Question about Samsung HL-R4266W 42" HDTV-Ready Projection Television
THE TV WILL NOT TURN ON, THE LAMP SIGN IS FLASHING, WE HAVE JUST REPLACE THE LAMP BUT IT IS STILL NOT WORKING?
  • pjh1253 Jun 19, 2009
    replaced both and still nothing ......
I'm having the same issue. Which ballast do you replace? Is it located on the board just underneath the Lamp housing?
Posted on Jul 13, 2009
  • Samsung Master
  • 3,866 Answers
Well when you replace the lamp more then likely you need to replace the balast as well this will shore up the problems you may have with both.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Jun 16, 2009
  • Grand Canyon Tech
    Grand Canyon Tech Jun 19, 2009
    Well if the balast is new and the lamp and your still getting error codes then the power supply unit has got to be a culprit in this case.
When I turn the tv on it came on for a minute then started flashing on and off then went blank but the power light keep flashing off and on with a blank screen.
This problem is easy to repair. If when you turned the tv on and it had sound and picture for a second or two, and the power went off and the power green light keeps flashing on and off, it is a bad CCFL backlight lamp inside the LCD panel which has 10 of these lamps in it, but only one is bad. Replace the lamp and the tv will power on. What the tv is doing is, it has stored a lamp error code on the main board and turning the power off. The replacement lamp is part # RLMPLA029WJN1 and you can buy them at www.encompassparts.com for $19.49 ea. Go to their web sight and sign in as guess to order. I can give you step to step instruction on how to check how many lamps you will have to order if you need me, too. You will have to take the tv apart to check them.
Aug 03, 2011 | Sharp LC-32SB23U 32 in. LCD TV
Changed lamp and TV won't turn on, power light flashes 3 times
Red light blinking 3 times shows problem with lamp cover.
Lamp cover is not fixed securely in your tv after lamp replacement. Lamp cover is first thing that was removed to replace lamp, check lamp cover and make sure its back in place properly.
Thanks.
Jul 17, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Four blinking lights from standby led lamp after I turned on the TV.
Yeah, it is not lamp problem. Check fans in tv as one of fan is stopped for some reason and causing problem.
Jun 29, 2010 | Sony KDS-R50XBR1 50" HDTV
Lamp light is flashing and tv will not turn on
replace the lamp. it has failed. the lamp light is a warning sign to alert a failed lamp.
Jun 25, 2009 | Sony Televison & Video
I have a lg rt 52sz, lamp light flashed so i replaced the lamp, now when i turn the tv on the red light turns orange for 8 secnds then tv turns itself off, the lamp is still flashing. Signed unhappy...
make sure the lamp is in correctly and the door is also on good. there is a switch on the lamp door opening that wont let the set turn on if the door is not on.
Apr 24, 2009 | Televison & Video
Tv not turning on
I also have this model. A few months ago, when I turned on the tv, it told me my lamp was in need of replacement. just yesterday, my tv did the same as you....the blue light flashed and then the lamp light kept flickering. All I can say is your lamp needs to be replaced.
Mar 19, 2009 | JVC HD-56G657 Television
NO PICTURE OR SOUND
Hi
Usually, if the red light is flashing and you get no picture, that means that the lamp life cycle is finished and you'll have to get a replacment lamp. the lamp has about 3000 hours of life (2 to 3 years under nomal use).
You can buy a replacment lamp from here
http://cgi.ebay.com/NEW-DLP-LAMP-BULB-JVC-FOR-HD-61G787-HD-61G887-HD-61Z456_W0QQitemZ320274762989QQcmdZViewItem?IMSfp=TL0807151554r7572
Hope this helps
Cheers
Aug 10, 2008 | JVC HD-61Z456 Television
HELP
I had the same issue. Replaced the lamp and now mine is working. Normally this is a sign that the bulb is out, however - I would say now that either:
1. Your lamp is defective.  2. The balast in your TV is defective.
I would check out Discount-Merchant.com - they can help.
May 18, 2008 | LG 52SX4D 52" HDTV
Samsung DLP HL-S5087W 56" Confused...
Mine did that when the color wheel didn't spin up...just give it a whack where you installed the light & the wheel should spin up. I had to replace my color wheel as the bearing was shot & was buzzing all the time. The light won't come on if the wheel doesn't spin up first.
May 08, 2008 | Samsung DLP HL-P5663W 56" TV
Open Questions:
Samsung HL-R4266W 42" HDTV-Ready Projection Television Logo
204 people viewed this question
Jerry Greenberg
Jerry Greenberg
