Question about Casio EXILIM ZOOM EX-Z70 Digital Camera
Lens stuck when i turn on the switch ,the lens doesnt come outside but when i put the camera facing lens downward the screen pops up with the Check connections
  • 586 Answers
The slide motor start malfunction, You have to replace complete lens block assembly.
Thanks for using fixya.
Posted on Jun 16, 2009
My easyshare C1550 lens is stuck open and the screen says Lens obstructed
Try removing the battery then put it back and turn it on. If it still wont close, place the camera facing the ground and gently tap it repeatedly. There might be a debris stuck in the mechanism.
Aug 09, 2012 | Kodak EasyShare One Digital Camera
F-stop stuck on F00
aperture stuck at f00.... 50mm 1.8... please help!!!
Apr 22, 2012 | Canon EOS Rebel XSi Digital Camera
Lens will not extend when turned on message on screen lens error
This error indicate that focusing ring got stuck or jammed due sand, dust or may be due to external shock caused by dropping the device.
  • Try compressed air. With a fine tip blow off gun around lens barrel. It should remove all dust and sand. Turn the camera on this will solve the problem.
  • You can gently bump the camera to try to free the focusing ring.
  • You can try to turn camera ON at the table (facing it to the ceiling), don't put camera down face to the floor when opening.
If motor is running but lens won't retract sometimes lens would slip off with the gear or break off a tooth in the gear when it gets dropped. Try to gently move the lens barrel around with the finger and see if it is moving, but if tooth or gear is broken lens will move once or twice then it will stuck again.
Else your camera need to be disassembled to get at the focusing ring at Service Center.
Thanks and have a nice day
Jul 04, 2011 | Fuji Cameras
Dropped my camera and now lens stuck out and beeps and switches off
Hi
Do you get a E18 in the bottom left on the camera screen before the Canon PowerShot A95 switches off?
If you do see this error code then t
he problem could be because dirt or sand has got into the lens mechanism.
Firstly you should contact your local Canon repair centre and Canon may fix it for free. If this fails you can try the suggestions below, but you do so AT YOUR OWN RISK as this could make the problem worse.
Make sure the batteries are new or if you are using rechargeable batteries they are fully charged.
a) Remove the batteries from the camera, and unplug any USB cable. Wait for 5 minutes, then put them back in and switch the camera on.
b) Try using compressed air with a fine tip. Use between the lens turret and the camera body and turn on the air while moving the tip around the lens. It should remove any dust or sand. Turn the camera on and see if operates correctly.
c) Another, slightly unusual method is to gently tap the padded USB cover part on a hard surface. Amazingly this does sometimes work.
d) Lastly, you can try and force the lens back into the camera. With the camera switched off place the camera on a surface with the lens facing up - look at the spacing between the lens and the lens housing. If it is not even all the way around the lens VERY VERY GENTLY press down the lens on the side where the gap is the biggest. Hopefully you should hear a reassuring "click" as it pops back into place. Try powering the camera back on.
If these suggestions do not work then you are looking at a professional repair.
David
Feb 13, 2011 | Canon PowerShot A95 Digital Camera
I turn on my camera that has full battery but it doesnt turn on
Sounds like sand in the lens cavity. Use a fully charged battery, then lie the camera flat face down on the floor, ideally a carpet. With the camera OFF, lens face down with the carpet, switch the camera on. It will take a number of go's to release the **** stuck in it.
Mine took atleast 15 go's. Better than chucking the camera out, and saved atleast 80 dollars and a trip to Germany!
Jun 02, 2010 | Kodak EASYSHARE M763 Digital Camera
It suddenly crashed so I took the battery out. Now it does nothing except beep when I turn it on and the screen stays black! Help!!!1
The lens is stuck. Switch on and tap the edge of the camera against your hand quite sharply. The lens should eventually pop out and screen operate as normal. Make sure lens casing is totally clean before switching off.
Cheers
Paul
Aug 10, 2009 | Samsung L200 Digital Camera
Camera stuck in "lens error" mode
Hello, It's time to let a Nikon camera repairman take a look. If lens does not pop out, then it could be motor, shutter, etc, etc. Check out one of our Camera Repair providers and get a repair quote.
Nov 30, 2008 | Nikon Coolpix 4600 Digital Camera
Lens error,restart camera
My Camera: Canon PowerShot SD770 IS Digital Camera
Went to the beach yesterday, by the end of the night my camera gave me this error: "lens error, restart camera". The lens would no longer come out.
I figured sand got stuck within the lens, so I did the following:
1. Turn camera up-side-down (with lens facing down)
2. Gently tap the sides of the camera (to loosen particles in lens)
3. Turn camera on
4. The lens will eventually come out
5. Gently tap the sides of the lens
6. Turn camera off (continue tapping side of lens as it retracts)
I turned the camera on and off a couple of times to ensure I removed all sand particles from the camera.
Now the camera works...thank god.
Aug 31, 2008 | Canon PowerShot SD600 Digital Camera
How can i fix a stuck lens on a Nikon COOLPIX L11?
I have the same problem with my nikon coolpix s200. After 2 months the lens of my camera won't go inside. On the lcd screen stood lens error. I went to a shop with this problem. He took the battery out of my camera and press the off and on button for a while. Then he put the battery back in the camera and press the on button. The lens of the camera was now going inside en outside and inside and outside with a strange noise. And also on the screen stood lens error. Okey, the lens is inside the camera. But how can I fix this camera? What is the problem? What have you done? Please let know..!!
Jul 13, 2008 | Nikon COOLPIX S200 Digital Camera
Lens will not open
whille turning cuyber-shot ON, tapp the camera with other hand. if you put the lens side downward, this trick will work.
May 28, 2008 | Sony Cyber-Shot DSC-P100 Digital Camera
Open Questions:
See all Casio EXILIM ZOOM EX-Z70 Digital Camera Questions
Casio EXILIM ZOOM EX-Z70 Digital Camera Logo
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
