Question about Kirby Ultimate G Bagged Upright Vacuum
Drive pedal stoped working
The drive pedal as stopped working
How to repair drive pedal kirby
You will need to remove upper cover ,then remove the three screws
holding the trans in. Slide out the old drive pedal reuse the cam arm
and install new pedal. Slide trans back in and reinstall belt,reinstall rear screw first then the other two . replace cover and test N/D pedal.
Jul 30, 2014 | Kirby Vacuums
How do I replace a kirby g7 drive pedal?
Here is a step by step walk through with pictures on how to replace the neutral / drive pedal on any Kirby Generation vacuum (G3, G4, G5, G6, Ultimate G, Ultimate G Diamond Edition, Sentria and Sentria II)
Kirby Neutral Drive Pedal Replacement Guide
GoodVac.com Technician
www.goodvac.com
1-800-775-6586
May 04, 2014 | Kirby G6 Bagged Upright Vacuum
Kirby g4 stoped working
cable has shorted out internally, will need new cable
Nov 18, 2012 | Kirby G4 Bagged Upright Vacuum
The foot pedal to go from drive to nuetral on my G series fell off and i cant seem to get it back in
The pedal assembly must be replaced,( part # 558401S), as it has a gear pressed to it which has come loose. The handle, switch plate, and upper motor cover must be removed first. To remove the plastic switch plate, remove it's screws and insert a flat screwdriver into the rectangular slot in it to pop it off. Four screws hold the upper motor shell in place. Next the switch button must be removed. The Techdrive assembly can be removed by removing the three screws on the bottom. Drop the drive down, and unhook it's belt from the gear on the end of the armature shaft. The pedal assembly can be removed by removing the remaining screw from the bottom of the drive unit. The N/D pedal has two parts - the pedal itself, and the shift cam. Observe carefully how these units fit together. After installing the new pedal and replacing the screw and washer to secure it, re-install the drive unit. The shift must be in the Drive position to install it, and remember to replace the belt. Be sure to line up the arm on the drive unit so that it engages the slot at the base of the handle pivot and re-install the other items.
Mar 06, 2011 | Kirby Ultimate G Bagged Upright Vacuum
How do you replace the drive/neutral lever (foot pedal) if it falls off? (The yellow and gray lever that you step on to put it into drive or neutral.) Not sure what happened but it just fell off. Now I...
The pedal assembly must be replaced,( part # 558401S), as it has a gear pressed to it which has come loose. The handle, switch plate, and upper motor cover must be removed first. To remove the plastic switch plate, remove it's screws and insert a flat screwdriver into the rectangular slot in it to pop it of. Four screws hold the motor cover in place. Next the switch button must be removed. The Techdrive assembly can be removed by removing the three screws on the bottom. Drop the drive down, and unhook it's belt from the gear on the end of the armature shaft. The pedal assembly can be removed by removing the remaining screw from the bottom of the drive unit. The N/D pedal has two parts - the pedal itself, and the shift cam. Observe carefully how these units fit together. After installing the new pedal and replacing the screw and washer to secure it, re-install the drive unit. The shift must be in the Drive position to install it, and replace the belt. Be sure to line up the arm on the drive unit so that it engages the slot at the base of the handle pivot and re-install the other items
Feb 28, 2011 | Kirby G5 Bagged Upright Vacuum
The lever came off (drive/neutral)
Feb 06, 2011 | Kirby Ultimate G Bagged Upright Vacuum
I have a Kirby G5 and need to replace the gear drive shaft, as the lever inside fell off and the shaft came out. (Common problem by the sound of it.) How do i remove the actual gearbox itself. I have...
I have never touched a Kirby vacuum
before and my wife had the same issue. The neutral/drive pedal just fell
out so I figured I would give it a shot to see if I could fix it and
quickly figured out the 3 screws in the bottom plate for the drive
unit wasn't the answer.
I was able to figure things out out after I found
a parts list with diagrams at the follow web site and address:
Vac Parts Warehouse.com
http://www.vacpartswarehouse.com/category-s/2821.htm
The two parts involved are:
13. Bracket Cam Assembly Neutral Drive
Pedal 557689A
16. Kirby Pedal Cam For Neutral Drive
G6 558499A
Here's how to get to a point that you
can get these two parts in/out of the machine.
- Remove bag and fill tube from handle
and main unit
- Remove floor nozzle assembly
- Remove the handle via the two screws
at the handle fork plate (these have loctite on them so needed a
socket wrench with torex bits to get them out).
- Remove the plastic rear scuff plate
vie the screw with the power cord anchor and screw by the Pedal Cam
For Neutral Drive. Note release plastic tab in slot in the center and
lift from the back and then over the base where the handle attaches.
I did not do this as I removed the the
power drive assembly so I could figure out how to put the dive
assembly back together. The pressed on arm that drives the cam
assembly had pulled of the pedal shaft so this also made it easier to
fish out the parts and experiment on positioning the arm in the right spot . I found the arm and a spring washer inside. Note – continue disassembly below if bracket cam assembly will not come out as it is easier to work with once the drive assembly is removed.
Remove the screw on the bottom plate that attaches the Bracket Cam Assembly and slide the Pedal Cam. Then the plastic back panel and the cam assembly should slide out if you lift up on it. Note that the screw is the only one with a star lock washer on it. Also note that this entire assembly is the only way that the parts are sold and it includes plastic back plate and metal cam assembly as. I when down the path to repair the existing assembly so I needed to take the power drive out The part was 16. Kirby Pedal Cam For Neutral Drive G6 558499A at Vac Parts Warehouse.com. The one listed on the website said it was for a G6 even though the parts listing is for a G5 so I don't know....
To continue to disassemble and take
the power drive assembly out:
- Remove the 4 screws from the Cover
Shell assembly - the metal top part. You do not need to remove the
hinged Headlight Cap that is attached to it.
- Remove the 4 screw from the bracket
assembly that has the handle attachment and forward/reverse switch.
It attached by two wires. I only disconnect one and swung it to the
side.
- Snap off the the on/off switch and
disconnect from the Actuating Rod Foot Pedal to Power Switch.
- Remove the 3 screw from the bottom
plate of the power drive assembly.
- Remove the drive belt.
- The power drive assembly will now
drop out the bottom.
I just put the spring washer and arm
back on the shaft and reassembled. I'll see how long that lasts
before before buying the new part. Update: this fix did not last long. Use red Loctite or super glue to attach cam to shaft so it doesn’t pull out if you want to avoid buying the new assembly. Note that the cam must be aligned so that when the neutral side is pushed the cam will stop in the detent to hold it in place. Must be reassembled in the drive position as that is the default for the drive assembly.
Have fun.
Aug 08, 2010 | Kirby G5 Bagged Upright Vacuum
The beater stoped working .
That sounds like a bad or burnt contact between one of the connections in the hose. Make sure all the connections are secure and look at the contacts, if they are bad you will usually see burn marks or melted plastic.
Hope this helps, and let me know if it doesn't.
Dec 01, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Back wheels not turning.
See if the pedal is set on D
Check if there is some resistance to move pedal from N to D and back - maybe pedal is broken...
See if handle slides back and forth a bit (maybe slide is rusted)
if everything is fine - Inspect primary drive belt. That will require to get inside the vacuum... See instructions HERE
If everything above is ok - you may need to replace a tech drive.
Good Luck
Nov 13, 2008 | Kirby G6 Bagged Upright Vacuum
Kirby Ultimate G Bagged Upright Vacuum Logo
20 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Gerry Harvey
Gerry Harvey
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
