Question about Bauknecht 24 in. GSFP3988 Built-in Dishwasher
My Bauknecht dishwasher stopped working
I had an electrical shut down in my house and the dishwasher stopped working. I ordered a technician and when he came (a few days later) the dishwasher was fine (it went back to work suddenly).
After another shutdown - the same thing happened. the dishwasher stopped working and after a day or two came back on.
Now, the same thing happened but the dishwasher still hasn't returned to work after three days.
  • Bauknecht Master
  • 19,050 Answers
2 Suggested Answers
  • 1462 Answers
SOURCE: dishwasher
have only worked on them a few times but no problem to use. literally select program, close door and start. you won't break anything by trying it out.
put detergent in the dispensor and rinse aid in the rinseaidv despensor. if in a harrd water area, add dishwasher salt to the softener
Posted on Aug 21, 2008
Everytime we attempt to press a programme button the dishwasher trips our electrical circuit breaker for the house. it does not blow its own fuse. It is almost 17 yrs old and never given a problem.
Hi, you have a short in the unit take the outer door panel off and look at the door switch and the were connections to the control for a burnt connection.
There are too many items that rely on the same circuit. You will have to get an electrician in to fix this. In the mean time, make sure everything else that is used by that circuit is turned off when you use the dishwasher
Jun 28, 2011 | Bauknecht Dishwashers
The START indicator lamp flashes and we can't shut it down
In this case, I would try unplugging it (or shutting the circuit breaker off) for about 5 minutes. Then turn it back on to see if the washer panel now functions normally.
I hope this helps your washer get its brains back! :)
-Jason
Dec 14, 2010 | Bauknecht Dishwashers
Hi my Bauknecht GSI 5411 dishwasher seems to starting ok but then it stops after a couple of minutes. have checked the water supply tap as well as the filter and they seem to be ok. Please help
Set the machine to the end of the drying cycle, when it has finished, try pouring boiling water into the machine about a kettle full there is a sump level control beneath the removable filter (where all the **** gathers) if this has fat deposits on it this type of problem can occur.
Nov 05, 2009 | Bauknecht 24 in. GSX7551 Built-in...
Dishwasher
Aug 14, 2008 | Bauknecht 24 in. GSF8971 Built-in...
Have got a bauknecht dishwasher model no gcx 5521. had the same problem last year. water is not going into the machine it looks like the water stop device activated. I think its something to do with a...
have got a bauknecht gsx4756 which when started beeps continually and start light flashes. it automaticaly then flashes the rinse button as well. I have reset holding down start and mode selection button next to the start button the fault keeps recurring. just wanting to know what the problem is before paying an engineers extortionate call out fees
Jul 31, 2008 | Bauknecht Dishwashers
Flashing
The lights flash when the door is not shut all the way, or the sensor that detects that the door is shut is not sensing the door is shut. Try pushing in on the door while hitting the start button.
Sep 10, 2007 | Bauknecht 24 in. GSF8984 Free-standing...
What does F7 Means?
The F7 means that the drain filter is blocked or your water pressure is low. Check and clean filters. Good luck !
Apr 25, 2007 | Bauknecht 24 in. GSF8984 Free-standing...
Bauknecht GSX4756 dishwasher
I have this problem frequetly - it's an easy one to fix! Just press the programme button which changes the programme setting you want (on my built-in GSX4756 it's the last button on the right) and keep it pressed in until the beeping stops. Then start it again (will probably be on the rinse programme if it's like mine).
Feb 08, 2007 | Bauknecht 24 in. GSFP3988 Built-in...
Bauknecht 24 in. GSFP3988 Built-in Dishwasher Logo
64 people viewed this question
Top Bauknecht Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Andrew Taylor
Andrew Taylor
Are you a Bauknecht Dishwasher Expert? Answer questions, earn points and help others
