Question about NetGear WGR826V Router
Netgear wgr614 will let me connect to some sites but not others
Computer #1 is hardwired to the wgr614 router,computer#2 is connected wirelessly,it's the wireless connected pc that wont connect to certain sites,that are available with the hardwired pc.Router settings are at default settings.Appreciate any help!
  • rdaltonsr Jun 16, 2009
    Sorry,I forgot to mention I'm running xp pro,IE8,mtu is set at 1500.I don't think it's browser problems,same deal with IE and firefox.thanks for the quick responses!
    Did a system restore.curing the problem.thnks for the responses
    Genius:
  • 1,341 Answers
I dont think there is anything wrong between your router.It's probably some other problem with the wireless pc..Also I am assuming you are using windows environment? If yes be careful when updating as there is a problem with internet explorer 8 and compatibility issues with some sites, even with youtube.com at the current moment.
Posted on Jun 16, 2009
Ialso have suddenlink
How to Set Up a Netgear WGR614 V5 Wireless Router
Netgear routers--like all wireless routers--give you the opportunity to access the Internet with your laptop or wireless-adapted computer from virtually anywhere in your house within range of the router's WiFi signal. Though slightly different in appearance from other router models by Netgear, the WGR614 V5 acts similar in its setup process as others such as the WGT624 or WNR1000 series routers.
Things You'll Need:
Netgear WGR615 V5 routerNetgear resource CDEthernet wireBlue network wireModemComputer
1 Prepare to install the Netgear router. Log off and shut down your computer system. Turn your Internet modem off and/or disconnect its power supply from the electrical outlet. Take out the contents of the Netgear router box and verify that all the essentials are present: the resource CD, the yellow wire and the router itself.
2 Connect the Internet modem to the Netgear WGR614 v5 router. Locate the yellow Ethernet wire running from one end of the Internet modem to the computer's Ethernet port. Unhook the computer-end of the Ethernet wire and insert this end into the port on the router labeled "Internet." After inserting, confirm that the wire runs from the modem to the router.
3 Connect the Netgear router to the computer. Grab the blue cable supplied with the router. Securely insert one end of the blue cable into one of the four "LAN" ports on the router (the "LAN" ports are labeled with numbers from 1 to 4). Insert the other end of the blue wire into your computer's Ethernet port.
4 Start your network devices. Turn on or connect your Internet modem to an electrical outlet. Wait for at least two minutes to allow the modem to fully boot. Plug the Netgear router into the wall or electrical outlet as well, and wait one to two minutes. Turn on your computer.
5 Look at the Netgear router to verify that all lights are on. The "power," "Internet" and "wireless" icon symbols on the front of the router should be solidly lit. One of the four "LAN" ports should also be lit with either a green or amber color.
6 Insert the resource CD that came with your Netgear router to launch the "welcome" screen. Select "Router Setup" from the menu to begin the "Smart Wizard" setup application. Read and follow the setup steps, including naming your SSID (secure set identifier) or "network name" and setting a level of wireless security. Finish the setup process, ending with the registration of your Netgear router.
7 Verify that your Netgear router has been set up correctly. Open an Internet browser from both the computer that is connected to the router and on a computer that has a wireless card or adapter. Surf to your favorite Internet sites to verify your connection is working. Open your "network connections" utility on your operating system and make sure it shows that you're connected to your own wireless network.
Jan 09, 2012 | NetGear WGR614 Wireless Router
Tip
Configuration of NETGEAR router as Access Point: The below steps illustrates the...
The below steps illustrates the usage of router's like WGR614, WGT624, WPN824 as an access point to extend the wireless network in your location. The only required setup is that you should have a DHCP server running on your network ( be it your modem or a different router).
1. Connect a computer directly to NETGEAR router on any of the four LAN ports.
2. Access the router, usually with http://192.168.1.1 or http://www.routerlogin.com.
3. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
4. Click on wireless settings in the left hand side menu Under Setup.
5. Change the network name SSID to some other name.
6. Select security options as 'WEP (Wired Equivalent Privacy)'.
7. Set the 'Authentication Type' as 'Automatic' and Set the 'Encryption Strength' as 64-bit.
8. In Key 1 type a 10 digit number.
9. Apply the settings.
Click on LAN IP setup from the left menu.
1. Change the IP address of the router from 192.168.1.1 to a free IP of your existing DHCP network.
2. Also disable the DHCP of the router by unchecking the box for 'Use router as DHCP Server'.
3. Click apply and click ok for any popup message that arise.
4. Once the browser display some error message like CANNOT FIND SERVER, ACTION CANCELLED etc, turn off the router and restart the computer.
Now, connect the two router in the following way:
1.Connect Ethernet cable from the Lan port of the existing router/modem to the Lan port of the NETGEAR router.
2. Powercycle both the routers and your computer
3. You may connect other computers' directly to NETGEAR router or wirelessly as per your requirement.
on Mar 18, 2010 | NetGear WGR614 Wireless Router
Installed router and now I can't pull up any sites...shows my pc is conn to my network but can't pull up any sites....can't conn when I'm hardwired to router either...any suggestions
did you reset all connections? Start from your DSL/Cable modem power it down. leave it down. Power down the router and leave it down. Wait 2 min and then power up your DSL/Cable modem let it do it's things (approx 45sec) then start up your router and connect your computer.
Is your laptop connecting wireless or wired to the router?
May 10, 2010 | NetGear WGR614 Router
Trying to connect a new Dell E6500
You need to use a computer hardwired to the router to check the wireless settings.
1. Please open any web browser like Internet Explorer or Mozilla Firefox.
2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
3. A window will prompt for a username and password. The default username is "admin" and the default password is "password".
Note: Username and password are case sensitive. If it does not take password as the password, you might have changed it when you ran the NETGEAR Setup CD so please try other passwords.
4. Click the Wireless Settings under Advanced tab.
5. Check the box under Enable Wireless Router Radio and Enable Wireless SSID Broadcast.
6. Click the Wireless Settings under Setup.
7. Change Channel (recommended are 1, 6 and 11).
8. Change the SSID to uniquely identify your network. You might have a similar SSID with your neighbor.
Note: Do not change the SSID if there are already other wireless computers that can connect to the network.
Other factors that you may consider when you are not able to view any available wireless network:
a. Switch for the wireless adapter is turned off
b. Distance between the wireless router and computer
c. Possible wireless interferences
Apr 22, 2010 | NetGear WGR614 Wireless Router
Will not let my laptop find it
No Wireless Connection Found in Range
Note: You need to use a computer hardwired to the router to check the wireless settings.
1. Please open any web browser like Internet Explorer or Netscape Navigator.
3. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
Jul 05, 2009 | NetGear WGR614 Wireless Router
Computer is not pick up signal from router
Jun 26, 2009 | NetGear WGR614 Wireless Router
No connectivity to 2nd desktop or laptop - although worked before
Hello....sudden loss of wireless on two computers, in the same home, may indicate that a powerful source of wireless interference has just arrived (since your wireless router light is still on).
1) Does the signal improve if you move the router, or move the laptop closer to the router?
2) Have you had any success with changing the channel on your router? (Login to router > select Wireless Settings > Channel)
If you have not moved furniture yourself, or installed a device which could interfere with the signal (eg a DECT phone), it's possible a neighbour's new router may be the culprit.
Please come back to Fixya if this does not help.
Jan 11, 2009 | NetGear WGR614 Router
Hardwired working, wireless not
hi ,
u will have to increase the beacon interval of the router .... that can be done wih the help of a router setup.... or
Oct 29, 2008 | NetGear WGR614 Router
Router connection problems
i assume that you are using 2 hardwired computers. if so, make sure that the cables are connected to the correct ports. the modem should be connected to the wan/internet port of the router and the 2 computers should be connected to the ethernet ports. try to do a power cycle by turning off the all the devices then turn on your modem first, then the router, lastly the computers. if you're getting the same problem, make sure that the router is properly configured according to the settings of your ISP. for example, if your ISP is dsl, you need to set you router to pppoe but if it's cable, you need to clone the mac address of the computer (the one that can access the internet directly to the modem) to the router.
if you're using wireless computers, you need to check if you are using the correct wireless settings to your computer. log in to your router's page to check the wireless settings.
hope this'll help you
ciao!
Oct 26, 2008 | NetGear WGR614 Router
The netgear router has problems connecting with the intetnet please help me
I have a problem here.
1) When i connected the modem to the computer, it works good.
2) I have more computer now, so i bought a router.
3) This time, when i plug in the modem to router and router to my 3 computers.
4) The local network is working but not the internet.
Any solutions? I have tried trendnet router, netgear. It's definitely not the router problem.
I have tested the same router in other ADSL line, it works.
Please help
Thank you
Aug 23, 2008 | NetGear WGR614 Wireless Router
NetGear WGR826V Router Logo
118 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
