Question about Gateway FPD1765 17" Flat Panel LCD Monitor
No signal Monitor blinks out and reads no signal RGB
  • 40 Answers
Faulty monitor connection
Posted on Jun 16, 2009
Ibm thinkpad wont connect to LG TV
Lower the screen resolution to 720 dpi.
Another issue is the reference to RGB. Is it the 3 cable (YPBPR) or the standard 15 pin VGA? You may need a converter.
Oct 08, 2012 | IBM ThinkPad T40p 2373 Notebook
Monitor say RGB no signal?
If the monitor works with other computer then the video card in the computer where the monitor does not work is bad. You need to replace the video card. If the video card is on the motherboard, just replace it with a video card that fits into one of the PCI slots. If you were using VGA then purchase a PCI VGA Video Card.
Apr 09, 2012 | Computers & Internet
Where to connect my pen drive in my sony bravia lcd klv32s400a?
Hi Radhika,
Your TV has USB port on back side. Just plug your pendrive there. Then go menu on TV ( use your remote commander) and go to this input. Your TV will read the file on pendrive accordingly.
Regards
Oct 03, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
My flat panel moitor displays RGB no signal. I
If the other monitor has no signal as well, this proved the video card is faulty and needs to be replaced.
Dec 03, 2009 | Gateway Computers & Internet
I see a gray screen only when I turn thePC on. I connected my monitor to my acer extensa laptop and still stayed gray.
The CRT monitors use RGB signals for displaying colours, most of the monitors dos'nt have colour setting option, This situation can only arise whenever the RGB signals are equally of the same strength, this is an indication that the chroma section responsible for colour distribution of your monitor is now working properly, you need to examine the RGB circuitry of your monitor, one more possibility is the data cable (VGA) has been tampered internally.
Oct 05, 2009 | Acer Computers & Internet
What is rgb mode? my vizio tv/computer monitor says no rgb signal i have tried input rgb, hdmi...and all sorts of combinations but with no success.
RGB stands for Red, Green, Blue (All colors can be otained from these.) All, it is saying it has no signal coming in.
Hope it helps.
Sep 11, 2009 | Vizio Televison & Video
While trying to change channels, my t.v. displayed ''no signal'' and then shut itself off. Now, when I turn it on, it says no signal and turns itself off after a few seconds.
Turn the television on and as soon as the screen turns on repeatily press the input button or change the input to whatever input you are using from a source device. As long as you change it to anything other than RGB.
Your television is essentially a big computer monitor with multiple inputs and a tuner. When using your computer and shutting it down the monitor will go in a power save mode. You don't need to shut off your monitor due to this power saving mode. When you power up your computer your monitor automatically turn on.
With the VIZIO and the RGB (computer) input the television will act just like a computer monitor. When you have a computer connected it will power down automatically when you shut off your computer. When you turn your computer on the VIZIO will automatically come out of standby mode. This is through RGB only.
This is normal operation for the VIZIO but can see confusing when nothing is connected to the RGB input. If you change your television input to RGB it will sense no signal on the input and will go into standby mode after about 5 - 10 seconds. If you were to send a signal to the television through RGB it would automatically kick on.
Apr 05, 2009 | Vizio L37 Television
No RGB imput signal
You need to change the input signal, get into the menu on your monitor and change the signal from rgb to dvi, hdmi or vga dipending on what cable you using for connection.
There is NO rgb connector on that monitor
Good luck
Dec 05, 2008 | Balance CM2015 15" LCD Monitor
CTX
Neichi could this monitor be set to receive dvi signals and not rgb even if he has the rgb hooked into the monitor? so in menu select rgb input?
Mitch, monitors don't conflict with windows generally usually they(windows os) will install a basic generic driver to run the monitor, and you should do this when changing monitors before you hook up the new one, your description really lacks any concrete description where are the "black and blue errors" what do they look like last I have had problems with modems interfering with video so I would remove the modem and see if the problem goes away.
Apr 27, 2008 | Gateway FPD2275W LCD Monitor
Gateway FPD1765 17" Flat Panel LCD Monitor Logo
155 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
