here is all u need to know except that it says i can read and burn dvd's but actually i cannot.
Drive Information ------------------ Drive : HL-DT-ST DVDRAM GSA-4040B Type : DVD±R/RW Recorder Firmware Version : A304 Buffer Size : 2 MB Date : ? Serial Number : K2A37T43117 Vendor Specific : Drive Letter : E:\ Location : 1:0 Mechanism : Tray Read Speed : 32 , 24 , 16 , 10 , 8 , 4 X Write Speed : 24 , 16 , 8 , 4 X
Read CD Text : Yes Return C2 Pointers : Yes Read CD-R : Yes Read CD-RW : Yes Read DVD-ROM : Yes Read DVD-RAM : Yes Read DVD-R : Yes Read DVD-RW : Yes Read DVD-R DL : No Read DVD+R : Yes Read DVD+RW : Yes Read DVD+R DL : No Read BD-ROM : No Read BD-R : No Read BD-RE : No Read HD DVD-ROM : No Read HD DVD-R : No Read HD DVD-RW : No Read HD-BURN : No Read Digital Audio : Yes Read CD+G : No Read VideoCD : Yes
Write CD-R : Yes Write CD-RW : Yes Write DVD-R : Yes Write DVD-RW : Yes Write DVD-R DL : No Write DVD+R : Yes Write DVD+RW : Yes Write DVD+R DL : No Write DVD-RAM : Yes Write BD-R : No Write BD-RE : No Write HD DVD-R : No Write HD DVD-RW : No Write HD-BURN-R : No Write HD-BURN-RW : No Buffer Underrun Protection : Yes Mount Rainier : No SolidBurn : No Labelflash : No LightScribe : No Modes : Packet, TAO, DAO, SAO, RAW SAO, RAW DAO, RAW SAO 16, RAW SAO 96, RAW DAO 16, RAW DAO 96
Region Protection Control : RPC I Region : All Changes User : n/a Changes Vendor : n/a
-   My lg dvd writer is able to read cds but it is not able to read dvds. i would be grateful if someone suggest me a solution. Thanks in advance......-   rvs_n1
Mar 08, 2009
-   my dvd ram does not read dvd but it can read any cd . when I put the dvd and click to open it turns into a cd-rom
-   Guest
Apr 04, 2008
-   for some people, disabling digital cd playback for the problematic optical drive solves read problems. Right click on drive in explorer: >Properties>Hardware tab>(select drive)>Properties>Properties tab>uncheck digitalcd playback.-   Guest
Nov 20, 2007
-   my pioneer dvr 111D WON'T READ THE SAME DVD+R DISCS THAT IT RECORD IT.IT USE TO WORK FINE UNTIL A COUPLE OF DAYS AGO.
I WOULD REALLY LOVE A SOLUTION. I RECORDED SOME GOOD MOVIES AND NOW I CAN'T SEE THEM.
LFR-   Jr-Ratchet
Nov 08, 2007
-   My DVD drive can read all disc.but can't burn any.
The error report shows :-
*can't perform start of Disc-at once
*Burning process failed at 48x (7,200 kb/s)
*DMA-driver error,CRC error-   Ahing
have you installed the softwares to burn DV/CDs? maybe you hadn't installed the softwares yet. normally samsung uses NERO. check the installation kits.
Thank You all for your solutions, but i found out that the problem was that the little door wasn't closing all the way.And as such the dvds weren't fitting in correctly.
Appreciate the response.
LFR
HP notebook does not recognize my Asus opt. drive (SDRW-08D1S-U) . No drive letter. Have no driver...
(More)
HP notebook does not recognize my Asus opt. drive (SDRW-08D1S-U) . No drive letter. Have no driver in the package.
Drive name - TS-H492a (combo Drive)
Some dvd movies does not work on my dvd drive.while some...
(More)
Some dvd movies does not work on my dvd drive.while some movies does work.This is not due scratches or dirt on the disk drive becuse the same dvd's does work on another dvd player.I used a dvd lense cleaner but the problem persist.
