the water and it still reads F 01
May 04, 2009 | Kenmore HE2 Plus Front Load Washer
Whirlpool duet front load beeped and flashed f with no numbers and stopped mid-cycle. now what. i've pushed red button x2 and tried spin/drain and nothing. now it is stopped again. help!!
In many cases these error codes can be erroneous. If you reset the Central Control Unit (the Main Control for the washer), in many cases, the problem will clear. You must unplug the washer for AT LEAST 30 minutes in order to do this, however. If an error code returns following a CCU reset, then you have a legitimate problem.
Feb 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
186 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
