Question about Cooktops
Holiday Stove Pilot Light won't stay lit.
I have a smaller Holiday gas stove in one of my apts., and the darn pilot light won't stay lit on the right side (affecting the 2 right burners). I light it, I turn on the burners (they flare up), I turn off the burners, and 2 minutes later the pilot is out, and the lovely gas smell takes over the house. The stove is only 3-4 years old. I've tried blowing out the area around the pilot, cleaning the underside of the stove top (had some build-up), and there doesn't seem to be a draft coming from anywhere. What's the problem? Can I replace something on it? Thanks for any help you can provide!
Wow this problem sounds exactly like my landlords problem only he is just now saying he is learning of the problem. You even have the age of the stove correct.
Posted on Jun 21, 2010
  • kkdesigns Jul 22, 2010
    Turns out their was a problem with the tubes on the pilot lights. You have to call the company to order replacements.
Pilot lock light on stove is on so stove burners unable to work
This sounds like you may have to fix a problem in the pilot area before it will work. These gas operated devices have to meet a much higher safety standard than their electric counterparts. It is a built- in safety feature. Now, look for any obstruction or crimp in the gas line. My guess is you are not getting proper gas flow or pressure or the pilot could be physically blocked.
Feb 19, 2015 | Thermador Cooktops
Is there a pilot lite I need to light for my stove ffgf3011lw
Some stoves have pilot lights, some have an electronic igniters. If you hear a click, click, click when you turn on the gas, you have igniters.
Dec 06, 2014 | Frigidaire 30" Freestanding Gas Range -...
Will not stay lit
There is a piece that senses the pilot that can go bad. Usually a piece of copper with a bulb right in front of the pilot on one side that screws into the gas valve try replacing that
Sep 06, 2014 | Wedgwood Wedgewood RV Range 21 In. With...
My oven want light its gas and the the pilot light islit
Is this a standard gas cook-top there maybe some small particle blocking the area where the gas comes out and lighting with the pilot. If you feel comfortable try lighting it with a match. First make sure there is not a lot of gas build open, so if there is a window near the stove open that and make you have plenty of ventilation before striking said match.
Mar 13, 2010 | Kenmore 30 in. 32384 / 32385 / 32389 Gas...
No spark to ignite gas on cooktop
Shut off the stove. Then lift up the range top and you will see pilot lights. Remove the cover on the pilot lights. They could be blown out, but usually they are just dirty. Take a pin and poke it through the hole, then carefully scrub the tubes with a brush that go from the range to the pilot light. When your done with that....use a long match and light the pilot light, make sure no gas is on when you do this. No flames will come out, but it doesn't hurt to be extra careful.
This just happened to me so good timing!
Hope this helps
Sep 10, 2009 | GE Profile JGP636 Gas Cooktop
Poorly functioning Shipmate stove
Hi
Normally pressing red buttons on stoves is for lighting the oven. You press the button, light the pilot light, leave it depressed for a minute and then that heats up the thermocouple, which opens a valve and allows gas to the main burner.
Shipmate Stoves are still in business, so you could contact them. The link also suggests places for Shipmate propane gas stove spares.
Shipmate stoves Google Search
Mar 27, 2017 | Brown Stove Works 23 in. TL03-3 Gas...
I have a brown brand gas stove and the oven is not coming on stove has no electical cords
hello. i can help. here is the manual for your stove. http://www.brownstoveworksinc.com/pdf/gas_manual.pdf
look on page 17 as it tells you how to light the pilot light.
Jun 05, 2009 | Brown Stove Works 23 in. TL03-3 Gas...
Can't get burners lit.
1. make sure the gas is turned on.
2. Make sure unit is pluged in.
3 make sure all burner and burner caps are aligned.
If you hear a spark and you small gas it should light.
Make sure the burner heads are not clogged.
If this top has pilot lights make sure the pilots are lit
Nov 23, 2008 | Cooktops
Cooktops Logo
1,958 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
