I have a remote control for my converter box brand rca #dta800 but i want to program my control to my tv and i dont have the code.
  • 25 Answers
Http://www.1800customersupport.com/productdocuments/DTA800_code.pdf
look inside for the codes to your tv model and it usually is trial and error.
Posted on Jun 16, 2009
Does the rca dta800 remote work with the apex dt502 converter box?
No. RCA remote controls (any model) have no set-up code to Apex brand devices. Electrohelponline
Nov 16, 2014 | Televison & Video
Can't find the codes for my emerson tv codes for
Instructions
    • 1Remove the battery cover and insert new batteries into the remote. Press the "Power" button on the television to turn it on.
    • 2 Press the "PRM" button that is in the lower left corner of the remote control. You should see the signal indicator light come on.
    • 3 Click the DTA800 TV Codes link in the resource section to view a list of program codes for the converter box. Enter the 3-digit code for your television by pressing the number keys on the keypad. Press the "OK" button when finished. You should see the indicator light turn off.
    • 4 Point the remote at the television and press the volume keys on the remote control. If the volume for the television changes, the remote has been programmed successfully.
    • 5 Enter another 3-digit code for your television if the first code fails to program the remote
    • CODES : Emerson
      • The RCA Universal Remote has 17 different codes for Emerson televisions. These codes are 011, 026, 027, 028, 029, 030, 031, 032, 037, 042, 053, 064 065, 067, 075, 076 and 079. There are 18 different Emerson VCR codes. These codes are 008, 009, 010, 013, 015, 020, 023, 027, 034, 041, 042, 047, 057, 062, 065, 067, 068 and 070. There are no codes for Emerson cable boxes.
      Hope this helps. =)
Sep 30, 2014 | Televison & Video
Code to program my JVC tv to the DTA800 Digital box
Hi debbie,
I see yiu need a code for your JVC TV to program ti the DTA800.
You can try The codes for JVC TV to program universal remote are 159, 013, 012, 182, 054, 060, 065, 066, 067, 123, 157, and 158. You can check these codes one by one.
I hope this helps.
mvincentc
May 28, 2011 | RCA (DTA800B1) Video Converter
I have a RCA Digital converter box remote that needs to be programmed for my TV and I do not have the code or know how to program it manually.
You have a limited number of TV brands that can be controlled by this remote as DTV converter boxes are just basic function devices. If your TV is not on the list, then it cannot be controlled. If your TV brand is on the list, look for the 3 digit codes next to your TV brand. You may have to try all the codes if one does not work. You should have the list on a separate leaflet that came with your converter box.
Press PGM on the remote. Enter the 3 digit code with the number keys. Press OK. Test by pressing the volume button and see if it works. If not try another code next to your TV brand from the list.
If you lost the leaflet then here is a link online to see this information:
http://www.1800customersupport.com/productdocuments/DTA800_code.pdf
I'm assuming you have the DTA800 box.
Aug 08, 2010 | Televison & Video
RCA DTA800 TV Converter Box I need TV codes for the remote to work. The TVs are a GE, phillips magnabox
Good day,
I might be missing something, but you are describing a converter box that converts digital signals from an antenna to analog.
The converter box will be set to channel 3, and you should set your tv's to channel 3 as well.
Using the remotes that came with the tv's go into setup and if available as an option, you will find an option to select cable/antenna or automatic. Select automatic or antenna and save. If there is a selector switch on the back of the tv's, set to 3.
Connect antenna cable into input, and use supplied cable to connect from the output of the converter to your tv.
plug in power supply for converter box, tune tv to channel 3 then follow instructions to setup converter box including channel scan.
When done, the converter remote will control everything. However, the tv volume control will work even though the converter remote will have volume as well. The tv remote as well is needed to shut off or turn on tv. These functions can on most tv's be performed on the set as well.
No codes are required. The converter remote will work on any tv.
If you want to use both tv's then you will need a splitter on the output of the converter to send the signal to both tv's. Only one channel can be viewed at a time.
Viewing separate Chanel's requires a second converter box and a splitter connected to the antenna cable for viewing separate channels.
More options are possible, but I hope this helps you get started.
The converter box takes place of the tv's tuner and in essence disables it.
Nov 05, 2009 | Tablets & eReaders
Need Program Code!!!
the code is just 0000. It worked for me.
Apr 17, 2009 | Apex Digital AT1308 13" TV
Lost code for rca DTA800B1 digital converter box
I have an RCA DTA800 converter box but I need the codes for my Magnavox...need help
Feb 19, 2009 | Jensen JER-422 Universal Remote Control
Need sanyo tv code to connect rca/dta800 converter box
sanyo 037,082.083.124.198,268.274 Press program, three number combo, ok, check volume control for function
Jan 01, 2009 | Insignia Digital-to-Analog Converter for...
Haier / Celera TV & RCA Converter Box remote code
hi guys,
pgm-->tv code-->ok-->you are done
try this link for codes.
hope you got it.
Satya.
Jul 18, 2008 | Televison & Video
Remote control programming codes
i have a GE t.v. and just bought the RCA DTA800 converter box. none of the codes that were in the manual worked for my t.v. can anyone help?
Jun 19, 2008 | Televison & Video
Televison & Video Logo
138 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
