Question about Garmin Nuvi 660 GPS Receiver
Touch screen frozen Nuvi 660 - Garmin Nuvi 660 GPS Receiver
Most likely due to internal cable coming loose from main board, perhaps after dropping unit.
Requires fair skill level to open cover and replace cable in connector.
Posted on Jun 23, 2009
My garmin nuvi 660 touch screen dosen't work
To calibrate the touchscreen on a nuvi 300 or 600 series:
  1. Power the unit On.
  2. From the Where to? / View map screen, touch Settings (wrench icon).
  3. Touch Display.
  4. Touch Recalibrate.
  5. A new screen will display that says Press Dot.
  6. Touch the center of the dot.
  7. Keep touching the center of the dot as it moves around the screen.
  8. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated.
If your touchscreen is not responding to any touch and preventing you from recalibrating the touchscreen using the instructions above, please follow the steps below:
  1. Connect your nuvi to your computer with a compatible USB cable.
  2. Open the Garmin Nuvi drive located in MyComputer/Computer. (Note: Mac users can locate the Garmin Nuvi drive icon on the Desktop.)
  3. Open the Garmin folder.
  4. Locate and delete the GUPDATE.GCD file.1
  5. Safely disconnect your nuvi from your computer.
  6. Power the nuvi Off.
  7. Power the nuvi on by holding the power button.
  8. Continue holding the power button down for 1-2 minutes until the screen calibration option displays.
  9. Touch the center of the dot as it moves around the screen.
  10. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated and should respond properly.
Oct 24, 2010 | Garmin Nuvi 660 GPS Receiver
My Garmin Nuvi 660 touch screen is frozen. I've tried to reset it with the switch on the back. I've tried connecting it to my computer to reset it. Powering on and off don't work.
Sounds like your firmware needs updated. Just go to Garmin’s website then downloads and update your firmware. As long as there is no screen damage but just touch screen not working that will fix it. An easy test is to take out the battery and if the unit works for second then freezes you just need to update firmware. Turn off unit plug into computer via usb cable and do firmware update, that easy!!!! Hope that helps?
Aug 16, 2010 | Garmin Nuvi 660 GPS Receiver
Nuvi 660 touch screen not responding
Please see this link:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
May 20, 2010 | Garmin Nuvi 660 GPS Receiver
Nuvi 660 screen locked
I HAVE THE 205 UNIT MY LOCK IS ON THE POWER BUTTON SLIDE IT TO THE RIGHT IT LOCKS AND PUT IT IN CENTER TO UNLOCK - YOURS SHOULD BE CLOSE TO THAT - HOPE IT HELPS
May 09, 2010 | Garmin Nuvi 660 GPS Receiver
Nuvi 660 : no response on touch screen
Use your fingernails to lightly pry the screen surround away from the screen. Mine did this and the casing was touching the screen. Once I did this, all was well.
Be careful, you are not trying to bend the case, just get it off the screen.
Jun 13, 2009 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 touch screen freezes up. Soft
I sat on the phone for 30 minutes waiting for Garmin support when my Nuvi suddenly had no touch screen response. They had me delete a file on the device (with it hooked to my computer) then reboot and it went thru a touch screen alignment and it worked.
Sadly, it has frozen again and I don't recall the file (it had been a GCD file in all caps, that is all I know and I don't see a file in all caps any more). I will be calling support tomorrow.
My take is that it *is* a firmware thing *and* there is some way to reset the firmware.
May 01, 2009 | Garmin Nuvi 660 GPS Receiver
Garmin 660 locked up / frozen
Resetting the device merely resets the power connection, on some devices there is a reset to manufacturer defaults on settings, but not your stored data. Working with GPS's 40 hours a week I constantly have to use the reset button when they lock up. Just press it in for a few seconds then if it doesn't power back up just hit the power button and everything should be fine.
May 09, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
633 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
