Question about Cycling
I have lost the drive when i pedal.
My pedals turn as normal but i seem to have snapped something inside the axle? which connects the pedals. or something regarding the drive cogs.
sorry if i not using the correct language but i am not sure what these parts are called.
    Sniper:
  • 58 Answers
Hi! No worries about the lingo!
What you are referring to is the free-wheel hub.  This is the rear hub which allows you to have load when you pedal forward, and then move freely when you pedal backwards.
I had a similar experience with a trike and what was needed was to pull the inside of the hub and replace a small spring that looked kind-a like a safety pin.  This is what makes the clicking noise when you pedal backwards or move the bike forward without pedaling.
Not all repair shops are willing to make this repair, and to be honest, I ended up having to go back several times to get the same part repaired, until I gave up and purchased a new hub. If you like to bike a lot and go far, this would be the best course of action.
Posted on Jun 16, 2009
Viking sew easy 350
It sounds like the computer has lost the program. What model do you have?
Jan 24, 2014 | Sewing Machines
Excercise bike clunking noise
please follow this steps and fix it. God bless you
Remove the screws or bolts securing the ends of the pedals to the crank axles. Slide the ends of the pedals off the axles. Remove any screws or bolts securing the left and right disc shields to the base unit. Pull or pry the disc shields off the base unit and set them aside.
Remove any screws or bolts securing the left and right side shields to the base unit. Detach the side shields and set them aside. Examine the interior of the base unit and locate the drive belt.
Pull the drive belt free of the crank pulley, flywheel and any other pulleys. Discard the old drive belt and install a new belt in its place. Turn the crank axles by hand to confirm that the belt will turn smoothly when the device is in use.Detach the ends of the pedals from the crank axles. Spread a layer of machine grease over the crank axles, then reattach the ends of the pedals.
Remove the bolts connecting the pedals to the swing arms. Detach the pedals from the arms, then spread a layer of machine grease over the axles on the swing arms. On some models, the bolts may also serve as the axles. Reattach the pedals to the arms.
Remove the bolts connecting the swing arms to the elliptical's upright. Detach the swing arms from the upright, then spread a layer of machine grease over the axles on the upright. Reattach the arms to the upright.
Nov 26, 2013 | Nordic Track Exercise & Fitness
Machine is Quivering while excersisng
Use a flat screwdriver to unseat the tabs that hold the front top cover in place. This will expose the flywheel and pedal arm connection points. Rotate the flywheel by hand and determine whether lubrication will accomplish the repairs. If the bearings are exposed, use a grease gun with an extension nozzle and lubricate both bearings with lithium grease. If the bearings are damaged or sealed, proceed to the next step.
Remove the front and side covers on the main frame. Hold the flywheel with one hand and use a box wrench to loosen the bolts that secure the pedal arms at each side of the flywheel. Pull the arms away from the flywheel and remove the bearings from each side.
Test the bearings as before. Lubricate exposed bearings with lithium grease and reinstall them. Sealed bearings must be replaced. Reattach the pedal arms to the flywheel. Replace the main frame covers and front top cover to complete the repairs.
Lubrication
Drive Belt
Nov 13, 2013 | Sole Fitness Sole E55 Elliptical
Quivering while excersising
I have a Proform Smart Strider. We just assembled it & when I tested it there's a very loud scraping sound when I stride, regardless of the level or program...help, pls. Thx.
I recomend you to disassemble again, and repeat the steps. Something must be there ARE not according with the instruction assembling. Try however for to see the some loose parts, bolts, nuts, and lube.
See this small instruction.s
God bless you
Lubrication:
Oct 15, 2013 | Proform Smart Strider SpaceSaver...
Life fitness ticking from foot pedal
1Detach the ends of the pedals from the crank axles. Spread a layer of machine grease over the crank axles, then reattach the ends of the pedals.
Version:1.0 StartHTML:0000000168 EndHTML:0000002129 StartFragment:0000000818 EndFragment:0000002112
Unplug the power cord. Identify the pivot points where the lower handlebars and the footpad link arms connect at each side of the machine. Use a screwdriver to remove the inside and outside elbow covers at each connection. This will expose the pivots.
Put a box wrench on the lock nut at the inside of one pivot and loosen the bolt with an Allen wrench. Remove the bolt and check the assembly for nylon spacers or a bearing. If no spacer is found, proceed to the next step. Replace the nylon spacers, reassemble the connection and reattach the elbow covers. Repeat this at the opposite side of the machine.
Have an assistant hold a deep socket against the inside face of the pivot hub. Make sure the socket is large enough to allow the bearing to pop out. Insert the point of a flat screwdriver into the outside of the hub until it contacts the bearing. Tap the handle of the screwdriver with a hammer to remove the bearing. Repeat this to remove the bearing on the opposite side.
God bless you
Mar 31, 2013 | Life Fitness X8 Advanced Elliptical Cross...
The wheel on my elliptical is stuck. A couple steps and it got stuck. How do I fix that?
see this causes and fix it. God bless you
Lubrication
1 Drive Belt
Oct 14, 2012 | Exercise & Fitness
Bremshey (Tunturi) Orbit Control S elliptical belt alignment
Dear Si: Please do the following>
Detachthe ends of the pedals from the crank axles. Spread a layer of machine greaseover the crank axles, then reattach the ends of the pedals.2
Removethe bolts connecting the pedals to the swing arms. Detach the pedals from thearms, then spread a layer of machine grease over the axles on the swing arms.On some models, the bolts may also serve as the axles. Reattach the pedals tothe arms.3
Remove the bolts connecting the swing arms to theelliptical's upright. Detach the swing arms from the upright, then spread alayer of machine grease over the axles on the upright. Reattach the arms to theupright.
sincerely.
ernesto cuadra
managua, nicaragua. c.a.
Feb 12, 2012 | Exercise & Fitness
My Pro-Form 330 elliptical has a resistance problem--it won't adjust and it seems to be set on a difficult resistance, I can't really pedal it. how do I fix this? I tried switching the levels, but...
Removethe bolts connecting the swing arms to the elliptical's upright. Detach theswing arms from the upright, then spread a layer of machine grease over theaxles on the upright. Reattach the arms to the upright.
Oct 27, 2011 | Proform PFTL79807 - 850 W/ Gamefit...
Cycling Logo
82 people viewed this question
Top Cycling Experts
Marvin
Marvin
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
