SOURCE: Threading my sewing machine
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
all machines thread the same. TTN tension, take up,
needle.
Beginning with the spool, guide the
thread through the thread guides to the tension assembly. Pull the thread
through the tension assembly and test it to make sure the tension is working
correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or
something in the middle. Raise the presser foot and pull the thread through the
tension. It should pull easily!! Lower the presser foot and pull the thread. It
should pull noticeably harder.) If it passes this test, continue up through the
take up lever,then down through the thread guides to the needle. Make sure your
needle is fully inserted and turned the correct way.( If you load your bobbin
case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT.
There are some exceptions. If you have a newer style drop in bobbin or your
bobbin case loads in the front then the rule is FLAT to the BACK.
Sewman7
SOURCE: manual
HF 3000 is the same as Memory Craft 3000
Here is the link to download the manual for Memory Craft 3000....
http://www.janome.com/index.cfm/Machines/Computerized/MC3000/NoFlash/Media/?image=4#Machines_Specifications
SOURCE: I need the instruction book for the New Homer
Well you can please follow the below link to get your instructions manual -
http://www.devicemanuals.com/guide/Balance/A&D/A-D-HF-3000-Balance-Instruction-Manual-English-==TWpZMk5EWXg=.html
Good Luck!!
Thanks for using FixYa!!
SOURCE: I also need a New Home (Janome) HF 3000 sewing
I would call Janome directly, 1-800-631-0183 and order one from them. They are open from 8:30 am To 5 PM,( Mon-Fri) I would also tell them that they should make their manuals available for download (and free) like Singer and Brother. Companies who make it impossible to for the customer to get a copy of their manuals drive me crazy. Not everyone sews between the times that they are open, to answer questions. I would complain to them, if nothing else, it may make them more sensitive to their customers. After all, they are not the only ones selling machines, and there is a real renaissance going on with sewing. They should appreciate every customer they have, especially with this economy.
