Question about RIM BlackBerry? Curve 8330 Cellular Phone
Blackberry Curve will not play video's I save to my memory card-
I am having the exact same problem! I will record a video WITH the phone and then try to play it back and it says Media processor busy or Unsupported format.. The videos play just fine on the computer or even in another phone but not my Curve. HELP!
Also, every once in awhile when I receive a call and try to answer the person calling can hear me but i have complete silence. This even happens when I dial out or check my voice mail messages. To fix the problem I have to take the battery out to reset it and its extremely aggravating! If anyone has a solution PLEASE let me know. Thanks!
I had a few videos I downloaded use 2 be able 2 watch them on my curve but 4 no reason they stopped playin, says summin about device drivers busy or meady device busy, weird and verry annoyin if it don't work mate I would suggest throwing it at a wall, didn't work 4 me but maybe ul av better luck lol kl
Posted on Aug 08, 2011
  • 25 Answers
1st check the video formats for the videos your trying to play. most fones only play Video: MPEG4 Video 320×240, 300 Kbps, 20 fps
Audio: LAME MP3 44100Hz stereo 96Kbp. using this format reload the video and try it.
secondly ive had trouble with my fone and this isssue was a blown speaker because the fone got to much moisture. check this or call your carrier.
Posted on Jun 16, 2009
My phone does not accept memory card. i have incerted it but the phone cant read it. blackberry curve 8520
first of all try inserting the memory card into other phone if it works then format it and re-insert it again.if still it does'nt work then check out your memory card jack present in blackberry.
Sep 11, 2013 | Blackberry Curve 8530 - black Verizon...
I pluged my blackberry 8330 onto my xbox360 to
Try to clear your memory card first ,then just put other things inside.
Jul 08, 2010 | RIM BlackBerry? Curve 8330 Cellular Phone
I have videos on my 8310 blackberry and i want to tranfer them to my desktop to play them.
Hi, Video files will be stored on memory card in blackberry, so please take the memory card and connect the memory card to computer. you will see a saperate drive in My Computer. Now you can transfer the video files to computer.
OR you can try another method. Please install latest version of Desktop Manager in your computer, connect blackberry using USB data cable, Then you can transafer the data, files, videos etc. If you dont have Desktop Manager software cd to install, you can donwlaod the software from blackberry.com. I hope this information will be helpful.
Nov 17, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
I have a blackberry curve w/ a 2gb micro sd memory card.but i cant store or save anything to the memory card.how do i do it?
Check it first if your memory card is recognized by your unit, if not try it to insert in different phone just to check it if it is working or not.
if not then more likely it is corrupted
Nov 05, 2009 | RIM BlackBerry Curve 8310 Smartphone
Changing Memory options for S3310 mobile
FOR CONTACTS :
1).go to phonebook in menu.. 2).select any number(default it is selected).. 3).go to options->settings-> select save new contacts to->choose ur memory..
FOR BLUETOOTH:
u cannot change it to memorycard..
u can choose memory card when saving radio songs,video,camera,songs.No other default options are available to change whole memory to memory card..
Sep 14, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Memory Card Error on New T-Mobile Blackberry Curve
use the computer to save what u have on it and then format the card and then u can copy everything back to the card and see if it will work then
Aug 11, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
Cannot play video recorded on my 8130 Pearl
It is possible that these videos have become corrupted and will not run you could try to download some codecs to your computer and see if that will make these run but that is about the best that can be done in these situations.
Kyle
Jul 01, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Blackberry curve won't pair with my bluetooth headset
Try the following. Hope this helps.
Okay,
1. Go into "Media" on your BlackBerry and enable incoming files (Menu-->Receive using bluetooth).
2. Find the file on your friend's device that you wish to send, and beam the said file accordingly.
2a. If you have not "paired" (created a friendship between) the two devices before, you will need to do this first...
2b. One of the devices will ask for a PIN code first and on this device you need to create a four-digit, numeric password that can be anything you like.
2c. On the second device, enter the four-digit, numeric password you created and follow the simple, on-screen prompts on both devices to complete the pairing (you can also pair the devices in advance by going into Menu-->Set Up Bluetooth).
2d. Depending on the devices being used and the time taken to complete the pairing, you may need to re-send the file (go back to step 1), otherwise, continue below...
3. When your friend's device tries to send you the file, your BlackBerry should ask you to name the file and where to save it; if you have not set the device as "trusted" in the bluetooth settings (Options-->Bluetooth-->your friend's device), you may need to approve the file transfer first though.
4. The file should now be on your device.
Note: by default, all
* Pictures are saved into /Device Memory/home/user/pictures or /Media Card/BlackBerry/pictures if you have a memory card.
* Sounds (including songs) are saved into /Device Memory/home/user/ringtones/ or /Media Card/BlackBerry/ringtones/ if you have a memory card.
* Videos are saved /Device Memory/home/user/videos or /Media Card/BlackBerry/videos if you have a memory card.
In other words, unless you specify somewhere else in step 3, this is where you will find your file.
And remember, your incoming file transfer WILL NOT WORK UNLESS YOU FIRST "PAIR" (CREATE A FRIENDSHIP BETWEEN) THE DEVICES, go into Media and CLICK MENU-->RECEIVE USING BLUETOOTH!!!
Jan 28, 2009 | RIM BlackBerry Curve 8310 Smartphone
Video recording/playback for blackberry curve 8310
The blackberry curve can record video and view youtube pages as long as you have the latest device software for you phone all you have to do is download Blackberry Desktop Manager to your PC and download the correct Device software and you can update it yourself to enable the video recording capabilities and view youtube and various other video sites.
Here are some links to various providers and choose yours from the list below
ATT
TMobile
Jan 13, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
BLACKBERRY CURVE 8310 video help!!!!
While the 8310 BB do not come standard with the OS to let you create your own videos you can dwonload OS 4.5 to your CPU and then download the new OS to your phone. I did this two days ago and it works really well...I can now look at youtube.com as well...very cool.
Aug 08, 2008 | AT&T BlackBerry Curve 8310 Cell Phone -...
RIM BlackBerry? Curve 8330 Cellular Phone Logo
1,697 people viewed this question
Top RIM Cell Phones Experts
Longtime User
ismael castillo
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
