Pioneer Elite SC-91 Manual Online: using all zone standby, Setting The Switching Time For The Receiver Operation Mode, Resetting The Remote Control ...
PDF
Increase the separation between the equipment and receiver. - Connect the ... Using the SR+ mode with a Pioneer flat panel TV . ... Plug the power cable into the AC outlet and switch on the receiver.1 Make ... See Automatically setting up for surround sound (MCACC ... 4 Optical and coaxial digital audio inputs (x7 (SC-07),.
PDF
The STANDBY/ON switch on this unit will not completely shut off all ... Plugging in the receiver . ... Automatically conducting optimum sound tuning (Full Auto MCACC) . ... Setting the switching time of AV amplifier operation mode. ... On a Mac, launch Safari and click <SC-85> displayed in 'Bonjour' on the Bookmarks bar.
PDF
Before plugging in for the first time, read the following ... The STANDBY/ON switch on this unit will not ... Connecting a satellite/cable receiver or other set-top box . ... Switching on/off the Acoustic Calibration EQ, Auto Sound Retriever or Dialog ... For the SC-65, the optional AS-BT200 Bluetooth adapter works together with ...
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
I had a receiver that would shut off when I had the volume too loud. It was caused because the speakers were using too much juice. Does it work with less speakers or at low low volumes? Then this may be the case.
I solved it by getting a different receiver.
if it has nothing to do with volume then check your manual and settings for a auto standby feature that may be just putting the receiver to standby after a set time.
The Media Receiver is the tuner/connector selector box.
If the top is removed the Media Box goes into shut down mode. It requires resetting by a Pioneer Authorised Service tool.
Have you tried changing the Auto Standby switch to ON?
You can prove if the sub amp will respond to a known good input by TURNING ITS VOLUME DOWN tp start and just feeding it ANY RCA output from the receiver while playing, say, FM (to keep it simple). That way you would known in which direction the problem actually lies (internal or external).
If your reciever is in a tight enclosed space, than it will overheat and shut down to protect itself. Try to get some ventilation to it by either opening the cabinet door, adding a fan, or pulling it completely out of the enclosed space.
