Question about Acer (56.04145.901) (5604145901) Power Supply
How to open Acer power adaptor to reconnect output lead?
The 19V wire to my Acer power adaptor, model ADP-60XB for a Travelmate 340T, seems to be broken at the point where it enters the sleeve on the adaptor itself - wiggling it there causes power to come and go. I need to open the adaptor to reconnect the leads, but it has no visible means of access. There is a groove round the side - is it just clipped together, and is there any way of opening it without damage? I can't feel any screws underneath the label, where some equipment hides them.
Geekman
  • 32281 Answers
SOURCE: Opening acer aspire 5050
The top and bottom covers are also held together with plactic catches.
After you remove the battery, CD/DVD drive and hard drive etc.
start near an openning and gently pull apart the top and bottom cases, you should hear a click as a catch releases, then continue to work around the edge fron this point.
Posted on Mar 06, 2009
SOURCE: My Acer Slide Latch is broken on my 5315-2698?
acer computer company is run by chimpanzees
Posted on Sep 18, 2009
  • 40 Answers
SOURCE: Acer Travelmate 2300 - UNABLE TO ACCESS!
video chip problem.go to service.
Posted on Apr 21, 2010
  • 236 Answers
SOURCE: I have an Acer One
The Acer One netbook has a mini-VGA port on its left side. Page 10 of Acer's QuickGuide shows the port as item 3 External display (VGA) port. But unfortunately, the description shown for it is incorrect.
From your description, your projector's lead likely has a mini-VGA connector on the end as pictured. The connector can simply be plugged into the mini-VGA port but there are no holes beside the port for screws so it would just be a friction fit which should be sufficiently secure for most puposes. The connector and port are mini-DB 15 male and female respectively and can only fit one-way. The port has the wide side of the D on top so you would have to turn the pictured connector over to be able to plug it into the port. Windows XP should be able to detect the projector via plug-and-play installing any display drivers if required. Page 8 of Acer's UserGuide describes Hotkey + Display toggle which switches display output between the display screen, external monitor (if connected) and both. Pressing + with the projector plugged in will bring up a window in the middle of the screen allowing the selection of internal display, external display, both, or a 800x600 VGA projector. If the display is on the projector, unplugging the cable should automatically revert display back to the internal screen. For VGA see http://en.wikipedia.org/wiki/VGA_connector splines.jpg
Posted on Jan 31, 2011
Acadiemedia
  • 131 Answers
SOURCE: HOW do you open an acer one to access memory slot and hard drive?
Hi James, Here is a step by step video tutorial.
Enjoy your new upgrades.
Posted on Oct 23, 2011
Specs ms2132
I hope this is useful; it's rather scanty
From the 2300 TM series manual (available from the acer website): 65W AC adapter 19V 3.42A
Or have a look at this
http://www.ukbatteryfast.co.uk/acer-travelmate-230-power-adapter-charger-p-1130
webpage. I think it's for a compatible power adapter, rather than an original Acer one, but it gives pictures of the connector.
Try www.acer.com > support > chat and see if they can be more helpful and specific
17.April.2014
Dec 13, 2013 | Acer TravelMate 230 Series Laptop Charger...
ASUS adapter for 501J series has a short in the cord. Am in need for a Model # ADP-65JH Input 100-240V Output 19V - 3.24A. What do I need to order. E-mail: krfecht@mac.com
You need a mains adapterthat has Input 100-240V Output 19V - 3.24A and the input plug that fits into the power socket of your laptop. It does not need to be from ASUS.
Google search the Internet for a suitable power adapter, make sure the output voltage is the same and the amps is 3.24 or higher.
Mar 11, 2011 | ASUS Televison & Video
I have ACER Aspire One Model KAV60. Need to Identify Power supply
There are three adapter manufacturers, the Acer One runs on 30 watts and 19 volts. Below are the specs for the adapters.
10001081
DELTA
30W Adapter DELTA 30W 19V 1.7x5.5x11 Black ADP-30JH BA
LF
60003544
LITE-ON OPT
30W Adapter LITE-ON 30W 1.7x5.5x11 Black PA-1300-04AC LF
60002015
HIPRO
30W Adapter HIPRO 30W 19V 1.7x5.5x11 Black HP-A0301R3
Jan 24, 2010 | Acer Aspire One PC Notebook
My Acer 340T powers on and then the screen gets beautiful stripes but nothing else...is this fixable or do I now have a paperweight?
It depends really. If you can still see the post/splash screen clearly then the problem will just be bad display drivers.
Boot the machine into safe mode. Right click on My Computer (XP) Computer (Vista) and select manage from the sub menu.
When the window pops up select Device Manager.
A device list will populate. When it has look down the list for Display Adapters. Click on the + icon next to Display Adapters to it expands. Right click on the display adapter and select uninstall.
Restart the computer and let it boot in normal mode.
If it boots in normal mode let it detect the Display and install the drivers for it.
I would be a good idea to update the display drivers via the Acer support website.
Regards.
Sep 29, 2009 | Acer TravelMate 340T Notebook
Hard drive remove
If you mean the Acer Travelmate 340t
Link to manual
Sep 02, 2008 | Computers & Internet
Acer travelmate C110 & Acer projector X11602
Hi Andrew,
you can try changing the output of the travelmate, to VGA Or External Device.
ensure you have the correct output lead from computer to projecter. Then on your keyboard you should have a button that changes the output. i.e numerical 5-6-7 or 8. usually says LCD/VGA et,c.
failing this try altering the output in the systems bios setup.
you can enter this by pressing F2 Or esc at bootup.
if your unsure, and none of this helps, i,d suggest visiting acers site. and downloading the user manual(s)
Mike @ Compurepair.
May 22, 2008 | Acer TravelMate C110 Tablet PC
Laptop not working
The Brick is the external power adapter, My acer uses model # ADP-60XB 19V X 3.16A= 60 Watts
Yours I believe is also a 19V but I believe the amps are 3.45 making yours a 65Watt power supply ac/dc adapter.
Test the voltage, if your unsure how, take it to Radio Shack and have them do it.
Mar 23, 2008 | Acer Aspire 3610 Notebook
Computers & Internet Logo
901 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
