Question about Siemens SpeedStream 4200 (13A4200001) Bridge
No internet service
My power and dsl light on my windstream modem are working, but not my ethernet?
My son went on the computer and reset the modem to the computer.
Posted on Jun 17, 2009
Is it possible to connect a standard DSL modem - without Wi-Fi (with 1 Ethernet port) and a DSL modem - Wi-Fi (with 4 Ethernet port) to broadcast Wi-Fi singles
Does the non wifi modem give out DHCP addresses?
Can the wifi modem be set up to receive it's IP address from DHCP?
If the answer to both these questions is Yes then that's what to do as a first step. Make sure the wifi modem DHCP service is disabled as it must NOT give out DHCP addresses.
Connect the ethernet port of the non wifi modem to one of the LAN ports of the wifi modem and NOT the DSL/WAN port. The wifi modem is not participating in any DSL connectivity at all so it's DSL light will remain off. The non wifi modem is doing the DSL duty so it's DSL light should be correctly illuminated.
May 01, 2015 | Computers & Internet
Tip
Troubleshooting DSL Modems
Ever look at your DSL Modem and wonder what all those lights mean? Why do some flash, while others remain solid? What if your lights are different colors? How do you tell if your DSL Modem is working correctly?<br /> <br /> Each light on your DSL Modem represents a function. The light is an indication of whether that function is working properly. Sometimes the placement and title of each function can vary by modem manufacturer, but they are pretty standard in interpetation. If you look closely your modem, you might find that each function is labeled in small print to help identify them.<br /> <br /> A standard DSL Modem has a light for power, internet, ethernet, link and wireless connection. A healthy DSL Modem will have a steady green light that does not blink or flutter for all features other than internet, ethernet and wireless. A flashing or fluttering light indicates movement and useage. When you are connected to your DSL Modem wireless, the light for this feature will blink indicating a connection and/or active useage. If the internet connection is working properly the color of the light will be green. If the connection is working but experincing a problem the light can turn to yellow or orange. If the connection fails, the light on the DSL Modem can be red or absent depending on the problem causing the trouble. If your service is turned off by the provider, more than likely the light will be "off".<br /> <br /> If your lights turn a different color, are absent or your internet connection fails try power cycling your modem before reporting the trouble to your provider. Power cycling helps the DSL Modem to reset its connection and repair your internet services.<br /> <br /> If you are using a DSL Modem alone to connect to the internet (no additional router) you can power cycle it by first turning off your computer and then unplug the modem itself from the power source at the wall. Wait for 1 to 2 minutes and then plug it back into the power source and wait for the warm up to finish before rebooting the pc.<br /> <br /> The DSL Modem should go through the normal warm up procedures of blinking lights, making them all stable and solid green ect. You will know when its finished warming up when the features are set at solid green (other than eithernet, internet and wireless connection as explained above). When the modem finished the warm up, reboot your computer and check your internet connection.<br /> <br /> Power cycling your DSL Modem can help keep your connection healthy and running at optimal speeds.<br />
on Mar 30, 2011 | Computers & Internet
My modems LAN light is blinking and I can't get Internet, I've tried unplugging it, but the problem still exists, please help
There will be 4 lights...
Power
Dsl
Internet
Ethernet
Power light indicates power supply is good...
Ethernet light indicates connection between modem and computer is good...
DSL light indicates connection between modem and telphone line is good... Also DSL light should be steady and it should not flash...
If it flashes then it says there is a lot of noise in telephone line...
Internet light says whether the internet status is connected or not...Internet light can flash depending upon the internet activity...
Feb 03, 2011 | Paradyne 6381 ADSL2+/ReachDSL Router...
Hi,,,,was wonder if there a problem....on that windstream black box that has power ethenet dsl activity ,the avtivity blenks a lot.....is there a problem
No, it only tells you that it is processing something and that the modem is active. Even if you are not doing anything on the computer it may or may not blink. But generally, it is perfectly fine.
What you have to watch out though are the
>POWER, if this light turns RED or OFF, it means there is something wrong with the modem.
>ETHERNET, if you are using an ethernet cable to connect your computer to the modem, it may or may not blink but it's ok, however, if it is OFF, it means there is no connection between the modem and the computer, check the ethernet cable and make sure it is securely plugged into the modem and into the computer as well. If you are using a wireless connection though, it's ok to see the ethernet light to be off.
>DSL, this light should always be STEADY which means the server where you get your internet service is fine. If it's blinking or RED, it's otherwise. If DSL is OFF, first check the connection between the modem and the telephone jack.
I hope it helped you. Rate for this information will greatly be appreciated. Thank you!
Jan 20, 2011 | Computers & Internet
I have had problems connecting to internet all weekend (internet - red light), am on now but internet and ethernet green light keep blinking, is this ok.
No because dsl light should be solid green light. You need to contact your ISP to check if there is a problem on the network.
Jul 11, 2010 | Computers & Internet
Ethernet light went off and won't come back on on dsl modem
no matter what the model is, the thing has to work. it is not that ur new modem is smaller so it is not working . Check the suggestable router modems for AT&T . if ur modem is working fine , then install the modem drivers in your Pc.
Aug 21, 2009 | Computers & Internet
How to use bellsouth router on windstream internet
yes you have to configure it with the dsl modem plug your modem ether net cable into routers ethernet,open your modem configuration page by typing 192.168.1.1 login by using by default the router login are "admin"and pass word is also" admin" note down dns setting and other setting which yopu may need tosupply the router now open router login page and supply required connection setting change set router default address 192.168.1.2 soit should not conflict whith each other supply dns setting, enable wireless ,set wireless secuirty ,try now sitehr@gmail.com
Aug 16, 2009 | Westell Wirespeed VersaLink...
The modem has green lights for power, but the DSL light either flickers green or goes to solid red.
Try power turning off once and if still remains the problem then the problem could be with internet service provider so contact them once. and if they say we are good then you need to look at internal bugs.
for that visit following website where you can find complete service manuals.
http://www.dsldepot.com/dslmodem.asp?modem=21
http://www2.windstream.net/downloads/links/SpeedStream211.pdf
Thank you.
Jan 03, 2009 | Efficient Networks SpeedStream 5100 Modem
Internet
Well, I understand that the modem is SS4100, which means ther are
5lights on it being, Power, Ethernet, DSL, Internet & Activity....
Note:The trouble shooting is done according to the Light Status on the modem.
1. No matter what the proble is, the first step is to Power Cycle the modem to eliminate the static on the modem(to switch it off and back on).
2. If the Power Light is anything other than a solid green, then the modem is fried(except the fact that the adapter is plugged and working).
3. If the Power is green and Ethernet is off, then check for the LAN cable at the back
of the computer if its connected to the modem.(It turns green if connected properly)
4. If the DSL light is anything other than solid green, then call up the ISP tech's to ask why the intenet is not working.
(make sure the DSL cable is plugged firmly onto the back of the modem and the wall jack)
5. If the Power, Ethernet and the DSL is green and the internet is not, the open up the Modem page(type 192.168.0.1 in the address bar and enter for the modem page), and cross-check for the username and the password. Save the changes and your internet is working!!!
6.  The Activity light usually blinks green and it does't have much to do with the troubleshooting.
The above are the basic troubleshooting steps.
Hope it solves your problem......
Dec 20, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
DSL modem connected but no internet
Have you installed DSL filters on all your phones and make sure you don't have on on the line for your modem?
Jun 28, 2008 | Westell Wirespeed LiteLine 6100...
Siemens SpeedStream 4200 (13A4200001) Bridge Logo
448 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
