SOURCE: Tuner won't go above Channel # 99?
Most cable boxes that go past 99 are digital channels and require the cable box to tune them in. You can always set the cable box to the station you want and hookup the rca output to your DR4 rca input and record from that. Their is no other work around for this because the DR4 has an analog tuner inside of it and your cable box is a digital turner.
SOURCE: We hooked out Toshiba SD-V291
I just had the same problem, and I am using rca blue, red and green cables for video. I unplugged them and plugged them back in again a couple times and it finally worked. I have had this problem before with another dvd player, don't know why. Hope this helps.
Chris
SOURCE: I can't set up DVD player correctly to record t.v. shows
ok let's start from simple connection.we'll use color coding,let's say rca plug. yellow plug is video.from DVD video out is yellow and to the tv is video in. white and red is for audio.if your tv is 5.1 compatible then follow the label on your DVD and insert it to its corresponding label on your tv.then still if your using a separate audio amplifier only the yellow/video plug is used.
SOURCE: YOUR TV DOES NOT ALLOW DISPLAY OF THIS PROGRAM THROUGH THE DVI IN
I solved the same problem by disabling SIMPLINK from OPTIONS menu. I own the LG TV myself. The LG TV comes SIMPLINK "ON" as default setting from the factory. Go to MEMU -> OPTIONS -> Turn SIMPLINK to "OFF". This should work....
SOURCE: Toshiba BDX2200KU Blu-Ray player.
Unplug bluray player wait 15 seconds replug in, that should reset it and work
Here are pictures of the back of the set top box:
http://www.jcom.co.jp/library/support/tv...
And the blu-ray recorder:https://www.japanet.co.jp/shopping/simg/...
