My tablet isn't installed, so I have to set up my programs, but when I tried to get internet access, my tablet won't connect-on the bottom right side of the computer says that the internet is connected, but when I open Internet Explorer up, it won't connect.
  • efs_perpends
    efs_perpends May 11, 2010
    What OS are you using? xp? vista?
    President:
  • 1,996 Answers
Link here to troubleshoot internet explorer.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jun 16, 2009
I downloaded a program on my tablet for my laptop, can I run that program from my tablet to my laptop if I connect my tablet to my laptop
Only if there is a PC version of same program you have installed on your tablet, installed on your PC also.
Other than this scenario, no, you can't.
Platform or OS are different
Oct 14, 2017 | Tablets & eReaders
Tip
Compatibility settings for older programs to run in Vista and Windows 7
Because of the way some software was written before windows Vista and Windows 7, such as windows XP applications they are not always compatible with the newer operating systems. However Microsoft has included some compatibility settings on executable files to hopefully fix these incompatibilities, so if a program isn't function properly in windows 7 you may wish to try this.<br /><br />1. Right click on the .exe or .msi installer package for the program you wish to install<br /><br />2. In the right click menu select the properties option<br /><br />3. In the tabs that appear select the compatibility tab<br /><br />4. Set the drop down operating system to be compatible with to the operating system that the program is designed to run on.<br /><br />5. Check the box that is labeled "run as administrator"<br /><br />hope this helps your applications that are performing unexpectedly in windows 7<br />
on May 12, 2011 | Computers & Internet
How do set the trio stealth to use an external SD card
I show you one of the many links about using an SD card on an Android tablet or phone:
How to install Android apps to your SD card by default fixedByVonnie
Jan 11, 2015 | Tablets & eReaders
Ematic table em63bl
If you are trying to factory reset your tablet, go to settings then go to backup & reset. There should be an option to factory reset your tablet which will delete anything you installed or downloaded.
Apr 07, 2014 | Ematic e8 series
Flash player is blocked
Since the Archos 101 Internet Tablet 16GB 10.1" is running Android 2.2 Froyo, you should be able to install Flash Player. When you say "Flash Player is blocked" what do you see when you try to install Flash Player, what software is blocking the install? Maybe we can disable the software which is blocking Flash Player. The other idea in to go into your settings, usually under security, find and check the box "Allow installation of external programs" then try the install again.
Jun 08, 2013 | Archos 101 Internet Tablet 16GB 10.1"...
My adobe flashplayer is blocked how to unblock it
Go into the Tablet's settings, under security find and check the box "Allow installation of programs". They try to install Flash Player again.
How can I set up Leap on my wifi
Frank,
Since the protocol isn't visually supported, either from Samsung or in the Froyo 2.2 manual, it appears that several have tried the PEAP setting with default values successfully. I found the following thread on code.google.com, and pay attention to Comment 22.
http://code.google.com/p/android/issues/detail?id=1871
Best of luck
Oct 28, 2011 | Samsung Galaxy Tab 101 Tablet...
Tablet does not work with Manga Studio Debut 4
I had the exact same problem. To fix it right click the manga studio icon go to properties-compatibility. Set everything under settings to on, apply-OK, then go on manga studio, it should mess up your screen resolution, don't worry about that. Close the program, your screen resolution should go back to normal, go back on to the properties-compatibility screen and set everything under settings to off. Now when you go on to manga studio it should work fine.
Jun 11, 2010 | Smith Micro Manga Studio Debut 4 for PC
I can't install my Intuos3 onto Vista
I don't think there are any programs for the Wacom. I don't see any on my computer. Open photoshop and see if the tablet works in there.
Nov 30, 2009 | Wacom Intuos3 Graphic Tablet
Wacom Tablet Installation: Where's the Setup Process?
What you should do now is to go to Control Panel->Add Remove programs. Select the entry for this tablet and delete it. after disconnecting the tablet reboot the PC. Then without connecting the tablet, install the drivers, Reboot. Connect the tablet and allow Windows to detect the tablet and load its drivers. Then only will work properly.
Nov 19, 2009 | Wacom Graphire3 Tablet 6x8 (C267252627)
Computers & Internet Logo
Alun Cox
David Payne
David Payne
